[pgrouting-dev] Problems in Importing .osm to Database
Daniel Kastl
daniel at georepublic.de
Wed May 30 12:26:11 PDT 2012
Hi Jinfu,
As far as I remember this is only a log message. I think it would be better
to reduce the number of messages.
At the end it should tell you the number of imported road segments.
Daniel
On Wed, May 30, 2012 at 6:57 PM, Jinfu Leng <logicnut at gmail.com> wrote:
> Hey Daniel, Dave,
> Thanks. The problem is solved by settings the pg_hba.conf to trust.
> But I got some error messages like:
> "We DON'T need a way of type and class
> We need a way of type highway and class steps
> We need a way of type highway and class footway
> We need a way of type highway and class footway"
> Do these errors matter? Or I can ignore them and go to the next step?
> Thanks again,
> Jinfu
> On Wed, May 30, 2012 at 10:44 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>> Hi Jinfu,
>> Look at the "Note" in the workshop:
>> http://workshop.pgrouting.org/chapters/osm2pgrouting.html#run-osm2pgrouting
>> When you don't need to care about server security you can set the
>> settings in pg_hba.conf to trust.
>> Daniel
>> On Wed, May 30, 2012 at 8:34 AM, Dave Potts <dave.potts at pinan.co.uk>wrote:
>>> Hello,
>>> From the text of the error message, it appears your having a problem
>>> connecting to your database, its not a pgroute package error but rather a
>>> postgres error.
>>> What happens if you try
>>> psql -d routing -U postgres
>>> This should connect directly to your database without using any of the
>>> routing software.
>>> Jinfu Leng wrote:
>>> > Hello all,
>>> > I created the database "routing" from the "template_routing", and
>>> > downloaded the .osm file of London. But I got a problem when I was
>>> trying
>>> > yo import this .osm file to the database.
>>> > command:
>>> > "osm2pgrouting -file "London.osm" -conf
>>> > "/usr/share/osm2pgrouting/mapconfig.xml" -dbname routing -user postgres
>>> > -clean"
>>> > error message:
>>> > "connection failed"
>>> > Any ideas?
>>> > Thanks a advance.
>>> > Jinfu
>>> > _______________________________________________
>>> > pgrouting-dev mailing list
>>> > pgrouting-dev at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120530/cc4e35da/attachment.html>
More information about the pgrouting-dev
