[pgrouting-dev] Gsoc 2013
Mukul priya mukul2047 at gmail.com
Sat Apr 27 03:29:58 PDT 2013
Hi steve , i have edited my proposal based on our previous discussion (
added some lines about Astar) .meanwhile do suggest if there is scope of
some improvement .
Thanks
Mukul
On Thu, Apr 25, 2013 at 11:22 PM, Mukul priya <mukul2047 at gmail.com> wrote:
> Thanks Steve will add a few lines to my proposal explaining the reason
> behind opting Astar.
> Mukul
> On Thu, Apr 25, 2013 at 8:55 PM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> On 4/25/2013 11:06 AM, Mukul priya wrote:
>>> How much of the network do you have to explore using each algorithm?
>>> This will be reduced significantly while using Astar as we will have a
>>> fair bit of idea about the direction towards which we should proceed.
>>> How does this impact the number of grids you have to load?
>>> Once we have an idea about the direction towards which we should proceed
>>> , only those grids will be loaded. This will result in loading of less
>>> number of grids.
>>> How does this impact your proposal?
>>> The basic motivation behind the proposal is to make shortest path
>>> computation faster. Number of database querry will be reduced as we will
>>> be fetching lesser number of grids. This will have a positive effect on
>>> computation time.
>> Right, so in your proposal, you want to be clear that the benefit will be
>> achieved using astar or another algorithm with a heuristic and not
>> dijkstra. I understand that "shortest path" is a generic reference to all
>> of these algorithms, but the only ones that will benefit from this approach
>> will be ones with a heuristic that allow us to explore only a subset the
>> overall bounding box of edges that we might otherwise use as input. So it
>> is best to be clear on these points.
>> -Steve
>>  On Thu, Apr 25, 2013 at 7:07 PM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>>> wrote:
>>>     On 4/25/2013 12:26 AM, Mukul priya wrote:
>>>         Thanks Steve ,I am familar with astar ,It uses a heuristic to
>>> guide
>>>         itself to the destination, there was huge focus on it in our
>>>         game theory
>>>         course.
>>>         Although do point out the advantages it has in real life road
>>>         network
>>>         and its importance to my proposal.
>>>     -Steve
>>>         On Thu, Apr 25, 2013 at 7:43 AM, Stephen Woodbridge
>>>         <mailto:woodbri at swoodbridge.__**com
>>>         <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>>> wrote:
>>>              Hi Mukul,
>>>              This is a good write up. It largely mirrors out discussion.
>>> One
>>>              thing that needs to change in this is that dijkstra should
>>> be
>>>              replaced with astar.
>>>              Are you familiar with how these are different?
>>>         http://theory.stanford.edu/~__**__amitp/GameProgramming/____**
>>> AStarComparison.html<http://theory.stanford.edu/~____amitp/GameProgramming/____AStarComparison.html>
>>>         <http://theory.stanford.edu/%**7E__amitp/GameProgramming/__**
>>> AStarComparison.html<http://theory.stanford.edu/%7E__amitp/GameProgramming/__AStarComparison.html>
>>>         <http://theory.stanford.edu/%_**_7Eamitp/GameProgramming/__**
>>>         <http://theory.stanford.edu/%**7Eamitp/GameProgramming/**
>>> AStarComparison.html<http://theory.stanford.edu/%7Eamitp/GameProgramming/AStarComparison.html>
>>>              Do you see why? and specifically why it matter for this
>>>         project?
>>>              -Steve
>>>              On 4/24/2013 9:10 PM, Mukul priya wrote:
>>>                  ***Name*:Mukul Priya
>>>                  *Country:*India
>>>                  *School and degree*: International Institute Of
>>> Information
>>>                  Technology-Hyderabad ,
>>>                                                   B.Tech + Masters in
>>>         computer
>>>                  Science And
>>>                  Engineering
>>>                  *Email*:mukul2047 at gmail.com
>>>         <mailto:mukul2047 at gmail.com> <mailto:mukul2047 at gmail.com
>>>         <mailto:mukul2047 at gmail.com>>
>>>         <mailto:mukul2047 at gmail.com>>>
>>>                  *Phone*:+91 9885991061
>>>                  *OSGeo project(s*):pgRouting
>>>                  *Title:* A partitioned approach to on demand increment
>>>         graph
>>>                  assembly
>>>                  for pgRouting.
