[pgrouting-dev] Gsoc 2013 Preliminary project proposal
Mukul priya
mukul2047 at gmail.com
Mon Apr 15 03:36:42 PDT 2013
Hi Steve ,
Just to clear things i would prefer item 2 ( partitioning
graph and then routing ) over item1 ( multi point routing ) .Its kind of
exciting and challenging too. what are your thoughts regarding this??
I went through the mail archive of previous years and it was
quite useful . For now i am trying to get familiar with the development
framework whenever i get time using this link (
https://github.com/pgRouting/pgrouting/wiki/Developer---Getting-Started).
Once i am done with my semester by 23rd of this month i will speed up
significantly.
Meanwhile feedbacks and suggestions are welcome.
Thanks
Mukul
On Sun, Apr 14, 2013 at 7:11 PM, Mukul priya <mukul2047 at gmail.com> wrote:
> Thanks for the reply Steve , clarifies all the issues that i raised ,
> Proposed data structures cover what we need , quad tree should work too ,
> I am right now looking into the last part which describes the method of
> appending our graph with new cells , seems fine and very much implementable
> , will post something in case some new ideas strike me . :)
> Thanks.
> On Sun, Apr 14, 2013 at 10:59 AM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> On 4/13/2013 11:12 PM, Mukul priya wrote:
>>> Thanks Steve for clearly mentioning the two proposals.
>>> For Item 1 , upgrading all the algorithms will certainly require a lot
>>> of work and since i will be having my summer vacation i don't have any
>>> issue with it :).
>>> For item 2 , i am looking into the idea that you have proposed , It is
>>> very much doable , there are however some concerns of mine like
>>> - how do we decide what should be the grid size . this can vary for
>>> suburban area and urban area based on netwrok density.
>> This might be done with a quad tree approach. You start with a square and
>> some condition like maximum number of node. If you exceed that number you
>> quarter it into 4 squares and divide the point into each of them.
>> - how do we classify the nodes lying on the junction of two or more
>>> grids . should it be assigned to all the grids??
>> A node can only lie in one square or the edge boundary of a square it
>> does not matter which one it is put in. Edges need to be flagged if the
>> cross a square boundary.
>> - how do we decide the grid that needs to be loaded in the memory ,
>>> connectivity with the previous grid seems legit here but i guess we need
>>> to discuss some corner cases too.
>> We could probably do something like
>> typedef struct pair {
>> int a;
>> int b;
>> } PAIR;
>> typedef struct edge_type {
>> int node_a;
>> int node_b;
>> PAIR *squares; // NULL if it does not cross square edge
>> float cost;
>> float rcost;
>> } EDGE;
>> Where PAIR can be assign the gridcell for the a and b ends.
>> If we number the grid cells by their quadtree numbers like:
>> | 1 | 2 |
>> | 3 | 4 |
>> So you start, with the above for your coverage area. So all nodes would
>> fall into cells 1-4. If you had to split cell 1 above, then those 4 new
>> cells would be number 11, 12, 13, 14 and the remaining unsplit cells would
>> still be 2, 3, 4. If you had to further split cell 14, then the new cells
>> would be numbered 141, 142, 143, 144. So each time a cell gets subdivided,
>> it gets another digit added.
>> This is the challenge of design good algorithms, if we have millions of
>> edges and node, we need to be efficient memory wise with our data
>> structures but still be fast. In the database, you need to think about
>> where the data is coming from (ie: tables using queries) and when it gets
>> moved into memory. You can't think just C code or database code, you have
>> to use both.
>> The idea being that we want to prepare our data in tables, then issue
>> queries from C to get the new edges we need to append cell(s) to our graph.
>> So I'm thinking that we have a recursive plpgsql procedure that splits the
>> nodes into the appropriate quadtree cells based on some rules. So for
>> example we have a vertices_tmp table that we use to assign node numbers to
>> nodes, we could add a cell column like this:
>> CREATE TABLE vertices_tmp
>> id serial NOT NULL,
>> cell bigint,
>> the_geom geometry,
>> and after we run the quadtree analysis each node is assigned a cell
>> number. The edge table has node_a and node_b assigned to it also.
>> If we want all edges related to cell 114 then we can do a query like:
>> select b.*
>> from vertices_tmp a, edges b
>> where a.cell=114 and (a.id=b.node_a or a.id=b.node.b);
>> Thoughts?
>> -Steve
>>> Thanks.
>>> On Sat, Apr 13, 2013 at 6:20 AM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>>> wrote:
>>> On 4/11/2013 3:24 PM, Mukul priya wrote:
>>> Hi Steve and Daniel,
>>> You suggested extending the present algorithms such
>>> that its
>>> input can take more points and not only the source and
>>> destination . i
>>> think this can be implemented and i will soon come up with
>>> implementation details( kind of more technical ) .
