[pgrouting-dev] [pgr_2.0] pgRouting 2.0 Update 2013-03-22
Daniel Kastl daniel at georepublic.de
Fri Mar 22 19:05:05 PDT 2013
On Sat, Mar 23, 2013 at 8:42 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Hi all,
> I continue to make progress on this. Next week I will be commuting into
> Boston all week for the Code Sprint. I look forward to meeting some of our
> colleagues there and continuing the efforts made so far. I'm not looking
> forward 1 hr+ commute to get into Boston in the mornings.
Thanks a lot for lots of changes, Steve!
Would have been nice to be in Boston as well next week, but commutation
time from here is even longer ;-)
> Today, I cleaned up the core/common/sql/* files, moved some cruft that is
> not getting used elsewhere into a legacy file, renamed the functions in
> topology and matching to have pgr_ prefix and pretty much rewrote
> add_vertices_geometry() function. I also move functions that were specific
> to an algorithm into their respect folders and renamed files so they are
> more consistent.
This is probably something Sandro can comment on, but is there any chance
to make use of the new PostGIS topology support and topology in pgRouting.
It's a different purpose, I know, just thinking loud.
Renaming the create_vertex_id function is something I always thought to be
important. The name already comes from pgDijkstra, though it always needed
an extra explanation in the workshop as the name was a bit confusing.
Have you seen Mario's attempts to rename the functions? Could be helpful
for name finding.
> So far I have moved the following functions into the legacy file. These
> will not get installed automatically and they will not be maintained or
> tested and might just disappear. The real idea for the legacy file is that
> we might want to build legacy wrappers that simulate the old pre 2.0
> behavior. This might be a job for another contributor once the new api
> stabilizes.
That's good.
> Also, a few people have boldly step forward and tried on the new code and
> reported back and I want to thank them for their feedback and effort. The
> more this happens the better the code will ultimately be, but things are
> very dynamic at the moment. I try to keep the branch in a more or less
> buildable, installable state, and to the extent I can functioning. If I
> find that I broke something, I try to imediately fix and push the code back
> out. There is usually a push every night or when I get a things stabilized.
> I think I pushed code 3 or 4 times today. Did I mention this is dynamic? :)
Yes, my Desktop notification for pgRouting news is already spinning ;-)
If I find some time during the weekend I thought to move the documentation
snippets into the right folders.
Do you have any objection to use Sphinx to build the documentation? The
website already uses it and the workshop as well.
Daniel
> Thanks,
>   -Steve
> ______________________________**_________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130323/a0c307d3/attachment.html>
More information about the pgrouting-dev mailing list
