[pgrouting-dev] GSoC Timeline
Stephen Woodbridge woodbri at swoodbridge.com
Wed May 16 16:31:45 EDT 2012
Hi Razequl,
It is good to here that you have got your course work almost done and it
sounds like you are making excellent progress getting started with
pgrouting.
Regarding the trsp it is in a branch called trsp so you probably need to
do something like:
cd /path/to/pgrouting-git/
#git checkout master
#git pull
git checkout trsp
#git merge master
cmake -DWITH_TRSP=ON .
make
sudo make install
Let me know if you have questions.
Thanks,
   -Steve
On 5/16/2012 4:10 PM, Razequl Islam wrote:
> Hi Steve,
> Sorry for being late to reply. I was busy for some academic purposes
> which are almost end. Now i can give the full time for this project.
> I am using ubuntu 12.04 LTS now. I hope it will not cause any problem in
> future as it is the very latest version of Ubuntu. I have already
> installed the pre-requirement for pgrouting. and compiled pgrouting core
> as it says in the documentation. I found a great help from Github for
> completing this process. But stuck at adding functionality of TRSP.  I
> haven't found any TRSP section in ~/pgrouting/extra/ directory. How
> could i add this functions. Please help.
> I have already gone through the Workshop+Tutorial.
> now i am working on making the design and prototype of the
> implementation. I will up it to gitub wiki in between 1 or 2 days.
> Thanks
> Razequl
> On Tue, Apr 24, 2012 at 7:37 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     Jinfu, Razequl,
>     Since I was just updating my calendar with critical GSoC dates from
>     here:
>     http://www.google-melange.com/ gsoc/document/show/gsoc_
>     program/google/gsoc2012/faqs# timeline
>     <http://www.google-melange.com/gsoc/document/show/gsoc_program/google/gsoc2012/faqs#timeline>
>     I thought I would pass this on to you in case you do not have it
>     handy. Please make sure you have these dates in your calendar so you
>     can plan around them. Many of these are hard deadlines that we need
>     to meet to keep your project in good standing with Google.
>     I'm sure you guys are busy with exams and curriculum deadlines but
>     between now and May 21th is also your time to get a head start on
>     your projects by reading pgRouting documentation, code, setting up a
>     build and test environment, getting to know us better, asking
>     questions, etc. This is a good time to think about how you will
>     actually break down you project in detail and discuss that with us.
>     We like to use the pgrouting-dev list for general discussions
>     because then you can get responses for Daniel, Jay and/or myself and
>     other users and developers my have some valuable insights also. Any
>     given question/answer is likely to provide insight to others as
>     well. Also, Daniel is in Japan, I am in the Boston, Mass USA area,
>     and I think Jay is in India. Given the wide range of timezones, we
>     are more likely to get you answers quicker by using the list.
>     How to get started:
>     0. Read these:
>     https://github.com/pgRouting/ pgrouting/wiki/Developer---
>     Getting-Started
>     <https://github.com/pgRouting/pgrouting/wiki/Developer---Getting-Started>
>     http://download.osgeo.org/ pgrouting/forum/pgrouting.
>     postlbs.org/wiki/ pgRoutingDocs.html
>     <http://download.osgeo.org/pgrouting/forum/pgrouting.postlbs.org/wiki/pgRoutingDocs.html>
>     1. Let us know if you are using Linux or Windows? Linux is easier
>     for us to support. So hopefully, you have access to a Linux machine.
>     2. Check out the TRSP branch from github. - Need help? Ask :)
>     3. Build it. - Need help? Ask.
>     4. Install it. - Need help? Ask.
>     5. Try out the Workshops & Tutorials
>     6. I have some simple test cases for trsp, somewhere, I will post a
>     link to download it.
>     7. Look at the flow of control from SQL, to plpgsql function, to C
>     wrappers, to C++ code in the extra/trsp/* files. Ask questions so
>     you understand this. You will need to mirror this flow for your project.
>     8. start planning out your project in terms of how you will
>     integrate your code using the above trsp as a model.
>     Ok, this is a lot of stuff, but you have some time. My goal here is
>     to lay out high level tasks in an order that will make your project
>     flow smoothly. The key is communications. Please let us know what
>     you are doing? We are here to help you and guide you to a successful
>     conclusion.
>     Jay, Roni - since you have both been GSoC students and recently
>     worked on various projects in pgRouting, feel free to jump in with
>     any thoughts hints, etc.
>     Best regards,
>       -Steve
>     ______________________________ _________________
>     pgrouting-dev mailing list
>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>     http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>     <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
More information about the pgrouting-dev mailing list
