[pgrouting-dev] Gsoc 2013 Preliminary project proposal
Mukul priya mukul2047 at gmail.com
Sun Apr 14 06:41:37 PDT 2013
Thanks  for the reply Steve , clarifies all the issues that i raised ,
Proposed data structures cover  what we need , quad tree should work too ,
I am right now looking into the last part which describes the method of
appending our graph with new cells , seems fine and very much implementable
, will post something in case some new ideas strike me . :)
 Thanks.
On Sun, Apr 14, 2013 at 10:59 AM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> On 4/13/2013 11:12 PM, Mukul priya wrote:
>> Thanks Steve for clearly mentioning the two proposals.
>> For Item 1 , upgrading all the algorithms will certainly require a lot
>> of work and since i will be having my summer vacation i don't have any
>> issue with it :).
>> For item 2 , i am looking into the idea that you have proposed , It is
>> very much doable , there are however some concerns of mine like
>> - how do we decide what should be the grid size . this can vary for
>> suburban area and urban area based on netwrok density.
> This might be done with a quad tree approach. You start with a square and
> some condition like maximum number of node. If you exceed that number you
> quarter it into 4 squares and divide the point into each of them.
>  - how do we classify the nodes lying on the junction of two or more
>> grids . should it be assigned to all the grids??
> A node can only lie in one square or the edge boundary of a square it does
> not matter which one it is put in. Edges need to be flagged if the cross a
> square boundary.
>  - how do we decide the grid that needs to be loaded in the memory ,
>> connectivity with the previous grid seems legit here but i guess we need
>> to discuss some corner cases too.
> We could probably do something like
> typedef struct pair {
>   int a;
>   int b;
> } PAIR;
> typedef struct edge_type {
>   int node_a;
>   int node_b;
>   PAIR *squares; // NULL if it does not cross square edge
>   float cost;
>   float rcost;
> } EDGE;
> Where PAIR can be assign the gridcell for the a and b ends.
> If we number the grid cells by their quadtree numbers like:
> | 1 | 2 |
> | 3 | 4 |
> So you start, with the above for your coverage area. So all nodes would
> fall into cells 1-4. If you had to split cell 1 above, then those 4 new
> cells would be number 11, 12, 13, 14 and the remaining unsplit cells would
> still be 2, 3, 4. If you had to further split cell 14, then the new cells
> would be numbered 141, 142, 143, 144. So each time a cell gets subdivided,
> it gets another digit added.
> This is the challenge of design good algorithms, if we have millions of
> edges and node, we need to be efficient memory wise with our data
> structures but still be fast. In the database, you need to think about
> where the data is coming from (ie: tables using queries) and when it gets
> moved into memory. You can't think just C code or database code, you have
> to use both.
> The idea being that we want to prepare our data in tables, then issue
> queries from C to get the new edges we need to append cell(s) to our graph.
> So I'm thinking that we have a recursive plpgsql procedure that splits the
> nodes into the appropriate quadtree cells based on some rules. So for
> example we have a vertices_tmp table that we use to assign node numbers to
> nodes, we could add a cell column like this:
> CREATE TABLE vertices_tmp
>   id serial NOT NULL,
>   cell bigint,
>   the_geom geometry,
> and after we run the quadtree analysis each node is assigned a cell
> number. The edge table has node_a and node_b assigned to it also.
> If we want all edges related to cell 114 then we can do a query like:
> select b.*
>   from vertices_tmp a, edges b
>  where a.cell=114 and (a.id=b.node_a or a.id=b.node.b);
> Thoughts?
> -Steve
>> Thanks.
>> On Sat, Apr 13, 2013 at 6:20 AM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>> wrote:
>>     On 4/11/2013 3:24 PM, Mukul priya wrote:
>>         Hi Steve and Daniel,
>>                   You suggested extending the present algorithms such
>>         that its
>>         input  can take more points and not only the source and
>>         destination . i
>>         think this can be implemented and i will soon come up with
>>         implementation details( kind of more technical ) .
>>                   Can you be a liitle bit more elaborate about
>>         partioning data
>>         into spatial chunks or even suggest some readings . I can then
>>         come up
>>         with some better ideas about implementing it.
>>     This is just me thinking out loud :)
>>     Lets say we construct a grid of one degree squares, you can
>>     visualize it by drawing a grid over your map.
