[pgrouting-dev] Having problems under standing the distance matrix of TSP in respect to route network pgroute version 2
Dave Potts
dave.potts at pinan.co.uk
Fri Jun 14 22:37:38 PDT 2013
On 14/06/13 14:19, Daniel Kastl wrote:
I can try and have a play, my problem being that I am more a C/java
programmer than an sql programmer. I prefer to deal with standard sql
constructs rather that data base specfic stuff.
I can see why you got for the matrix solution, if avoid all those
node/hash lookup problems.
If coding an select * from xyz solution , you have to deal with the case
that a node may be any number in the range 1-32^2 and that has to be
mapped on to an array of given size by using some type of hashing
function and a reverse lookup has to be done on the return.
The store procedure has its attractions because its version neutral, it
will work as well on linix box as well as a Windoz box.
I see what I can come up with.
DAve.
> On Fri, Jun 14, 2013 at 10:07 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> Hi Dave,
> I'm not totally opposed to this, but I would like to discuss how
> you plan to structure the data and what your query would look like.
> There is another possibility that I like better and that would be
> to write stored procedure that takes you sql query and returns a
> matrix.
> matrix[][] pgr_matrix(sql text)
> Then you can do something like:
> select * from pgr_tsp(pgr_matrix('select * from matrix_table'), 27);
> This idea I really like, because we might also be able to use it then
> for Razequl's VRP solver.
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130615/5624b688/attachment.html>
More information about the pgrouting-dev
