[pgrouting-dev] Having problems under standing the distance matrix of TSP in respect to route network pgroute version 2
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Jun 15 05:28:45 PDT 2013
Dave,
I thought a lot about this problem before coming up with the matrix. The
problem really boils down to how do you define your data that you want
to fetch with "select * from xyz", ie: your inputs and what you need to
solve TSP, ie: your outputs. In this case a symmetrix NxN matrix that is
fully populated.
One idea I had was to structure xyz something like:
node_a, node_b, cost
but then you have to count the distinct nodes, and create a map to
indices and a reverse map as you as you mention. But this is all pretty
trivial to do in SQL.
create temporary table xyz_map (
id serial not null primary key,
nid integer
insert into xyz_map values (nid) select nid from (
select distinct node_a as nid from xyz
union
select distinct node_b as nid from xyz
) as foo;
select array_agg(row) as matrix from (
select a.id, array_agg(cost) as row
from xyz a, xyz_map b, xyz_map c
where a.node_a=b.nid and a.node_b=c.nid
group by a.id
order by c.id
) foo order by foo.id;
I have not tested this, but I think it is close to what you would work.
I would then do some checking of matrix to make sure it is symmetric and
filled out.
-Steve
On 6/15/2013 1:37 AM, Dave Potts wrote:
> On 14/06/13 14:19, Daniel Kastl wrote:
> I can try and have a play, my problem being that I am more a C/java
> programmer than an sql programmer. I prefer to deal with standard sql
> constructs rather that data base specfic stuff.
> I can see why you got for the matrix solution, if avoid all those
> node/hash lookup problems.
> If coding an select * from xyz solution , you have to deal with the case
> that a node may be any number in the range 1-32^2 and that has to be
> mapped on to an array of given size by using some type of hashing
> function and a reverse lookup has to be done on the return.
> The store procedure has its attractions because its version neutral, it
> will work as well on linix box as well as a Windoz box.
> I see what I can come up with.
> DAve.
>> On Fri, Jun 14, 2013 at 10:07 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>> Hi Dave,
>> I'm not totally opposed to this, but I would like to discuss how
>> you plan to structure the data and what your query would look like.
>> There is another possibility that I like better and that would be
>> to write stored procedure that takes you sql query and returns a
>> matrix.
>> matrix[][] pgr_matrix(sql text)
>> Then you can do something like:
>> select * from pgr_tsp(pgr_matrix('select * from matrix_table'), 27);
>> This idea I really like, because we might also be able to use it then
>> for Razequl's VRP solver.
>> Daniel
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
>> Web: http://georepublic.de <http://georepublic.de/>
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev
