[pgrouting-dev] [pgr_2.0] Just checked in code to eliminate GAUL
Pieter du Plooy
pjduplooy at zpanelcp.com
Sat Apr 6 00:16:01 PDT 2013
Thanx Steve
Do you perhaps have prebuilt binaries? (64 and 32 bit)?
I will build during this week, just need to get my DEV machine up and
running.
On Sat, Apr 6, 2013 at 2:38 AM, Stephen Woodbridge
<woodbri at swoodbridge.com>wrote:
> I built this based on the postgis mingw32 and ming64 build environments.
> But if you pull my branch there is a tools directory at the top level that
> has some scripts (more as doc then a runnable script) called:
> makedependanciesw64.sh - how to build the dependencies
> makepgroutingw32.sh - how to build under ming32
> makepgroutingw64.sh - how to build under ming64
> I say to look at these as docs not as scripts because they have a lot of
> assumptions about directory structures and such.
> There are also a couple of patch files in the tools directory also. With
> my latest checking you do not need to build the GAUL dependency anymore.
> -Steve
> On 4/5/2013 1:09 AM, Pieter du Plooy wrote:
> Steve
> Is the windows build instructions the same as what I did last year for
> the build that I made? (mingw?)
> Pieter
> On Fri, Apr 5, 2013 at 3:35 AM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> Hi All,
>> I have just checked in code into sew-devel-2_0 branch that eliminates the
>> GAUL dependency and replaces the TSP solver with a simple C routine. I
>> rewrote the TSP lib code to use the existing GAUL API and to use the
>> postgresql memory management and added two test cases. I have build and
>> tested on Win32-pg92 and Linux-pg84 with no problems.
>> Daniel - Thanks for the feedback on TSP, I will look at it and see what I
>> can do with your suggestions.
>> The current code assumes a loop, ie: the start is also the end point.
>> Other than that is should work as before.
>> -Steve
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> pgrouting-dev mailing listpgrouting-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130406/acd84d98/attachment.html>
More information about the pgrouting-dev