>>     Then you can associate all the nodes with the grid they fall in. We
>>     might also need to associate edges to the grids also and an edge the
>>     crosses over a grid boundary might need to be associated with two
>>     grids. This could be done with some simple relational tables like:
>>     node_id|grid_id  or  edge_d|grid_id
>>     So my idea would be to do the routing like this:
>>     1. get the start node or edge
>>     2. build the graph based on loading the items in the related grid
>>     3. mark the boundary nodes (we might want to do this when we grid
>> them)
>>     4. run the algorithm until we find the target node or hit a boundary
>>     node
>>     5. on hitting a boundary:
>>        a. we check if the connected grid is loaded and continue if it is
>>        b. or we extent the graph with the new grid
>>     6. continue with the routing
>>     We might want to be able to dynamically change the size of the grid
>>     cell based on the number of items in it. This would give us better
>>     performance when transitioning from rural areas into urban areas
>>     where there is a greater density of road segments. Think of a
>>     quadtree where we split it based on number of entities.
>>                   Daniel , i took a look at the oracle link that you
>>         provided but
>>         there was no details about how it has been implemented , it was
>> more
>>         about how one can use it. May be a bit  more search   and luck
>> might
>>         take me to its implementation document :) .
>>     Right, it is useful if you look at the documentation and ask why did
>>     they do it that way and what does it imply about how it works behind
>>     the scenes.
>>                    The other thing that you mentioned was about
>> contraction
>>         Hierarchy . Still the nodes have to be ordered based on some
>>         criteria or
>>         according to their importance . We can  use natural hierarchy
>>         present in
>>         the network for doing that .
>>     This is not related to what you proposed. It is an algorithm that
>>     does a lot of precompuation, that is LOTS in capitals, but it can
>>     get results in milliseconds for cross country routes.
>>                     i will be really grateful if anyone can correct me
>>         in case if
>>         my thought process in not on the right lane and sorry for the
>>         late reply
>>         as my academic session  is in progress too .Meanwhile  i am
>>         trying to
>>         get fluent with git ,cmake and other tools.
>>     So read over our wiki:
>>     https://github.com/pgRouting/_**_pgrouting/wiki<https://github.com/pgRouting/__pgrouting/wiki>
>>     <https://github.com/pgRouting/**pgrouting/wiki<https://github.com/pgRouting/pgrouting/wiki>
>>     The way I see it at the moment there are two unrelated proposals on
>>     the table (I'm leaving out the contraction hierarchy):
>>     1. multi point routing
>>     2. partition JIT graph building while routing
>>     Item 1 is fairly trivial technically, I think, but if you were to
>>     upgrade all the algorithms to do this it would be a lot of work and
>>     a useful contribution to pgrouting.
>>     Item 2 is more of a design and code a new algorithm and you would
>>     probably want to focus on using astar or trsp algorithm to do this
>>     with. This one is more technically challenging and has more unknowns
>>     in it but I think it should be doable.
>>     If you are interested in reading about contraction hierarchies:
>>     https://www.google.com/#q=__**contraction<https://www.google.com/#q=__contraction>
>>     <https://www.google.com/#q=**contraction<https://www.google.com/#q=contraction>>
>> hierarchies
>>     Thanks,
>>        -Steve
>>         Thanks .
>>         Mukul
>>         On Thu, Apr 11, 2013 at 6:47 PM, Stephen Woodbridge
>>         <mailto:woodbri at swoodbridge.__**com
>>         <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>> wrote:
>>              With pgRouting, we do most things dynamically, here is the
>>         basic flow:
>>              1. Given a collection of input, points, nodes, or edges
>>              map these to nodes or edges depending on algorithm.
>>              2. Select the edges we need to build the graph
>>              3. build the graph and solve it
>>              4. return the results
>>              All our algorithms today only take start and end points.
>>         They could
>>              be extended to take points. Each "point" (I use "point" as
>>         a generic
>>              term because it might be a lat/lon, node id, edge id and
>>         offset,
>>              etc) would need to be mapped to the appropriate input need
>>         for any
>>              given algorithm.
>>              So for node based algorithms like Dijkstra,and astar it
>>         would get
>>              resolved to a node. For TRSP it would get mapped to the
>>         nearest edge
>>              and offset along that edge. Postgis has lots of handy tools
>> for
>>              doing this.
>>              -Steve
>>              On 4/10/2013 10:50 PM, Mukul priya wrote:
>>                  Thanks for the reply steve . i have already cloned the
>>         github
>>                  repository
>>                  and looking into various aspects of it .
