[pgrouting-dev] pgRouting 2.0 Update
Stephen Woodbridge woodbri at swoodbridge.com
Mon Mar 18 05:37:06 PDT 2013
On 3/18/2013 8:09 AM, Sandro Santilli wrote:
> On Sun, Mar 17, 2013 at 08:22:04PM -0400, Stephen Woodbridge wrote:
>> On 3/17/2013 2:56 PM, Sandro Santilli wrote:
>>> Note it'd currently be impossible to test with the "CREATE EXTENTION"
>>> mechanism (no way to load an extension from outside the systemwide
>>> directory).
>> I just read the thread you started on pgsql-hackers about this issue
>> last year. It seems that extension are version wide rather than
>> database wide, because the current system assume everything is store
>> in a versioned directory tree.
>> So if you build postgresql from src you can set the PREFIX to
>> something like ~/pgN.N which would give us our private version
>> install tree, as a regular user so it does not try to overwrite
>> system files.
>> Any thoughts on this?
> Making tests rely on a specific build of PostgreSQL doesn't seem
> a good idea to me. I mean, it's the same as NOT providing pre-install
> testing, and delegating to the user the installation in a staging
> environment for the sole purpose of testing.
> I'm not familiar with extensions, but as long as you still need
> enabling and disabling scripts, can't you just always _also_ provide
> those scripts and use them for setting up the testing database ?
I'm thinking about how we can test multiple versions of postgresql and
multiple versions of postgis.
So if it were possible to install multiple postgresql instances in
separate trees, then you could do something like:
for each version tree
   start postgres for this tree
   cmake for this tree
   build and stage for this tree
   test on this tree
   stop postgres for this tree
endfor
May be we need to think about setting up travis-ci or jenkins testing
frameworks. I might leave this to someone else to tackle if anyone is
interested.
-Steve
More information about the pgrouting-dev mailing list
