[pgrouting-dev] pgRouting and the Shortest Path Shooting Star algorithm
Stephen Woodbridge woodbri at swoodbridge.com
Wed Mar 7 10:43:50 EST 2012
On 3/7/2012 8:39 AM, Espen O wrote:
> Hi
> We are very interested in version 1.03/1.05 of pgRouting and the
> Shortest Path Shooting Star algorithm. However, there is a problem with
> way restrictions in shooting star if there is more than one rule for an
> edge. It also doesn’t seem to take into account the reverse cost. We are
> interested in fixing these bugs.
> Stephen Woodbridge has developed an alternative
> “turn_restricted_shortest_path” which is very promising. We have tested
> the Windows version compiled by Sanak (2012/03/04), but it is very
> unstable and seems to return inconsistent answers when running the same
> input data multiple times.
Hi Espen,
I would like to get a copy of you graph and queries that return
inconsistent results. I have not seen this behavior and I think I need
to understand what is happening. If we have a bug I want to get it fixed.
Can you dump your database something like:
pg_dump -fP -Z0 -f mydump.sql.gz -t <table_1> -t <table_2> ... -U <user>
-h localhost <mydatabase>
and email that and the queries you are running. I would be greatly
appreciated and I will analyze it and get any bugs fixed that we need to.
Thanks,
   -Steve
> We are working on Windows 2008 server 32 bit, not Linux. Is there anyone
> who can give us the detailed setup for compiling on Windows (pgRouting
> 1.03 2010/01/30 by Martin is the most stable we have tested) so we can
> start to debug the source code? We have tried Sanaks recipe
> (/sanak/pgrouting/blob/master/BUILD.msvc90), but we get a lot of errors
> (Microsoft Visual C++ 2008 Express Edition and the required libraries).
> Regards
> Espen
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