>>                  For IRNN querry implementation i think it is a good
>>         idea to sub
>>                  divide
>>                  the whole route and generate n+1 routes separately ,
>>         say from S
>>                  to F1 ,
>>                  F1-F2 ,..... F(n-1)-Fn , Fn to D . i wanted to know if
>>         we have
>>                  that kind
>>                  of a data where each and every facility is mentioned on
>>         the map as a
>>                  point (node ) . even if it is not directly connected to
>>         the road
>>                  network
>>                  we can basically treat it a pseudo node and then call
>>         the router
>>                  . The
>>                  other thing about optimization yes we can do that using
>>         spatial
>>                  range
>>                  querries suppose there are several instances of the same
>>                  facility that a
>>                  user wants to access then we can use spatial range
>>         querries to
>>                  locate
>>                  that facility which is the nearest.
>>                  On Thu, Apr 11, 2013 at 1:42 AM, Stephen Woodbridge
>>         <mailto:woodbri at swoodbridge.__**com <mailto:woodbri at swoodbridge.*
>>         <mailto:woodbri at swoodbridge.>_**___com
>>         <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>>
>> wrote:
>>                       On 4/10/2013 3:23 PM, Mukul priya wrote:
>>                           Hi ,
>>                       Hi Mukul,
>>                       Thank you for your interest in pgRouting.
>>                                          I am a  B.tech fourth year
>>         student at
>>                  IIIT-Hyderabad
>>                           pursuing a degree in computer science and
>>         engineering
>>                  and i will
>>                           be soon
>>                           pursuing a Masters Degree in the field of
>> Spatial
>>                  Informatics
>>                           and the
>>                           research topic that i have been working on is
>> *"In
>>                  route nearest
>>                           neighbour querries".*
>>                                          Last year i worked on a project
>>         that was
>>                  funded by
>>                           Honeywell technology solutions and it gave me
>>         a lot of
>>                  insight about
>>                           open source programming and industrial work
>>         culture.
>>                           I was introduced to pgrouting by *Prof.
>> Venkatesh
>>                  Raghavan* who
>>                           visited
>>                           our college last summer. i have also used
>>         pgrouting for
>>                           implementing one
>>                           of my Honors project.
>>                           i have gone through the updated ideas page and
>>         i am
>>                  listing out
>>                           a topic
>>                           that i feel i can contribute to.
>>                           *Idea *
>>                           Network Partitioning
>>                           A very simple method using which it can be
>>         done is :
>>                              * *Existence of a natural Hierarchy*
>>                                      Generally road networks are
>>         organized such
>>                  that there
>>                           is some
>>                           natural hierarchy for example if we look at
>>         the road
>>                  network of
>>                           USA we
>>                           observe that there are national highways which
>>         connect
>>                  multiple
>>                           large
>>                           regions , inter state roads connect places
>>         within these
>>                  regions
>>                           , multi
>>                           lane roads connect city areas and then there
>>         are small
>>                  roads to
>>                           connect
>>                           individual houses.
>>                                        so what we can do is first rank
>> these
>>                  classes that
>>                           constitute the road network and then use the
>>         highest
>>                  level roads to
>>                           divide the road network into large regions
>>         enclosed by
>>                  these
>>                           roads. each
>>                           of the divided regions can further be divided
>>         again
>>                  using next lower
>>                           level road.
>>                                        so suppose we have a road network
>>         which n
>>                  classes of
>>                           different roads then we can create a tree of
>>         depth n-1
>>                  where the
>>                           root of
>>                           the tree will represent the entire road
>>         network and
>>                  children of
>>                           the the
>>                           root node will represent the area formed by
>>                  partitioning the
>>                           root using
>>                           the level 1 ( highest ) edges and so on . the
>>         nodes
>>                  will basically
>>                           represent a smaller part of the road network.
>>                                         The idea seems to be very naive
>>         right now
>>                  but if
>>                           anyone can
>>                           give some feedback whether it is achievable or
>>         not or
>>                  may be suggest
>>                           some modifications.
>>                       Yes this is the basics of how this could work.
>>         Because we
>>                  build our
>>                       graphs dynamically for each route request, we can do
>>                  something like
>>                       this today. Typically you have to feed the route
>>         request
>>                  and SQL
>>                       query that provides the edges needed to build the
>>         graph and
>>                  this can
>>                       be simply the bounding box of the start and end
>>         point of
>>                  the route
>>                       expanded slightly to allow the route move outside
>> that
>>                  bounds by a
>>                       little if needed. A case in point are start and
>>         end points
>>                  that form
>>                       a vertical of horizontal line.
>>                       So for the natural hierarchy, you can for a SQL
>>         query like:
>>                       select * from edges where st_dwithin(the_geom,
>>         start_pnt,
>>                  radius)
>>                       union
>>         end_pnt, radius)
>>                       union
>>                       select * from edges
>>                          where st_expand(st_makeline(start___**____pnt,
>>         end_pnt), pct)
>>                            and road_class < 4;
>>                       So this gets all edges regardless of class at the
>>         start and
>>                  end and
>>                       then gets all the major roads and highways between
>> the
>>                  start and end
>>                       points. We can dynamically select the edges that
>>         we want
>>                  when we
>>                       build the graph.