>>>                  *Describe your idea*
>>>                  *1. Introduction*
>>>                           pgRouting has been working towards providing
>>>         routing
>>>                  functionality on a PostGis/PostgreSql  Geo spatial
>>>                      database. It already has support for shortest path
>>>         algorithm
>>>                  like
>>>                  astar ,dijkstra , tdsp and trsp .But for a very
>>>                      large network, routing becomes time consuming.
>>> Network
>>>                  partitioning
>>>                  is one such way which can prove to
>>>                      be helpful in improving the overall time efficiency
>>>         of routing
>>>                  querries. The main idea  here is to first partition
>>>                      the whole network using a Quad tree approach and
>>>         when the
>>>                  shortest
>>>                  path is computed these partitions are
>>>                      loaded on demand. hence , there is an on demand
>>>         incremental
>>>                  graph
>>>                  generation.
>>>                           The project aims at designing and implementing
>>> a
>>>                  Shortest Path
>>>                  algorithm on an on demand incremental
>>>                        Graph using a network partitioning approach.
>>>                  *2. Background*
>>>                           Considering the present status where pgRouting
>>> has
>>>                  support for
>>>                  shortest path algorithm like astar etc.
>>>                     Looking at their implementation details we can
>>>         observe that
>>>                  the graph
>>>                  is configured dynamically for all
>>>                     of them before computation.My proposal will also be
>>>         on the
>>>                  same track
>>>                  and for very large networks
>>>                     where  the distance between source and destination
>>>         can be
>>>                  very large ,
>>>                  the response time will be
>>>                     significantly lesser and memory wise too it will be
>>>         lot more
>>>                  efficient. Presently they don't use any partitioning
>>>                     approach so it will prove to be a good addition to
>>> their
>>>                  support for
>>>                  shortest past algorithms.
>>>                  *3. The idea*
>>>                       There are two major components of my idea .
>>>                       *Network Partitioning*
>>>                           For this part we can use a quad tree approach.
>>>         Say , we
>>>                  start
>>>                  with a square and a condition like maximum
>>>                           number of nodes that can reside in a square .
>>>         if the
>>>                  number of
>>>                  nodes in the square is greater than the max
>>>                           condition we further quarter it into four
>>>         squares and
>>>                  allot the
>>>                  nodes appropriately to each of them.All these
>>>                           squares can be called grids and they all will
>>>         be addressed
>>>                  uniquely using a grid cell number .Each node
>>>                           will be assigned a grid cell number based on
>>>         the grid
>>>                  they are
>>>                  lying inside.
>>>                                  We will have data structures to address
>>>         edges as
>>>                  they can
>>>                  remain contained in either one grid cell
>>>                            or span across a number of grid cells.the
>>>         idea is to
>>>                  first flag
>>>                  such edges and store the grid cell numbers
>>>                            of the grids that the edge crosses/intersects.
>>>                       *On demand graph generation and Routing.*
>>>                                   The idea here is to first identify the
>>>         grid cell
>>>                  initially and then fetch the edges that are associated
>>> with
>>>                           that grid. These are the edges that will get
>>>         appended
>>>                  to the
>>>                  present graph and the graph will keep growing
>>>                           dynamically this way. we will have appropriate
>>>         database
>>>                  tables
>>>                  addressing the above issue such that
>>>                           we are able to fetch the required edges
>>>         quickly using  a
>>>                  database querry.
>>>                            The implementation details for the above are :
>>>                           we will first partition the whole graph using
>>>         the quad tree
>>>                  approach and each node/vertex will be assigned
>>>                           a grid cell number so we can have  database
>>>         table for the
>>>                  assigned nodes and edges like :
>>>                           CREATE TABLE vertex{
>>>                            id Node_id                               \\
>>>           unique
>>>                  for each
>>>                  node.
>>>                            cell grid_cell_number;               \\ the
>>>         grid in
>>>                  which the
>>>                  node lies.
>>>                             geometry;
>>>                             CREATE TABLE edge  {
>>>                              int id ;
>>>                              Int node_a;
>>>                               int node_b;        \\ the connecting nodes
>>>                        //     we can have other parameters like
>>>         traversal cost
>>>                  and return
>>>                  cost.
>>>                              using the tables we can then fetch the
>>>         edges form
>>>                  edge table
>>>                     using simple database querry once
>>>                     we are provided with the grid cell number very
>>> easily.
>>>                     In short the summary of the whole idea is :
>>>                  Step1: Fetch the start node , get the related Grid cell
>>>         number.
