[pgrouting-dev] Gsoc 2013
Mukul priya mukul2047 at gmail.com
Thu Apr 25 10:52:49 PDT 2013
Thanks Steve will add a few lines to my proposal explaining the reason
behind opting Astar.
Mukul
On Thu, Apr 25, 2013 at 8:55 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 4/25/2013 11:06 AM, Mukul priya wrote:
>> How much of the network do you have to explore using each algorithm?
>> This will be reduced significantly while using Astar as we will have a
>> fair bit of idea about the direction towards which we should proceed.
>> How does this impact the number of grids you have to load?
>> Once we have an idea about the direction towards which we should proceed
>> , only those grids will be loaded. This will result in loading of less
>> number of grids.
>> How does this impact your proposal?
>> The basic motivation behind the proposal is to make shortest path
>> computation faster. Number of database querry will be reduced as we will
>> be fetching lesser number of grids. This will have a positive effect on
>> computation time.
> Right, so in your proposal, you want to be clear that the benefit will be
> achieved using astar or another algorithm with a heuristic and not
> dijkstra. I understand that "shortest path" is a generic reference to all
> of these algorithms, but the only ones that will benefit from this approach
> will be ones with a heuristic that allow us to explore only a subset the
> overall bounding box of edges that we might otherwise use as input. So it
> is best to be clear on these points.
> -Steve
>  On Thu, Apr 25, 2013 at 7:07 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>> wrote:
>>     On 4/25/2013 12:26 AM, Mukul priya wrote:
>>         Thanks Steve ,I am familar with astar ,It uses a heuristic to
>> guide
>>         itself to the destination, there was huge focus on it in our
>>         game theory
>>         course.
>>         Although do point out the advantages it has in real life road
>>         network
>>         and its importance to my proposal.
>>     -Steve
>>         On Thu, Apr 25, 2013 at 7:43 AM, Stephen Woodbridge
>>         <mailto:woodbri at swoodbridge.__**com
>>         <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>> wrote:
>>              Hi Mukul,
>>              This is a good write up. It largely mirrors out discussion.
>> One
>>              thing that needs to change in this is that dijkstra should be
>>              replaced with astar.
>>              Are you familiar with how these are different?
>>         http://theory.stanford.edu/~__**__amitp/GameProgramming/____**
>> AStarComparison.html<http://theory.stanford.edu/~____amitp/GameProgramming/____AStarComparison.html>
>>         <http://theory.stanford.edu/%**7E__amitp/GameProgramming/__**
>> AStarComparison.html<http://theory.stanford.edu/%7E__amitp/GameProgramming/__AStarComparison.html>
>>         <http://theory.stanford.edu/%_**_7Eamitp/GameProgramming/__**
>>         <http://theory.stanford.edu/%**7Eamitp/GameProgramming/**
>> AStarComparison.html<http://theory.stanford.edu/%7Eamitp/GameProgramming/AStarComparison.html>
>>              Do you see why? and specifically why it matter for this
>>         project?
>>              -Steve
>>              On 4/24/2013 9:10 PM, Mukul priya wrote:
>>                  ***Name*:Mukul Priya
>>                  *Country:*India
>>                  *School and degree*: International Institute Of
>> Information
>>                  Technology-Hyderabad ,
>>                                                   B.Tech + Masters in
>>         computer
>>                  Science And
>>                  Engineering
>>                  *Email*:mukul2047 at gmail.com
>>         <mailto:mukul2047 at gmail.com> <mailto:mukul2047 at gmail.com
>>         <mailto:mukul2047 at gmail.com>>
>>         <mailto:mukul2047 at gmail.com>>>
>>                  *Phone*:+91 9885991061
>>                  *OSGeo project(s*):pgRouting
>>                  *Title:* A partitioned approach to on demand increment
>>         graph
>>                  assembly
>>                  for pgRouting.
