[pgrouting-dev] pgRouting 2.0 Update
Stephen Woodbridge woodbri at swoodbridge.com
Wed Mar 13 08:02:25 PDT 2013
On 3/13/2013 10:02 AM, Sandro Santilli wrote:
> On Wed, Mar 13, 2013 at 08:24:52AM -0400, Stephen Woodbridge wrote:
>> Hi strk,
>> On 3/13/2013 3:14 AM, Sandro Santilli wrote:
>>> Hi Stephen,
>>> is the branch supposed to be buildable on linux ?
>> More or less, I have been changing between linux and windows to keep
>> the cmake changes working on both side. It needs me to push some
>> stuff back for linux which will happen later today.
>> BUT - at this point it is only "buildable", it does not install and
>> has not been tested. I also have a lot of changes to make to it for
>> postgis 2.x compatibility.
> It's not buildable here, with cmake 2.8.7:
This might be a problem. I'm running cmake version 2.8.10.2 and I might
need to up the minimum version to 2.8.10 as I think that is the version
that allows you to build obj files in a tree and then assembly them into
a single library, which is what I'm doing.
>   -- Configuring done
>   CMake Error at CMakeLists.txt:139 (ADD_LIBRARY):
>    Cannot find source file:
>      $<TARGET_OBJECTS:astar>
>    Tried extensions .c .C .c++ .cc .cpp .cxx .m .M .mm .h .hh .h++ .hm .hpp
>    .hxx .in .txx
> And the same message repeated for:
>    $<TARGET_OBJECTS:dijkstra>
>    $<TARGET_OBJECTS:shooting_star>
>    $<TARGET_OBJECTS:trsp>
> Then:
>   CMake Error in core/astar/src/CMakeLists.txt:
>      OBJECT
>    .hxx .in .txx
> and the same message repeated for:
>   CMake Error in core/dijkstra/src/CMakeLists.txt:
>   CMake Error in core/shooting_star/src/CMakeLists.txt:
>   CMake Error in core/trsp/src/CMakeLists.txt:
> And finally:
>   -- Build files have been written to: /usr/src/pgrouting/pgrouting/b
> With cmake exit code being 1 and `make` returning:
>   make: *** No targets specified and no makefile found.  Stop.
> This is invoking cmake from outside the source dir, ie:
>   mkdir b; cd b; cmake -DWITH_TSP=ON -DWITH_DD=ON ..
My cmake files were not designed to work outside the source tree. I
think all your errors above are a result of this. I didn't think about
doing this, but there is no reason that I could support this at some
point. I'm very new to working with cmake so suggestions, help and/or
pull requests would be appreciated. I suspect that I would need to
establish the root of the src tree, then make all the paths absolute or
something along those lines. Do you have an example of a project that
does this?
> With current seq-devel-2_0 (commit 825b40e049e4b21787c27f00aae49b0382279842)
I just pushed a minor fix to add -fPIC so the libraries will link now on
linux. 825b40e..209c592  sew-devel-2_0 -> sew-devel-2_0
Thank you for taking the time to test this and report back.
-Steve
> --strk;
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