>>                       Regardless of how you implement the routing, the
>>         problem is all
>>                       about the data. If you have a road segment the is
>>                  misqualified, you
>>                       might end up with a network that is broken between
>>         start
>>                  and end.
>>                       This can alsoo happen if ramps are not coded
>>         correctly.
>>                       One of the challenges we have today is that we
>>         have to be
>>                  able to
>>                       construct the whole graph in memory before we can
>>         start
>>                  routing.
>>                       This is ok for small areas but it is a problem if
>>         you want to
>>                       generate a route between say Miami, Florida and
>>         Seattle,
>>                  Washington.
>>                       An interesting problem would be the ability to
>>         partition
>>                  the data in
>>                       spatial chucks and only load them as the solver
>>         needed them.
>>                       If you think about your edges sorted into say 1
>>         degree grid
>>                  partitions,
>>                       then you load the partition for the start point
>>         and start
>>                  routing
>>                       using A* search, when you frontier get to an edge
>>         of the
>>                  grid you
>>                       are in, then you load the adjacent grid and
>>         continue, if
>>                  you bump
>>                       into another grid boundary that is not loaded yet,
>> you
>>                  load, if it
>>                       is already loaded you continue. Anyway food for
>>         thought! :)
>>                                          In route nearest neighbour
>>         querries(
>>                  IRNN) which
>>                           handle
>>                           querries like computation of shortest path ,
>>         provided
>>                  that the user
>>                           wants to visit facilities F1 , F2 ,.....FN
>>         while he/she
>>                  drives
>>                           or walks
>>                           from source to destination. Network
>>         partitioning can
>>                  optimize these
>>                           computations  too as the search space reduces
>>                  significantly once
>>                           we have
>>                           the partitions. Handling such querries have
>>         not been
>>                  implemented
>>                           yet. It
>>                           will be very helpful if we can have some
>>         discussion
>>                  about whether
>>                           implementing it is feasible or not.
>>                       What is we just added via support to routing? Then
>>         we could do
>>                       something like say generate a route: Start, F1,
>>         F2, ... Fn, End
>>                       This would allow us to build a graph one time and
>>         then generate
>>                       multiple sub-routes with in the graph. Today if
>>         you want to
>>                  do that
>>                       you have to generate n+1 routes and build the
>>         graph n+1
>>                  times. We
>>                       could also do some preliminary optimization of the
>> via
>>                  points based
>>                       on Euclidean distance using something like TSP
>> before
>>                  calling the
>>                       router.
>>                                          It would be great if someone
>>         could give
>>                  a general
>>                           idea
>>                           how  to go about learning more about the areas
>>                  mentioned  with
>>                           respect
>>                           to the organization's projects.Specially
>>         suggest those
>>                  ideas
>>                           which the
>>                           developers think are achievable for now . I
>>         will also
>>                  be grateful if
>>                           somebody can guide me regarding the development
>>                  framework of
>>                           pgrouting
>>                           so that i get familiar with the whole
>>         framework in the
>>                  coming days.
>>                       I would clone the github repository and look at
>> branch
>>                  sew-devel-2_0
>>                       this is our new tree structure and it has code,
>>         doc, and
>>                  test all
>>                       organized in a nice way that makes it easy to
>> multiple
>>                  contributors
>>                       work with the tree.
>>                       Ask questions, There is a tutorial floating around
>>         and lots of
>>                       people that are will to help.
>>                       -Steve
>>                           Thank you .
>>                           Mukul Priya
>>                           Lab for spatial Informatics
>>                           IIIT-Hyderabad
>>           ______________________________**_______________________
>>                           pgrouting-dev mailing list
>>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**
>> osgeo.org <pgrouting-dev at lists.osgeo.org>>
>>                  <mailto:pgrouting-dev at lists.__**osgeo.org<http://osgeo.org>
>>         <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>>         <mailto:pgrouting-dev at lists.>_**___osgeo.org <http://osgeo.org>
>>         http://lists.osgeo.org/______**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev>
>>         <http://lists.osgeo.org/____**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev>
>>         <http://lists.osgeo.org/__**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
>> **>__>
>>         <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>> **>__>__>
>> **>__>
>> **>__>__>
>>         <mailto:pgrouting-dev at lists.__**osgeo.org <http://osgeo.org>
>> **>__>
>> **>__>
>>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130414/ae791b3f/attachment-0001.html>
More information about the pgrouting-dev mailing list
