[pgrouting-dev] tsp problem
Jaime Casanova jaime at 2ndquadrant.com
Mon Mar 4 07:38:29 PST 2013
On Tue, Mar 22, 2011 at 3:09 PM, Jaime Casanova <jaime at 2ndquadrant.com> wrote:
> Hi,
> I installed pgrouting with tsp on a centos 5 machine with postgres
> 8.4.5 and postgis 1.3.6.
> When i tried to run this query:
> SELECT *
> FROM tsp_astar_directed('view_viasnodo','38151,38151,35604,35586,20948,39935,35457,40636,40242,35485,19143,40079,40335,40058,19058',38147,12000,false,false);
> i get this message "ERROR:  relation "tsp_test" does not exist at
> character 328" which is because the function tsp_astar_directed() in
> routing_tsp_wrappers.sql has an UNION ALL that takes values from that
> table... i workaround that problem creating a dummy tsp_test table...
> but then when i try the same select i get "segmentation fault", this
> is the backtrace:
I posted this on 2011 but it seems i posted in the users list. I also
created issue # 27 (https://github.com/pgRouting/pgrouting/issues/27)
on github.
On that issue someone suggested to replace al ocurrences of "tsp_test"
with " ' || quote_ident(geom_table) || ' ", which i did (recently) but
now i get this other crash (which i reported in a comment on that same
issue).
Core was generated by `postgres: postgres db [local] SELECT '.
Program terminated with signal 11, Segmentation fault.
#0 0x00007f301738965d in find_tsp_solution (num=, dist=,
p_ids=0x7fff89d10b40, source=,
fit=0x7fff89d10be8, err_msg=) at
/usr/src/debug/pgrouting-1.05/extra/tsp/src/tsp_solver.cpp:299
299 if(score < ga_get_entity_from_rank(pop,0)->fitness)
as you can see this is failing at tsp_solver line 299 which is an "if
" statement and the only thing i can see as a possible problem is the
function ga_get_entity_from_rank() which comes from GAUL.
ideas?
Jaime Casanova         www.2ndQuadrant.com
Professional PostgreSQL: Soporte 24x7 y capacitación
Phone: +593 4 5107566         Cell: +593 987171157
More information about the pgrouting-dev mailing list
