[pgrouting-dev] Definitions for types
Stephen Mather stephen at smathermather.com
Fri Jun 14 16:36:04 PDT 2013
Ah yes.  I see I was doing a really lazy man's job of reading the
docs... .  Apologies for that.
Thanks Steve,
Best,
Steve
> http://docs.pgrouting.org/dev/doc/index.html
> It is a generic tuple, and each function decides what to put in the
> slots, but the basic usage is something like:
> seq - allows you to maintain order of results after joins
> id1 - often node id
> id2 - often edge id
> cost - cost to traverse edge or get to node
> But it can vary based on the specific command.
> -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