>>                  *Describe your idea*
>>                  *1. Introduction*
>>                           pgRouting has been working towards providing
>>         routing
>>                  functionality on a PostGis/PostgreSql  Geo spatial
>>                      database. It already has support for shortest path
>>         algorithm
>>                  like
>>                  astar ,dijkstra , tdsp and trsp .But for a very
>>                      large network, routing becomes time consuming.
>> Network
>>                  partitioning
>>                  is one such way which can prove to
>>                      be helpful in improving the overall time efficiency
>>         of routing
>>                  querries. The main idea  here is to first partition
>>                      the whole network using a Quad tree approach and
>>         when the
>>                  shortest
>>                  path is computed these partitions are
>>                      loaded on demand. hence , there is an on demand
>>         incremental
>>                  graph
>>                  generation.
>>                           The project aims at designing and implementing a
>>                  Shortest Path
>>                  algorithm on an on demand incremental
>>                        Graph using a network partitioning approach.
>>                  *2. Background*
>>                           Considering the present status where pgRouting
>> has
>>                  support for
>>                  shortest path algorithm like astar etc.
>>                     Looking at their implementation details we can
>>         observe that
>>                  the graph
>>                  is configured dynamically for all
>>                     of them before computation.My proposal will also be
>>         on the
>>                  same track
>>                  and for very large networks
>>                     where  the distance between source and destination
>>         can be
>>                  very large ,
>>                  the response time will be
>>                     significantly lesser and memory wise too it will be
>>         lot more
>>                  efficient. Presently they don't use any partitioning
>>                     approach so it will prove to be a good addition to
>> their
>>                  support for
>>                  shortest past algorithms.
>>                  *3. The idea*
>>                       There are two major components of my idea .
>>                       *Network Partitioning*
>>                           For this part we can use a quad tree approach.
>>         Say , we
>>                  start
>>                  with a square and a condition like maximum
>>                           number of nodes that can reside in a square .
>>         if the
>>                  number of
>>                  nodes in the square is greater than the max
>>                           condition we further quarter it into four
>>         squares and
>>                  allot the
>>                  nodes appropriately to each of them.All these
>>                           squares can be called grids and they all will
>>         be addressed
>>                  uniquely using a grid cell number .Each node
>>                           will be assigned a grid cell number based on
>>         the grid
>>                  they are
>>                  lying inside.
>>                                  We will have data structures to address
>>         edges as
>>                  they can
>>                  remain contained in either one grid cell
>>                            or span across a number of grid cells.the
>>         idea is to
>>                  first flag
>>                  such edges and store the grid cell numbers
>>                            of the grids that the edge crosses/intersects.
>>                       *On demand graph generation and Routing.*
>>                                   The idea here is to first identify the
>>         grid cell
>>                  initially and then fetch the edges that are associated
>> with
>>                           that grid. These are the edges that will get
>>         appended
>>                  to the
>>                  present graph and the graph will keep growing
>>                           dynamically this way. we will have appropriate
>>         database
>>                  tables
>>                  addressing the above issue such that
>>                           we are able to fetch the required edges
>>         quickly using  a
>>                  database querry.
>>                            The implementation details for the above are :
>>                           we will first partition the whole graph using
>>         the quad tree
>>                  approach and each node/vertex will be assigned
>>                           a grid cell number so we can have  database
>>         table for the
>>                  assigned nodes and edges like :
>>                           CREATE TABLE vertex{
>>                            id Node_id                               \\
>>           unique
>>                  for each
>>                  node.
>>                            cell grid_cell_number;               \\ the
>>         grid in
>>                  which the
>>                  node lies.
>>                             geometry;
>>                             CREATE TABLE edge  {
>>                              int id ;
>>                              Int node_a;
>>                               int node_b;        \\ the connecting nodes
>>                        //     we can have other parameters like
>>         traversal cost
>>                  and return
>>                  cost.
>>                              using the tables we can then fetch the
>>         edges form
>>                  edge table
>>                     using simple database querry once
>>                     we are provided with the grid cell number very easily.
>>                     In short the summary of the whole idea is :
>>                  Step1: Fetch the start node , get the related Grid cell
>>         number.
>>                  Step 2: Increment the graph by fetching all the items
>>         related to
>>                  that grid.
