[pgrouting-dev] pgr_alphaShape
Stephen Mather stephen at smathermather.com
Fri Jun 21 13:39:00 PDT 2013
Ok so it get's interesting trying to use embed one function within
another, for example calculating driving distance and wrapping with
alpha shape.
This is as far as I've gotten:
On 06/21/2013 04:07 PM, Stephen Mather wrote:
> Hi All,
> Having a great time with 2.0-develop.  Question on
> pgr_drivingDistance.  I added geometry to the test dataset and wrote
> the following query to return all points within driving distance:
> WITH DD AS (
> SELECT seq, id1 AS node, cost
>         FROM pgr_drivingDistance(
>                 'SELECT id, source, target, cost FROM edge_table',
>                 7, 1.5, false, false
> SELECT ST_AsText(the_geom)
>     FROM vertex_table w, DD d
>     WHERE w.id <http://w.id> = d.node
> A) Am I correct in my usage of this?
> B) Am I correct in assuming there is no way (at this time) to return
> subsets of lines, similar to TSP?
> Best,
> Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130621/02ceede8/attachment.html>
More information about the pgrouting-dev mailing list