>>>                  Step 2: Increment the graph by fetching all the items
>>>         related to
>>>                  that grid.
>>>                  Step3 : Check for boundary nodes  ( this is done while
>>>         we are
>>>                  partitioning) or target node .
>>>                  Step 4: On hitting a boundary node
>>>                                     check if the connected grid is
>>>         loaded and
>>>                  continue if
>>>                  it is
>>>                                     or we extend the graph with the new
>>>         grid and
>>>                  continue
>>>                  with the routing;
>>>                               or On hitting the target Node
>>>                                            stop;
>>>                  *4. Project plan*
>>>                         I will have about 12 weeks to implement the
>>>         project. The
>>>                  tentative
>>>                  schedule is as follows:
>>>                         Before 17th June : Get familiar with the
>>> development
>>>                  environment
>>>                  of pgRouting and test some demos.
>>>                         week 1-2: Discuss and Define the various data
>>>         structures
>>>                  and data
>>>                  table that will be required.Prepare the
>>>                                         Overall implementation
>>>           architecture.
>>>                         week 3-4-  Discuss and Implement network
>>>         partitioning
>>>                  using quad
>>>                  tree.
>>>                         week 5-8 -Start coding for on demand graph
>>>         generation and
>>>                  routing
>>>                  using Dijkstra. In between Prepare mid-term
>>>                                           report.
>>>                         week 9 - Integration with pgrouting .
>>>                         week 10-12- Testing and Bug fixing. Draft Final
>>>         report and
>>>                  documentation.
>>>                     5. Future ideas / How can your idea be expanded? *
>>>                          It can be integrated with other shortest path
>>>         algorithms
>>>                  like
>>>                  astar etc. which pgrouitng provides.For time dependent
>>>                        shortest path computation, it will greatly reduce
>>> the
>>>                  updating cost
>>>                  as we will be updating the cost of only those edges
>>>                        that are contained in the grid cells that are
>>> loaded.
>>>                         In route nearest neigbour querries can also be
>>>                  implemented using
>>>                  the partitioning approach.Overall we can
>>>                         expand this approach to various other algorithms.
>>>                  *Explain how your SoC task would benefit the OSGeo
>>> member
>>>                  project and
>>>                  more generally the OSGeo Foundation as a whole:*
>>>                        The proposed idea will significantly improve the
>>>                  performance of
>>>                  shortest path finding algorithms.This will have a
>>>                      positive effect on the user base of pgRouting. For
>>>         various
>>>                  software
>>>                  paltforms or applications that are using this library ,
>>>                      the response time will significantly improve.
>>>                  Please provide details of general computing experience:
>>>                  I generally use ubuntu ( 12.04) for all my academic
>>>         purposes and
>>>                  windows
>>>                  7 for entertainment only. I am familiar with Fedora
>>> also.
>>>                  C++ is the language that i use most ( programming
>>>         purposes). For
>>>                  implementing various  course projects i have used C++
>>>         ,python
>>>                  ,Java and
>>>                  matlab.
>>>                  I have no experience with hardware. The only experience
>>>         that i
>>>                  had with
>>>                  networking was during my computer network course.
>>>                  Please provide details of previous GIS experience:*
>>>                  I am a part of "Lab for Spatial Informatics" which is
>>>         the only
>>>                  lab in
>>>                  India devoted to GIS applications and learning. I am
>>>         familiar
>>>                  with and
>>>                  have used almost all the open source GIS platforms like
>>>         Quantum ,
>>>                  OpenJump, ILwis,Grass.  We have our own rendering
>>>         platform that was
>>>                  developed by our lab.(LSI viewer)
>>>                  *Please provide details of any previous involvement
>>>         with GIS
>>>                  programming
>>>                  and other software programming:*
>>>                  I am very much familiar with Gdal/OGR  as i used it
>>>         extensively
>>>                  while
>>>                  implementing an outsourced project of Honeywell
>>>                  Technology . I have played a lot with ESRI shape files.
>>>                  *Please tell us why you are interested in GIS and open
>>>         source
>>>                  software:*
>>>                  I was very impressed with google earth when it was
>>>         launched way
>>>                  back in
>>>                  2004.GIS platforms like quantum and Openjump were
>>>         introduced  to
>>>                  me when
>>>                  i was in my second year and then i joined Lab for
>>> spatial
>>>                  informatics
>>>                  that is in our college based on my interest in this
>>> area.
