[pgrouting-dev] pgRouting and the Shortest Path Shooting Star algorithm
Espen O espoern at hotmail.com
Thu Mar 8 05:10:14 EST 2012
Excellent!
I will send you a link to our test data.
Regards Espen
> Date: Wed, 7 Mar 2012 10:43:50 -0500
> From: woodbri at swoodbridge.com
> To: pgrouting-dev at lists.osgeo.org
> Subject: Re: [pgrouting-dev] pgRouting and the Shortest Path Shooting Star algorithm
> On 3/7/2012 8:39 AM, Espen O wrote:
> > Hi
> > We are very interested in version 1.03/1.05 of pgRouting and the
> > Shortest Path Shooting Star algorithm. However, there is a problem with
> > way restrictions in shooting star if there is more than one rule for an
> > edge. It also doesn’t seem to take into account the reverse cost. We are
> > interested in fixing these bugs.
> > Stephen Woodbridge has developed an alternative
> > “turn_restricted_shortest_path” which is very promising. We have tested
> > the Windows version compiled by Sanak (2012/03/04), but it is very
> > unstable and seems to return inconsistent answers when running the same
> > input data multiple times.
> Hi Espen,
> I would like to get a copy of you graph and queries that return
> inconsistent results. I have not seen this behavior and I think I need
> to understand what is happening. If we have a bug I want to get it fixed.
> Can you dump your database something like:
> pg_dump -fP -Z0 -f mydump.sql.gz -t <table_1> -t <table_2> ... -U <user>
> -h localhost <mydatabase>
> and email that and the queries you are running. I would be greatly
> appreciated and I will analyze it and get any bugs fixed that we need to.
> Thanks,
> -Steve
> > We are working on Windows 2008 server 32 bit, not Linux. Is there anyone
> > who can give us the detailed setup for compiling on Windows (pgRouting
> > 1.03 2010/01/30 by Martin is the most stable we have tested) so we can
> > start to debug the source code? We have tried Sanaks recipe
> > (/sanak/pgrouting/blob/master/BUILD.msvc90), but we get a lot of errors
> > (Microsoft Visual C++ 2008 Express Edition and the required libraries).
> > Regards
> > Espen
> > pgrouting-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120308/672b69f1/attachment.html
More information about the pgrouting-dev mailing list
