[pgrouting-dev] pgRouting 2.0 Update
Sandro Santilli
strk at keybit.net
Wed Mar 13 08:13:38 PDT 2013
On Wed, Mar 13, 2013 at 11:02:25AM -0400, Stephen Woodbridge wrote:
> On 3/13/2013 10:02 AM, Sandro Santilli wrote:
> >It's not buildable here, with cmake 2.8.7:
> This might be a problem. I'm running cmake version 2.8.10.2 and I
> might need to up the minimum version to 2.8.10 as I think that is
> the version that allows you to build obj files in a tree and then
> assembly them into a single library, which is what I'm doing.
It'd be a pity to drop support for older cmake, it's actually already
an annoyance to require cmake :'(
> My cmake files were not designed to work outside the source tree. I
> think all your errors above are a result of this. I didn't think
> about doing this, but there is no reason that I could support this
> at some point. I'm very new to working with cmake so suggestions,
> help and/or pull requests would be appreciated. I suspect that I
> would need to establish the root of the src tree, then make all the
> paths absolute or something along those lines. Do you have an
> example of a project that does this?
QGIS does that. But I don't really have tips on using cmake, so far
I've seen _no_ project using cmake and giving the same level of features
you have with autoconf. /me cmake hater :)
--strk;
http://strk.keybit.net
More information about the pgrouting-dev
