[pgrouting-dev] Driving Distance
Stephen Mather
stephen at smathermather.com
Fri Jun 21 13:07:45 PDT 2013
Hi All,
Having a great time with 2.0-develop. Question on pgr_drivingDistance.
I added geometry to the test dataset and wrote the following query to
return all points within driving distance:
WITH DD AS (
SELECT seq, id1 AS node, cost
FROM pgr_drivingDistance(
'SELECT id, source, target, cost FROM edge_table',
7, 1.5, false, false
SELECT ST_AsText(the_geom)
FROM vertex_table w, DD d
WHERE w.id <http://w.id> = d.node
A) Am I correct in my usage of this?
B) Am I correct in assuming there is no way (at this time) to return
subsets of lines, similar to TSP?
Best,
Steve
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130621/6dec0408/attachment.html>
More information about the pgrouting-dev
