[pgrouting-dev] pgRouting and the Shortest Path Shooting Star algorithm
Stephen Woodbridge woodbri at swoodbridge.com
Thu Mar 8 09:21:12 EST 2012
Espen,
I have CC the list as there might be helpful information to others in my
response.
I get the following results on my Linux system. Is this what you are
getting on your system?
trsp_bug=# SELECT kollektivnett32.objid::integer, qry1.*
              FROM turn_restrict_shortest_path(
                'SELECT gid AS id,
                        source::int4,
                        target::int4,
                        minutes::double precision AS cost,
                        rminutes::double precision AS reverse_cost
                   FROM kollektivnett32',
                  17914,
                  24470,
                  true,
                  true,
                  'SELECT to_cost,
                          gid AS target_id,
                          rule AS via_path
                     FROM kollektivnett32_turns
                    WHERE costtype=''V''') qry1
              inner join kollektivnett32
                 on qry1.edge_id=kollektivnett32.gid;
  objid | vertex_id | edge_id |       cost
  39510 |     17914 |   39553 |  1.22921517354843
  39503 |     19542 |   39546 |  1.16385126125265
  39502 |     15062 |   39545 |  1.13463764875839
  39501 |     10238 |   39544 | 0.894134798291999
  39495 |     19538 |   39538 | 0.866380394768565
  39496 |     19468 |   39539 | 0.933687082563116
  39497 |     19470 |   39540 | 0.657732599215612
  39498 |     19473 |   39541 | 0.908336115840503
  39499 |     19452 |   39542 | 0.375975675882557
  39500 |      9999 |   39543 | 0.467548379399679
  39493 |     18169 |   39536 | 0.722558560770379
  39492 |     19474 |   39535 | 0.359215445372181
  39491 |     18166 |   39534 | 0.372316300710597
  39490 |      6151 |   39533 |   0.7529314841121
  39514 |     14128 |   39557 | 0.247611717608335
  39513 |      2820 |   39556 | 0.642005590638696
  39494 |     19535 |   39537 |  1.08148812344578
  39475 |     19518 |   39518 | 0.985412403126148
  39476 |     19519 |   39519 |  1.00870667860245
  39477 |     19524 |   39520 |  1.10356478488934
  39478 |      7347 |   39521 |  2.31489365914156
   2912 |     19418 |    2630 | 0.710630767866117
(22 rows)
Ok, I have a couple of observations:
1. the route does not get to the destination node which seems like that
might indicate a bug
2. I see you are using "rule AS via_path", is rule formatted the way you
would pass it to shooting_star? If so this is wrong. I unfortunately
implemented via_path to be a list of edges in the reverse order of rule.
IF for RULE:
target_id: 1, rule: 2,3,4,5
THEN for via_path
target_id: 1, via_path: 5,4,3,2
Since all your restrictions only involve a single edge this does not
matter. So moving on to the next potential problem. Consistency of edge
ids could be a problem.
For example, in the kollektivnett32_turns table what are the target_id
and rule ids? These should be the edge ids not the node ids and you
using: gid, objectid_1, objectid, or some other field for these values?
When you select your edges in the first query you have "gid as id", you
have to match the column used in the kollektivnett32_turns table as the
edge id to define the id in the first query. So if the
kollektivnett32_turns uses objectid values your first query needs to be
"objectid::integer as id"
Also it would be good it you can reduce the problem to a simple 10-20
node/edge graph that is easier to debug and understand. Most cases can
be demonstrated using a simple graph like:
                   o   o
         o---------o---o--------o
o-------o---------o---o--------o---------o
                   o   o
Just label the nodes and the edges, and set up the restrictions, then
you can run simple tests to verify that it works as expected on simple
cases.
-Steve
On 3/8/2012 5:12 AM, Espen O wrote:
> Hi
> Here is our testdata http://dl.dropbox.com/u/525315/example.rar
> It contains the following:
> *File *
> *Description *
> Kollektivnett32.sql
> Network table
> kollektivnett32_turns.sql
> Turn restrictions table
> example_query.sql
> Example query from node 17914 to 24470
> Image of expected result (24,2 minutes including turn costs)
> Regards Espen
>  > Date: Wed, 7 Mar 2012 10:43:50 -0500
>  > From: woodbri at swoodbridge.com
>  > To: pgrouting-dev at lists.osgeo.org
>  > Subject: Re: [pgrouting-dev] pgRouting and the Shortest Path Shooting
> Star algorithm
>  > On 3/7/2012 8:39 AM, Espen O wrote:
>  > > Hi
>  > > We are very interested in version 1.03/1.05 of pgRouting and the
>  > > Shortest Path Shooting Star algorithm. However, there is a problem with
>  > > way restrictions in shooting star if there is more than one rule for an
>  > > edge. It also doesn’t seem to take into account the reverse cost.
> We are
>  > > interested in fixing these bugs.
>  > > Stephen Woodbridge has developed an alternative
>  > > “turn_restricted_shortest_path” which is very promising. We have tested
>  > > the Windows version compiled by Sanak (2012/03/04), but it is very
>  > > unstable and seems to return inconsistent answers when running the same
>  > > input data multiple times.
>  > Hi Espen,
>  > I would like to get a copy of you graph and queries that return
>  > inconsistent results. I have not seen this behavior and I think I need
>  > to understand what is happening. If we have a bug I want to get it fixed.
>  > Can you dump your database something like:
>  > pg_dump -fP -Z0 -f mydump.sql.gz -t <table_1> -t <table_2> ... -U <user>
>  > -h localhost <mydatabase>
>  > and email that and the queries you are running. I would be greatly
>  > appreciated and I will analyze it and get any bugs fixed that we need to.
>  > Thanks,
>  > -Steve
>  > > We are working on Windows 2008 server 32 bit, not Linux. Is there
> anyone
>  > > who can give us the detailed setup for compiling on Windows (pgRouting
>  > > 1.03 2010/01/30 by Martin is the most stable we have tested) so we can
>  > > start to debug the source code? We have tried Sanaks recipe
>  > > (/sanak/pgrouting/blob/master/BUILD.msvc90), but we get a lot of errors
>  > > (Microsoft Visual C++ 2008 Express Edition and the required libraries).
>  > > Regards
>  > > Espen
>  > > _______________________________________________
>  > > pgrouting-dev mailing list
>  > > http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
