[pgrouting-dev] pgr_alphaShape
Stephen Mather stephen at smathermather.com
Fri Jun 21 13:39:50 PDT 2013
Ahem, sent before I was done:
WITH DD AS (
SELECT seq, id1 AS node, cost
         FROM pgr_drivingDistance(
                 'SELECT id, source, target, cost FROM edge_table',
                 7, 1.5, false, false
dd_points AS(
SELECT id, x, y
     FROM vertex_table w, DD d
     WHERE w.id <http://w.id> = d.node
SELECT pgr_alphaShape('SELECT * FROM dd_points');
doesn't work...
ERROR:  relation "dd_points" does not exist
I understand why this doesn't work, but I'm not sure how to work around.
On 06/21/2013 04:39 PM, Stephen Mather wrote:
> Ok so it get's interesting trying to use embed one function within
> another, for example calculating driving distance and wrapping with
> alpha shape.
> This is as far as I've gotten:
> On 06/21/2013 04:07 PM, Stephen Mather wrote:
>> Hi All,
>> Having a great time with 2.0-develop.  Question on
>> pgr_drivingDistance.  I added geometry to the test dataset and wrote
>> the following query to return all points within driving distance:
>> WITH DD AS (
>> SELECT ST_AsText(the_geom)
>> A) Am I correct in my usage of this?
>> B) Am I correct in assuming there is no way (at this time) to return
>> subsets of lines, similar to TSP?
>> Best,
>> Steve
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130621/abd05a43/attachment.html>
More information about the pgrouting-dev mailing list
