[pgrouting-dev] [pgr_2.0] Just checked in code to eliminate GAUL
Pieter du Plooy
pjduplooy at zpanelcp.com
Thu Apr 4 22:09:01 PDT 2013
Steve
Is the windows build instructions the same as what I did last year for the
build that I made? (mingw?)
Pieter
On Fri, Apr 5, 2013 at 3:35 AM, Stephen Woodbridge
<woodbri at swoodbridge.com>wrote:
> Hi All,
> I have just checked in code into sew-devel-2_0 branch that eliminates the
> GAUL dependency and replaces the TSP solver with a simple C routine. I
> rewrote the TSP lib code to use the existing GAUL API and to use the
> postgresql memory management and added two test cases. I have build and
> tested on Win32-pg92 and Linux-pg84 with no problems.
> Daniel - Thanks for the feedback on TSP, I will look at it and see what I
> can do with your suggestions.
> The current code assumes a loop, ie: the start is also the end point.
> Other than that is should work as before.
> -Steve
> ______________________________**_________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130405/edc2c485/attachment.html>
More information about the pgrouting-dev
