[pgrouting-dev] [pgr_2.0] Just checked in code to eliminate GAUL
Stephen Woodbridge woodbri at swoodbridge.com
Fri Apr 5 17:38:49 PDT 2013
I built this based on the postgis mingw32 and ming64 build environments.
But if you pull my branch there is a tools directory at the top level
that has some scripts (more as doc then a runnable script) called:
makedependanciesw64.sh  - how to build the dependencies
makepgroutingw32.sh          - how to build under ming32
makepgroutingw64.sh          - how to build under ming64
I say to look at these as docs not as scripts because they have a lot of
assumptions about directory structures and such.
There are also a couple of patch files in the tools directory also. With
my latest checking you do not need to build the GAUL dependency anymore.
-Steve
On 4/5/2013 1:09 AM, Pieter du Plooy wrote:
> Steve
> Is the windows build instructions the same as what I did last year for
> the build that I made? (mingw?)
> Pieter
> On Fri, Apr 5, 2013 at 3:35 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     Hi All,
>     I have just checked in code into sew-devel-2_0 branch that
>     eliminates the GAUL dependency and replaces the TSP solver with a
>     simple C routine. I rewrote the TSP lib code to use the existing
>     GAUL API and to use the postgresql memory management and added two
>     test cases. I have build and tested on Win32-pg92 and Linux-pg84
>     with no problems.
>     Daniel - Thanks for the feedback on TSP, I will look at it and see
>     what I can do with your suggestions.
>     The current code assumes a loop, ie: the start is also the end
>     point. Other than that is should work as before.
>     -Steve
>     _______________________________________________
>     pgrouting-dev mailing list
>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130405/865e7ce4/attachment.html>
More information about the pgrouting-dev mailing list