>>> Can you be a liitle bit more elaborate about
>>> partioning data
>>> into spatial chunks or even suggest some readings . I can then
>>> come up
>>> with some better ideas about implementing it.
>>> This is just me thinking out loud :)
>>> Lets say we construct a grid of one degree squares, you can
>>> visualize it by drawing a grid over your map.
>>> Then you can associate all the nodes with the grid they fall in. We
>>> might also need to associate edges to the grids also and an edge the
>>> crosses over a grid boundary might need to be associated with two
>>> grids. This could be done with some simple relational tables like:
>>> node_id|grid_id or edge_d|grid_id
>>> So my idea would be to do the routing like this:
>>> 1. get the start node or edge
>>> 2. build the graph based on loading the items in the related grid
>>> 3. mark the boundary nodes (we might want to do this when we grid
>>> them)
>>> 4. run the algorithm until we find the target node or hit a boundary
>>> node
>>> 5. on hitting a boundary:
>>> a. we check if the connected grid is loaded and continue if it is
>>> b. or we extent the graph with the new grid
>>> 6. continue with the routing
>>> We might want to be able to dynamically change the size of the grid
>>> cell based on the number of items in it. This would give us better
>>> performance when transitioning from rural areas into urban areas
>>> where there is a greater density of road segments. Think of a
>>> quadtree where we split it based on number of entities.
>>> Daniel , i took a look at the oracle link that you
>>> provided but
>>> there was no details about how it has been implemented , it was
>>> more
>>> about how one can use it. May be a bit more search and luck
>>> might
>>> take me to its implementation document :) .
>>> Right, it is useful if you look at the documentation and ask why did
>>> they do it that way and what does it imply about how it works behind
>>> the scenes.
>>> The other thing that you mentioned was about
>>> contraction
>>> Hierarchy . Still the nodes have to be ordered based on some
>>> criteria or
>>> according to their importance . We can use natural hierarchy
>>> present in
>>> the network for doing that .
>>> This is not related to what you proposed. It is an algorithm that
>>> does a lot of precompuation, that is LOTS in capitals, but it can
>>> get results in milliseconds for cross country routes.
>>> i will be really grateful if anyone can correct me
>>> in case if
>>> my thought process in not on the right lane and sorry for the
>>> late reply
>>> as my academic session is in progress too .Meanwhile i am
>>> trying to
>>> get fluent with git ,cmake and other tools.
>>> So read over our wiki:
>>> https://github.com/pgRouting/_**_pgrouting/wiki<https://github.com/pgRouting/__pgrouting/wiki>
>>> <https://github.com/pgRouting/**pgrouting/wiki<https://github.com/pgRouting/pgrouting/wiki>
>>> The way I see it at the moment there are two unrelated proposals on
>>> the table (I'm leaving out the contraction hierarchy):
>>> 1. multi point routing
>>> 2. partition JIT graph building while routing
>>> Item 1 is fairly trivial technically, I think, but if you were to
>>> upgrade all the algorithms to do this it would be a lot of work and
>>> a useful contribution to pgrouting.
>>> Item 2 is more of a design and code a new algorithm and you would
>>> probably want to focus on using astar or trsp algorithm to do this
>>> with. This one is more technically challenging and has more unknowns
>>> in it but I think it should be doable.
>>> If you are interested in reading about contraction hierarchies:
>>> https://www.google.com/#q=__**contraction<https://www.google.com/#q=__contraction>
>>> <https://www.google.com/#q=**contraction<https://www.google.com/#q=contraction>>
>>> hierarchies
>>> Thanks,
>>> -Steve
>>> Thanks .
>>> Mukul
>>> On Thu, Apr 11, 2013 at 6:47 PM, Stephen Woodbridge
>>> <mailto:woodbri at swoodbridge.__**com
>>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>>> wrote:
>>> With pgRouting, we do most things dynamically, here is the
>>> basic flow:
>>> 1. Given a collection of input, points, nodes, or edges
>>> map these to nodes or edges depending on algorithm.
>>> 2. Select the edges we need to build the graph
>>> 3. build the graph and solve it
>>> 4. return the results
>>> All our algorithms today only take start and end points.
>>> They could
>>> be extended to take points. Each "point" (I use "point" as
>>> a generic
>>> term because it might be a lat/lon, node id, edge id and
>>> offset,
>>> etc) would need to be mapped to the appropriate input need
>>> for any
>>> given algorithm.
>>> So for node based algorithms like Dijkstra,and astar it
>>> would get
>>> resolved to a node. For TRSP it would get mapped to the
>>> nearest edge
>>> and offset along that edge. Postgis has lots of handy tools
>>> for
>>> doing this.