>>                  Step3 : Check for boundary nodes  ( this is done while
>>         we are
>>                  partitioning) or target node .
>>                  Step 4: On hitting a boundary node
>>                                     check if the connected grid is
>>         loaded and
>>                  continue if
>>                  it is
>>                                     or we extend the graph with the new
>>         grid and
>>                  continue
>>                  with the routing;
>>                               or On hitting the target Node
>>                                            stop;
>>                  *4. Project plan*
>>                         I will have about 12 weeks to implement the
>>         project. The
>>                  tentative
>>                  schedule is as follows:
>>                         Before 17th June : Get familiar with the
>> development
>>                  environment
>>                  of pgRouting and test some demos.
>>                         week 1-2: Discuss and Define the various data
>>         structures
>>                  and data
>>                  table that will be required.Prepare the
>>                                         Overall implementation
>>           architecture.
>>                         week 3-4-  Discuss and Implement network
>>         partitioning
>>                  using quad
>>                  tree.
>>                         week 5-8 -Start coding for on demand graph
>>         generation and
>>                  routing
>>                  using Dijkstra. In between Prepare mid-term
>>                                           report.
>>                         week 9 - Integration with pgrouting .
>>                         week 10-12- Testing and Bug fixing. Draft Final
>>         report and
>>                  documentation.
>>                     5. Future ideas / How can your idea be expanded? *
>>                          It can be integrated with other shortest path
>>         algorithms
>>                  like
>>                  astar etc. which pgrouitng provides.For time dependent
>>                        shortest path computation, it will greatly reduce
>> the
>>                  updating cost
>>                  as we will be updating the cost of only those edges
>>                        that are contained in the grid cells that are
>> loaded.
>>                         In route nearest neigbour querries can also be
>>                  implemented using
>>                  the partitioning approach.Overall we can
>>                         expand this approach to various other algorithms.
>>                  *Explain how your SoC task would benefit the OSGeo member
>>                  project and
>>                  more generally the OSGeo Foundation as a whole:*
>>                        The proposed idea will significantly improve the
>>                  performance of
>>                  shortest path finding algorithms.This will have a
>>                      positive effect on the user base of pgRouting. For
>>         various
>>                  software
>>                  paltforms or applications that are using this library ,
>>                      the response time will significantly improve.
>>                  Please provide details of general computing experience:
>>                  I generally use ubuntu ( 12.04) for all my academic
>>         purposes and
>>                  windows
>>                  7 for entertainment only. I am familiar with Fedora also.
>>                  C++ is the language that i use most ( programming
>>         purposes). For
>>                  implementing various  course projects i have used C++
>>         ,python
>>                  ,Java and
>>                  matlab.
>>                  I have no experience with hardware. The only experience
>>         that i
>>                  had with
>>                  networking was during my computer network course.
>>                  Please provide details of previous GIS experience:*
>>                  I am a part of "Lab for Spatial Informatics" which is
>>         the only
>>                  lab in
>>                  India devoted to GIS applications and learning. I am
>>         familiar
>>                  with and
>>                  have used almost all the open source GIS platforms like
>>         Quantum ,
>>                  OpenJump, ILwis,Grass.  We have our own rendering
>>         platform that was
>>                  developed by our lab.(LSI viewer)
>>                  *Please provide details of any previous involvement
>>         with GIS
>>                  programming
>>                  and other software programming:*
>>                  I am very much familiar with Gdal/OGR  as i used it
>>         extensively
>>                  while
>>                  implementing an outsourced project of Honeywell
>>                  Technology . I have played a lot with ESRI shape files.
>>                  *Please tell us why you are interested in GIS and open
>>         source
>>                  software:*
>>                  I was very impressed with google earth when it was
>>         launched way
>>                  back in
>>                  2004.GIS platforms like quantum and Openjump were
>>         introduced  to
>>                  me when
>>                  i was in my second year and then i joined Lab for spatial
>>                  informatics
>>                  that is in our college based on my interest in this area.
>>                  open source platforms provide an opportunity to learn .
