[pgrouting-dev] tsp problem
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Mar 4 08:23:35 PST 2013
Hi Jaime,
I'm not sure there is anyone that knows much about the original tsp
integration still on the list.
I am starting a project targeted to release a pgrouting 2.0. We have
wishlist items in this plan to replace Gaul and cgal libraries if we
have time to integrate a suitable replacement.
If you are able to dig into this and create a pull request, I will be
going through a lot of the open pull requests at some point in this
process, but if we replace gaul that will be moot for 2.0. That said I
expect there will be people that need the fix for the current releases.
-Steve W
On 3/4/2013 10:38 AM, Jaime Casanova wrote:
> On Tue, Mar 22, 2011 at 3:09 PM, Jaime Casanova <jaime at 2ndquadrant.com> wrote:
>> Hi,
>> I installed pgrouting with tsp on a centos 5 machine with postgres
>> 8.4.5 and postgis 1.3.6.
>> When i tried to run this query:
>> SELECT *
>> FROM tsp_astar_directed('view_viasnodo','38151,38151,35604,35586,20948,39935,35457,40636,40242,35485,19143,40079,40335,40058,19058',38147,12000,false,false);
>> i get this message "ERROR: relation "tsp_test" does not exist at
>> character 328" which is because the function tsp_astar_directed() in
>> routing_tsp_wrappers.sql has an UNION ALL that takes values from that
>> table... i workaround that problem creating a dummy tsp_test table...
>> but then when i try the same select i get "segmentation fault", this
>> is the backtrace:
> I posted this on 2011 but it seems i posted in the users list. I also
> created issue # 27 (https://github.com/pgRouting/pgrouting/issues/27)
> on github.
> On that issue someone suggested to replace al ocurrences of "tsp_test"
> with " ' || quote_ident(geom_table) || ' ", which i did (recently) but
> now i get this other crash (which i reported in a comment on that same
> issue).
> Core was generated by `postgres: postgres db [local] SELECT '.
> Program terminated with signal 11, Segmentation fault.
> #0 0x00007f301738965d in find_tsp_solution (num=, dist=,
> p_ids=0x7fff89d10b40, source=,
> fit=0x7fff89d10be8, err_msg=) at
> /usr/src/debug/pgrouting-1.05/extra/tsp/src/tsp_solver.cpp:299
> 299 if(score < ga_get_entity_from_rank(pop,0)->fitness)
> as you can see this is failing at tsp_solver line 299 which is an "if
> " statement and the only thing i can see as a possible problem is the
> function ga_get_entity_from_rank() which comes from GAUL.
> ideas?
> Jaime Casanova www.2ndQuadrant.com
> Professional PostgreSQL: Soporte 24x7 y capacitación
> Phone: +593 4 5107566 Cell: +593 987171157
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev
