[pgrouting-dev] pgRouting 2.0 Update
Daniel Kastl
daniel at georepublic.de
Tue Mar 12 20:38:32 PDT 2013
Thanks, Steve!
The progress is encouraging.
I think it's important that the basic structure is there, so that later old
and new functionality can be added back easily by anyone, who wants to
help. And that it's clearly defined, what needs to be included with each
new algorithm, such as directory structure, tests, documentation, etc..
Daniel
On Wed, Mar 13, 2013 at 12:13 PM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> Hi all,
> I'm making some progress with pgRouting on Win64. I have been able to get
> my source tree to compile which means I have worked through the various
> issues of installing the various dependencies to pgRouting. There are still
> a few minor issues in this regard and Sanak is looking into one related to
> installing boost.
> My source tree is not complete yet from the point of view that it still
> needs changes for:
> 1. creating all the postgresql extension files and installing them properly
> 2. for up grading the SQL to work with postgis 2.0+
> 3. testing the installed code
> 4. getting everything to work with 32 bit builds
> But getting the dependencies to install and getting the source to compile
> on MinGW64 is a huge step. I have also brought the source back to Linux and
> made a few changes there. So a lot of back and forth to keep everything
> working on both sides.
> Thanks,
> -Steve
> ______________________________**_________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130313/b3748412/attachment-0001.html>
More information about the pgrouting-dev