>>         The best
>>                  part is
>>                  you can always create or develop something that you are
>>                  interested in
>>                  and there are people who will always be there to help
>>         you if you
>>                  are stuck.
>>                  Please tell us why you are interested in working for
>>         OSGeo and the
>>                  software project you have selected:*
>>                  It will be huge learning experience  since i have been
>>         using
>>                  platforms
>>                  like Qgis , Gdal ,PostGis etc which come under Osgeo
>>                  I chose pgrouting because the algorithms that they have
>>                  implemented are
>>                  related to my masters topic and it will be great if i
>>         get an insight
>>                  about how these were implemented on a much larger scale.
>>                  *Please tell us why you are interested in your specific
>>         coding
>>                  project:*
>>                  Implementing routing algorithms for real world networks
>> is
>>                  actually very
>>                  challenging.its a challenge to come up with good
>>         approaches so
>>                  that the
>>                  computation cost and response time is both reduced.
>>                  *Would your application contribute to your ongoing
>>                  studies/degree? If
>>                  so, how?*
>>                  I am pursuing my Masters and my topic is closely
>>         related to my
>>                  proposal
>>                  . If the results are impressive , i might get a
>>         publication in
>>                  this area.
>>                  *Please explain how you intend to continue being an
>>         active member of
>>                  your project and/or OSGeo AFTER the summer is over:*
>>                  I was always interested in open source programming but
>>         never
>>                  knew where
>>                  to start . GSOC  provides an opportunity for beginners
>>         like me
>>                  to take a
>>                  dive in the area  open source programming. i have other
>>         ideas like
>>                  implementing IRNN ( In route nearest neighbour
>>         querries) which
>>                  can be
>>                  implemented within pgRouting.I have other intentions like
>>                  working for
>>                  bigger projects like Quantum Gis or Grass.I will be
>>         contributing
>>                  to the
>>                  community forum and will always try to improve things.
>>                  *Do you understand this is a serious commitment,
>>         equivalent to a
>>                  full-time paid summer internship or summer job?*
>>                  Yes, I understand that this is a serious commitment and
>>         will try
>>                  to give
>>                  my best and work in a professional manner.
>>                  *Do you have any known time conflicts during the
>>         official coding
>>                  period?
>>                  (June 17 to Sept. 27)*
>>                  No .
>>                  On Thu, Apr 25, 2013 at 12:47 AM, Stephen Woodbridge
>>         <mailto:woodbri at swoodbridge.__**com <mailto:woodbri at swoodbridge.*
>>         <mailto:woodbri at swoodbridge.>_**___com
>>         <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>>
>> wrote:
>>                       On 4/24/2013 2:34 PM, Mukul priya wrote:
>>                           Hi Steve and Daniel ,
>>                           I have posted my proposal on Melange Gsoc
>>         system. Do
>>                  have a look
>>                           at it.
>>                           Waiting for feedback and suggestions.
>>                       Can you post a link to your proposal? or the text
>>         of it
>>                  here also. I
>>                       can never find anything in Melange or I may not have
>>                  visibility to
>>                       it yet as I just applied as a mentor.
>>                       Thanks,
>>                          -Steve
>>                       ______________________________**
>>                       pgrouting-dev mailing list
>>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**
>> osgeo.org <pgrouting-dev at lists.osgeo.org>>
>>                  <mailto:pgrouting-dev at lists.__**osgeo.org<http://osgeo.org>
>>         <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>>         <mailto:pgrouting-dev at lists.>_**___osgeo.org <http://osgeo.org>
>>         http://lists.osgeo.org/______**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev>
>>         <http://lists.osgeo.org/____**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev>
>>         <http://lists.osgeo.org/__**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
>> **>__>
>>         <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>> **>__>__>
>>                  ______________________________**_____________________
>>         <mailto:pgrouting-dev at lists.__**osgeo.org <http://osgeo.org>
>> **>__>
>> **>__>
>>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130425/7c03f837/attachment-0001.html>
More information about the pgrouting-dev mailing list
