[pgrouting-dev] Building TRSP branch
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jun 12 07:33:49 PDT 2012
On 6/12/2012 9:17 AM, Steve Horn wrote:
> Was not able to find these libraries via package manager, but I did get
> pgRouting and dependencies installed manually.
> The "cannot find -lgmp" referred to a dependency of CGAL that needed to
> be installed ( http://gmplib.org/manual/Installing-GMP.html#Installing-GMP )
> Also of note is that CGAL needs a specific version of the Boost
> libraries to work (1.41).
> After successful pgRouting make/make install then I ran the
> driving_distance function to test and got this:
> “Error while loading shared libraries: libboost_thread.so.1.41.0: cannot
> open shared object file: No such file or directory"
> Used the information in this blog to correct that error:
> http://somethingididnotknow.wordpress.com/2012/02/17/fix-the-error-while-loading-shared-libraries-libboost_thread-so-1-48-0-cannot-open-shared-object-file-no-such-file-or-directory-error/
> Hope this helps someone in the future.
> Steve: Haven't done a deep dive into the TRSP functionality -but I am
> impressed at the surface. Does it use an A Star algorithm at the core?
I'm afraid I have not looked in detail at the exact algorithm but I
believe it uses a combination of Dijkstra that is node based and then
uses, edge based exploration to navigate around the turn restrictions.
A Star requires a heuristic so you pass the end points of the edges
which we do not pass in TRSP, so we are not doing that. That might be an
interesting future enhancement that could speed TRSP up even faster. My
rough timing tests showed that performance was a little slower than
Dijkstra without any restrictions, but about 5x faster than our broken
Shooting Star.
Roni, If you have a chance it would be good if you could provide a
little more background information on how TRSP solves.
Thanks,
-Steve W
> Thanks for your efforts on this!
> On Mon, Jun 11, 2012 at 8:26 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> On 6/11/2012 7:58 PM, Steve Horn wrote:
> Trying to manually build and install the gmp dependency for
> cgal..but
> I'm curious how you can install it through yum. The searches you
> provided do not turn up anything.
> You probably need to google "centos cgal" and then add an
> appropriate repository to yum. I forget the exact way to do that.
> I'm more familiar with apt get and adding repositories. Does yum
> work
> similarly? Just curious and trying to learn. Thanks!
> Yes, yum is the CentOS equivalent to apt-get. They both work in
> similar ways. There were some good yum howto or tutorials that I
> learned from when I needed to use it that I found via google.
> -Steve
> On Monday, June 11, 2012, Stephen Woodbridge wrote:
> On 6/11/2012 3:41 PM, Steve Horn wrote:
> Hello again :)
> Trying to build and install the trsp branch on my CentOS
> linux box.
> (Using
> https://github.com/pgRouting/ pgrouting/wiki/Developer---
> Getting-Started
> <https://github.com/pgRouting/ pgrouting/wiki/Developer---
> Getting-Started
> <https://github.com/pgRouting/pgrouting/wiki/Developer---Getting-Started>>
> as
> a baseline)
> Here is where I'm at:
> # git clone https://github.com/pgRouting/ pgrouting.git
> <https://github.com/pgRouting/ pgrouting.git
> <https://github.com/pgRouting/pgrouting.git>>
> # cd pgrouting
> //Hack around installing GAUL
> # cmake -DWITH_TSP=ON -DWITH_DD=ON .
> -- POSTGRESQL_EXECUTABLE is POSTGRESQL_EXECUTABLE-NOTFOUND
> -- Found PostgreSQL: /usr/include/postgresql/
> include/server,
> /usr/pgsql-9.1/lib/libpq.so
> Boost headers were found here: /usr/include
> Output directory for libraries is set to /usr/pgsql-9.1/lib
> Installation directory for libraries is set to
> /usr/pgsql-9.1/lib and
> for SQL files is set to /usr/share/pgrouting
> /usr/pgsql-9.1/lib
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/shorn/pgrouting
> # make
> Linking CXX shared library ../../../lib/librouting_tsp.so
> */usr/bin/ld: cannot find -lgmp //THIS APPEARS TO BE
> THE PROBLEM?*
> collect2: ld returned 1 exit status
> make[2]: *** [lib/librouting_tsp.so] Error 1
> make[1]: *** [extra/tsp/src/CMakeFiles/
> routing_tsp.dir/all] Error 2
> make: *** [all] Error 2
> Can anyone help me understand the error "Cannot find -lgmp"?
> For TSP you need to instal GUAL and for DD you need the CGAL
> libraries.
> Try:
> yum search libcgal
> yum search cgal
> You probably need the dev package also.
> After you:
> cd pgrouting
> git checkout trsp ## switch to trsp branch
> git pull
> cmake -DWITH_TRSP=ON -DWITH_TSP=ON -DWITH_DD=ON .
> -Steve
> ______________________________ _________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
> http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
> <http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
> <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev> >
> Steve Horn
> Steve Horn
More information about the pgrouting-dev
