[pgrouting-dev] can not find the definition of the function
Jay Mahadeokar
jai.mahadeokar at gmail.com
Wed Jun 13 20:32:58 PDT 2012
Hi Jinfu,
It seems that your function is not created in postgres database. You need
to create a .sql file and write function definition. Modify cmakelists
accordingly.
If you have already done that, and didn't work, try adding it by giving the
command at sql prompt. Check out the documentation in apsp page in
pgrouting wiki for exact commands.
On 14 Jun 2012 07:52, "Jinfu Leng" <logicnut at gmail.com> wrote:
> Hey,
> I am writing the code for the new algorithm. I added the name of the file
> to the file "CMakeLists.txt", and then the file can be compiled. In
> pgAdmin3, I can call the function shortest_path(), but when I tried to call
> my function shortest_path_mild_two_q(), I got the error message "no matched
> function".
> My question is, besides "CMakeLists.txt", what else should I do to let the
> system know there is a function named shortest_path_mild_two_q().
> Thanks,
> Jinfu
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120614/a6f2f04f/attachment.html>
More information about the pgrouting-dev
