[pgrouting-dev] KSP integration into sew-devel-2_0 branch
Stephen Woodbridge woodbri at swoodbridge.com
Fri Apr 19 22:06:03 PDT 2013
Just checked in the tests for KSP, and it runs great on Linux, pg 9.2,
postgis 2.0.3.
Dave Potts - thank you for your work on this, it is a great addition.
Check out 2.0 and KSP, let me know if there are issues with anything.
Any help on the other issues would be appreciated.
Thanks,
   -Steve
On 4/19/2013 8:14 PM, Stephen Woodbridge wrote:
> Hi all,
> I have integrated the KSP code into sew-devel-2_0 branch. I still have
> to update the tests to work in this tree. Which means that it has not
> been tested at all yet, beyond compiling. It also throws a bunch of
> errors, on pg 8.3 which I'm sure most people to not care about, but it
> happens to be what I run on some of my servers. I've asked Dave Potts to
> look at it and a warning to see if he has any ideas.
> To be more specific I have on tried these:
>    pg 8.3 Linux fails to compile
>    pg 9.2 Linux compiles
> I'll try it on MinGW at some point.
> I hope Dave will try on MSVC or whatever he runs.
> I have also taken the first steps toward removing shooting_star from
> this branch and the 2.0 tree. As you know, or should know, by now, it is
> severely broken and we don't have anyone that understands the code here.
> And the TRSP code provides all the functionality and more and is much
> faster.
> So give it a try.
> Thanks,
>    -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