>>> -Steve
>>> On 4/10/2013 10:50 PM, Mukul priya wrote:
>>> Thanks for the reply steve . i have already cloned the
>>> github
>>> repository
>>> and looking into various aspects of it .
>>> For IRNN querry implementation i think it is a good
>>> idea to sub
>>> divide
>>> the whole route and generate n+1 routes separately ,
>>> say from S
>>> to F1 ,
>>> F1-F2 ,..... F(n-1)-Fn , Fn to D . i wanted to know if
>>> we have
>>> that kind
>>> of a data where each and every facility is mentioned on
>>> the map as a
>>> point (node ) . even if it is not directly connected to
>>> the road
>>> network
>>> we can basically treat it a pseudo node and then call
>>> the router
>>> . The
>>> other thing about optimization yes we can do that using
>>> spatial
>>> range
>>> querries suppose there are several instances of the same
>>> facility that a
>>> user wants to access then we can use spatial range
>>> querries to
>>> locate
>>> that facility which is the nearest.
>>> On Thu, Apr 11, 2013 at 1:42 AM, Stephen Woodbridge
>>> <mailto:woodbri at swoodbridge.__**com <mailto:woodbri at swoodbridge.
>>> <mailto:woodbri at swoodbridge.>_**___com
>>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>>
>>> wrote:
>>> On 4/10/2013 3:23 PM, Mukul priya wrote:
>>> Hi ,
>>> Hi Mukul,
>>> Thank you for your interest in pgRouting.
>>> I am a B.tech fourth year
>>> student at
>>> IIIT-Hyderabad
>>> pursuing a degree in computer science and
>>> engineering
>>> and i will
>>> be soon
>>> pursuing a Masters Degree in the field of
>>> Spatial
>>> Informatics
>>> and the
>>> research topic that i have been working on is
>>> *"In
>>> route nearest
>>> neighbour querries".*
>>> Last year i worked on a project
>>> that was
>>> funded by
>>> Honeywell technology solutions and it gave me
>>> a lot of
>>> insight about
>>> open source programming and industrial work
>>> culture.
>>> I was introduced to pgrouting by *Prof.
>>> Venkatesh
>>> Raghavan* who
>>> visited
>>> our college last summer. i have also used
>>> pgrouting for
>>> implementing one
>>> of my Honors project.
>>> i have gone through the updated ideas page and
>>> i am
>>> listing out
>>> a topic
>>> that i feel i can contribute to.
>>> *Idea *
>>> Network Partitioning
>>> A very simple method using which it can be
>>> done is :
>>> * *Existence of a natural Hierarchy*
>>> Generally road networks are
>>> organized such
>>> that there
>>> is some
>>> natural hierarchy for example if we look at
>>> the road
>>> network of
>>> USA we
>>> observe that there are national highways which
>>> connect
>>> multiple
>>> large
>>> regions , inter state roads connect places
>>> within these
>>> regions
>>> , multi
>>> lane roads connect city areas and then there
>>> are small
>>> roads to
>>> connect
>>> individual houses.
>>> so what we can do is first rank
>>> these
>>> classes that
>>> constitute the road network and then use the
>>> highest
>>> level roads to
>>> divide the road network into large regions
>>> enclosed by
>>> these
>>> roads. each
>>> of the divided regions can further be divided
>>> again
>>> using next lower
>>> level road.
>>> so suppose we have a road network
>>> which n
>>> classes of
>>> different roads then we can create a tree of
>>> depth n-1
>>> where the
>>> root of
>>> the tree will represent the entire road
>>> network and
>>> children of
>>> the the
>>> root node will represent the area formed by
>>> partitioning the
>>> root using
>>> the level 1 ( highest ) edges and so on . the
>>> nodes
>>> will basically
>>> represent a smaller part of the road network.
>>> The idea seems to be very naive
>>> right now
>>> but if
>>> anyone can
>>> give some feedback whether it is achievable or
>>> not or
>>> may be suggest
>>> some modifications.
>>> Yes this is the basics of how this could work.
>>> Because we
>>> build our
>>> graphs dynamically for each route request, we can
>>> do
>>> something like
>>> this today. Typically you have to feed the route
>>> request
>>> and SQL
>>> query that provides the edges needed to build the
>>> graph and
>>> this can
>>> be simply the bounding box of the start and end
>>> point of
>>> the route
>>> expanded slightly to allow the route move outside
>>> that
>>> bounds by a
>>> little if needed. A case in point are start and
>>> end points
>>> that form
>>> a vertical of horizontal line.
