[pgrouting-dev] GSoC Timeline
Razequl Islam ziboncsedu at gmail.com
Wed May 16 16:10:17 EDT 2012
Hi Steve,
Sorry for being late to reply. I was busy for some academic purposes which
are almost end. Now i can give the full time for this project.
I am using ubuntu 12.04 LTS now. I hope it will not cause any problem in
future as it is the very latest version of Ubuntu. I have already installed
the pre-requirement for pgrouting. and compiled pgrouting core as it says
in the documentation. I found a great help from Github for completing this
process. But stuck at adding functionality of TRSP.  I haven't found any
TRSP section in ~/pgrouting/extra/ directory. How could i add this
functions. Please help.
I have already gone through the Workshop+Tutorial.
now i am working on making the design and prototype of the implementation.
I will up it to gitub wiki in between 1 or 2 days.
Thanks
Razequl
On Tue, Apr 24, 2012 at 7:37 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Jinfu, Razequl,
> Since I was just updating my calendar with critical GSoC dates from here:
> http://www.google-melange.com/**gsoc/document/show/gsoc_**
> program/google/gsoc2012/faqs#**timeline<http://www.google-melange.com/gsoc/document/show/gsoc_program/google/gsoc2012/faqs#timeline>
> I thought I would pass this on to you in case you do not have it handy.
> Please make sure you have these dates in your calendar so you can plan
> around them. Many of these are hard deadlines that we need to meet to keep
> your project in good standing with Google.
> I'm sure you guys are busy with exams and curriculum deadlines but between
> now and May 21th is also your time to get a head start on your projects by
> reading pgRouting documentation, code, setting up a build and test
> environment, getting to know us better, asking questions, etc. This is a
> good time to think about how you will actually break down you project in
> detail and discuss that with us.
> We like to use the pgrouting-dev list for general discussions because then
> you can get responses for Daniel, Jay and/or myself and other users and
> developers my have some valuable insights also. Any given question/answer
> is likely to provide insight to others as well. Also, Daniel is in Japan, I
> am in the Boston, Mass USA area, and I think Jay is in India. Given the
> wide range of timezones, we are more likely to get you answers quicker by
> using the list.
> How to get started:
> 0. Read these:
> https://github.com/pgRouting/**pgrouting/wiki/Developer---**
> Getting-Started<https://github.com/pgRouting/pgrouting/wiki/Developer---Getting-Started>
> http://download.osgeo.org/**pgrouting/forum/pgrouting.**postlbs.org/wiki/*
> *pgRoutingDocs.html<http://download.osgeo.org/pgrouting/forum/pgrouting.postlbs.org/wiki/pgRoutingDocs.html>
> 1. Let us know if you are using Linux or Windows? Linux is easier for us
> to support. So hopefully, you have access to a Linux machine.
> 2. Check out the TRSP branch from github. - Need help? Ask :)
> 3. Build it. - Need help? Ask.
> 4. Install it. - Need help? Ask.
> 5. Try out the Workshops & Tutorials
> 6. I have some simple test cases for trsp, somewhere, I will post a link
> to download it.
> 7. Look at the flow of control from SQL, to plpgsql function, to C
> wrappers, to C++ code in the extra/trsp/* files. Ask questions so you
> understand this. You will need to mirror this flow for your project.
> 8. start planning out your project in terms of how you will integrate your
> code using the above trsp as a model.
> Ok, this is a lot of stuff, but you have some time. My goal here is to lay
> out high level tasks in an order that will make your project flow smoothly.
> The key is communications. Please let us know what you are doing? We are
> here to help you and guide you to a successful conclusion.
> Jay, Roni - since you have both been GSoC students and recently worked on
> various projects in pgRouting, feel free to jump in with any thoughts
> hints, etc.
> Best regards,
>  -Steve
> ______________________________**_________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120517/d73251f8/attachment.html
More information about the pgrouting-dev mailing list
