[pgrouting-dev] Free as in Freedom OSM converter
Stephen Mather
stephen at smathermather.com
Wed Jun 12 20:39:28 PDT 2013
Wos, I wasn't expecting a response so soone. I'll give your new version
a test.
Best,
Steve
On 06/10/2013 11:01 PM, Daniel Kastl wrote:
> On Tue, Jun 11, 2013 at 11:11 AM, Stephen Mather
> <mather.stephen at gmail.com <mailto:mather.stephen at gmail.com>> wrote:
> Hi All,
> Is (for the moment) OSM2pgrouting a zombie project, or has there
> been work to port this for 2.0? I'm using OSM2po at the moment,
> but thought I'd check in on status of free as in freedom alternatives.
> Thanks,
> Best,
> Steve
> Hi Steve,
> osm2pgrouting needs some work, because
> 1. Not compatible with PostGIS 2.0 and the new pgRouting 2.0
> 2. Cannot handle the new OSM bigint ID's
> It was some years ago written by Daniel Wendt and then hosted together
> with pgRouting and like this found its way to Github.
> There is not much activity except some modifications over the years.
> But it has so far worked and just recently we have the issues as
> described before.
> Currently pgRouting has priority. If someone wants to fix the issues
> with osm2pgrouting, then that's very welcome.
> There is a good alternative to process OSM data, named "osm2po". But
> it's not released under Open Source license, if that's OK for you.
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130612/fdadf264/attachment.html>
More information about the pgrouting-dev