>>> So for the natural hierarchy, you can for a SQL
>>> query like:
>>> select * from edges where st_dwithin(the_geom,
>>> start_pnt,
>>> radius)
>>> union
>>> end_pnt, radius)
>>> union
>>> select * from edges
>>> where st_expand(st_makeline(start___**____pnt,
>>> end_pnt), pct)
>>> and road_class < 4;
>>> So this gets all edges regardless of class at the
>>> start and
>>> end and
>>> then gets all the major roads and highways between
>>> the
>>> start and end
>>> points. We can dynamically select the edges that
>>> we want
>>> when we
>>> build the graph.
>>> Regardless of how you implement the routing, the
>>> problem is all
>>> about the data. If you have a road segment the is
>>> misqualified, you
>>> might end up with a network that is broken between
>>> start
>>> and end.
>>> This can alsoo happen if ramps are not coded
>>> correctly.
>>> One of the challenges we have today is that we
>>> have to be
>>> able to
>>> construct the whole graph in memory before we can
>>> start
>>> routing.
>>> This is ok for small areas but it is a problem if
>>> you want to
>>> generate a route between say Miami, Florida and
>>> Seattle,
>>> Washington.
>>> An interesting problem would be the ability to
>>> partition
>>> the data in
>>> spatial chucks and only load them as the solver
>>> needed them.
>>> If you think about your edges sorted into say 1
>>> degree grid
>>> partitions,
>>> then you load the partition for the start point
>>> and start
>>> routing
>>> using A* search, when you frontier get to an edge
>>> of the
>>> grid you
>>> are in, then you load the adjacent grid and
>>> continue, if
>>> you bump
>>> into another grid boundary that is not loaded yet,
>>> you
>>> load, if it
>>> is already loaded you continue. Anyway food for
>>> thought! :)
>>> In route nearest neighbour
>>> querries(
>>> IRNN) which
>>> handle
>>> querries like computation of shortest path ,
>>> provided
>>> that the user
>>> wants to visit facilities F1 , F2 ,.....FN
>>> while he/she
>>> drives
>>> or walks
>>> from source to destination. Network
>>> partitioning can
>>> optimize these
>>> computations too as the search space reduces
>>> significantly once
>>> we have
>>> the partitions. Handling such querries have
>>> not been
>>> implemented
>>> yet. It
>>> will be very helpful if we can have some
>>> discussion
>>> about whether
>>> implementing it is feasible or not.
>>> What is we just added via support to routing? Then
>>> we could do
>>> something like say generate a route: Start, F1,
>>> F2, ... Fn, End
>>> This would allow us to build a graph one time and
>>> then generate
>>> multiple sub-routes with in the graph. Today if
>>> you want to
>>> do that
>>> you have to generate n+1 routes and build the
>>> graph n+1
>>> times. We
>>> could also do some preliminary optimization of the
>>> via
>>> points based
>>> on Euclidean distance using something like TSP
>>> before
>>> calling the
>>> router.
>>> It would be great if someone
>>> could give
>>> a general
>>> idea
>>> how to go about learning more about the areas
>>> mentioned with
>>> respect
>>> to the organization's projects.Specially
>>> suggest those
>>> ideas
>>> which the
>>> developers think are achievable for now . I
>>> will also
>>> be grateful if
>>> somebody can guide me regarding the development
>>> framework of
>>> pgrouting
>>> so that i get familiar with the whole
>>> framework in the
>>> coming days.
>>> I would clone the github repository and look at
>>> branch
>>> sew-devel-2_0
>>> this is our new tree structure and it has code,
>>> doc, and
>>> test all
>>> organized in a nice way that makes it easy to
>>> multiple
>>> contributors
>>> work with the tree.
>>> Ask questions, There is a tutorial floating around
>>> and lots of
>>> people that are will to help.
>>> -Steve
>>> Thank you .
>>> Mukul Priya
>>> Lab for spatial Informatics
>>> IIIT-Hyderabad
>>> ______________________________**_______________________
>>> pgrouting-dev mailing list
>>> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**
>>> osgeo.org <pgrouting-dev at lists.osgeo.org>>
>>> <mailto:pgrouting-dev at lists.__**osgeo.org<http://osgeo.org>
>>> <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>>> <mailto:pgrouting-dev at lists.>_**___osgeo.org <http://osgeo.org>
>>> http://lists.osgeo.org/______**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev>
>>> <http://lists.osgeo.org/____**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev>
>>> <http://lists.osgeo.org/__**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
>>> **>__>
>>> <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>> **>__>__>
>>> **>__>
>>> **>__>__>
>>> <mailto:pgrouting-dev at lists.__**osgeo.org <http://osgeo.org>
>>> **>__>
>>> **>__>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130415/710bb44b/attachment-0001.html>
More information about the pgrouting-dev