>>>                  open source platforms provide an opportunity to learn .
>>>         The best
>>>                  part is
>>>                  you can always create or develop something that you are
>>>                  interested in
>>>                  and there are people who will always be there to help
>>>         you if you
>>>                  are stuck.
>>>                  Please tell us why you are interested in working for
>>>         OSGeo and the
>>>                  software project you have selected:*
>>>                  It will be huge learning experience  since i have been
>>>         using
>>>                  platforms
>>>                  like Qgis , Gdal ,PostGis etc which come under Osgeo
>>>                  I chose pgrouting because the algorithms that they have
>>>                  implemented are
>>>                  related to my masters topic and it will be great if i
>>>         get an insight
>>>                  about how these were implemented on a much larger scale.
>>>                  *Please tell us why you are interested in your specific
>>>         coding
>>>                  project:*
>>>                  Implementing routing algorithms for real world networks
>>> is
>>>                  actually very
>>>                  challenging.its a challenge to come up with good
>>>         approaches so
>>>                  that the
>>>                  computation cost and response time is both reduced.
>>>                  *Would your application contribute to your ongoing
>>>                  studies/degree? If
>>>                  so, how?*
>>>                  I am pursuing my Masters and my topic is closely
>>>         related to my
>>>                  proposal
>>>                  . If the results are impressive , i might get a
>>>         publication in
>>>                  this area.
>>>                  *Please explain how you intend to continue being an
>>>         active member of
>>>                  your project and/or OSGeo AFTER the summer is over:*
>>>                  I was always interested in open source programming but
>>>         never
>>>                  knew where
>>>                  to start . GSOC  provides an opportunity for beginners
>>>         like me
>>>                  to take a
>>>                  dive in the area  open source programming. i have other
>>>         ideas like
>>>                  implementing IRNN ( In route nearest neighbour
>>>         querries) which
>>>                  can be
>>>                  implemented within pgRouting.I have other intentions
>>> like
>>>                  working for
>>>                  bigger projects like Quantum Gis or Grass.I will be
>>>         contributing
>>>                  to the
>>>                  community forum and will always try to improve things.
>>>                  *Do you understand this is a serious commitment,
>>>         equivalent to a
>>>                  full-time paid summer internship or summer job?*
>>>                  Yes, I understand that this is a serious commitment and
>>>         will try
>>>                  to give
>>>                  my best and work in a professional manner.
>>>                  *Do you have any known time conflicts during the
>>>         official coding
>>>                  period?
>>>                  (June 17 to Sept. 27)*
>>>                  No .
>>>                  On Thu, Apr 25, 2013 at 12:47 AM, Stephen Woodbridge
>>>         <mailto:woodbri at swoodbridge.__**com <mailto:woodbri at swoodbridge.
>>>         <mailto:woodbri at swoodbridge.>_**___com
>>>         <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>>
>>> wrote:
>>>                       On 4/24/2013 2:34 PM, Mukul priya wrote:
>>>                           Hi Steve and Daniel ,
>>>                           I have posted my proposal on Melange Gsoc
>>>         system. Do
>>>                  have a look
>>>                           at it.
>>>                           Waiting for feedback and suggestions.
>>>                       Can you post a link to your proposal? or the text
>>>         of it
>>>                  here also. I
>>>                       can never find anything in Melange or I may not
>>> have
>>>                  visibility to
>>>                       it yet as I just applied as a mentor.
>>>                       Thanks,
>>>                          -Steve
>>>                       ______________________________**
>>>                       pgrouting-dev mailing list
>>>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**
>>> osgeo.org <pgrouting-dev at lists.osgeo.org>>
>>>                  <mailto:pgrouting-dev at lists.__**osgeo.org<http://osgeo.org>
>>>         <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>>>         <mailto:pgrouting-dev at lists.>_**___osgeo.org <http://osgeo.org>
>>>         http://lists.osgeo.org/______**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev>
>>>         <http://lists.osgeo.org/____**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev>
>>>         <http://lists.osgeo.org/__**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
>>> **>__>
>>>         <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>> **>__>__>
>>>                  ______________________________**_____________________
>>>         <mailto:pgrouting-dev at lists.__**osgeo.org <http://osgeo.org>
>>> **>__>
>>> **>__>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130427/ccb39d3a/attachment-0001.html>
More information about the pgrouting-dev mailing list
