[pgrouting-dev] pgr_alphaShape
Stephen Mather
stephen at smathermather.com
Sun Jun 23 09:44:20 PDT 2013
A solution of course is to escape the single quotes in the WITH queries,
and then embed in the pgr_alphaShape as below. Hope this helps someone:
SELECT pgr_alphaShape('
WITH DD AS (
SELECT seq, id1 AS node, cost
FROM pgr_drivingDistance(
''SELECT id, source, target, cost FROM edge_table'',
7, 1.5, false, false
dd_points AS(
SELECT id, x, y
FROM vertex_table w, DD d
WHERE w.id <http://w.id> = d.node
SELECT * FROM dd_points
Best,
Steve
On 06/21/2013 04:39 PM, Stephen Mather wrote:
> Ahem, sent before I was done:
> WITH DD AS (
> 'SELECT id, source, target, cost FROM edge_table',
> dd_points AS(
> SELECT id, x, y
> SELECT pgr_alphaShape('SELECT * FROM dd_points');
> doesn't work...
> ERROR: relation "dd_points" does not exist
> I understand why this doesn't work, but I'm not sure how to work around.
>> Ok so it get's interesting trying to use embed one function within
>> another, for example calculating driving distance and wrapping with
>> alpha shape.
>> This is as far as I've gotten:
>> On 06/21/2013 04:07 PM, Stephen Mather wrote:
>>> Hi All,
>>> Having a great time with 2.0-develop. Question on
>>> pgr_drivingDistance. I added geometry to the test dataset and wrote
>>> the following query to return all points within driving distance:
>>> WITH DD AS (
>>> SELECT ST_AsText(the_geom)
>>> A) Am I correct in my usage of this?
>>> B) Am I correct in assuming there is no way (at this time) to return
>>> subsets of lines, similar to TSP?
>>> Best,
>>> Steve
>>> pgrouting-dev mailing list
>>> pgrouting-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130623/d10c1c2e/attachment.html>
More information about the pgrouting-dev
