[pgrouting-dev] Sphinx documentation update
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Mar 23 17:33:31 PDT 2013
Hi Daniel,
In the current CMakeLists.txt file I actually assemble the sql files
during the cmake run and not during the make. This is probably wrong. It
was not obvious to me how to change the cmake to that this process got
move to the make process rather than the config process. I assume it
involves creating a cmake script that gets run as a Makefile target.
Any thoughts on how to do this?
It would probably be a good idea when you guys have some time to review
and make changes to the cmake stuff. I would like to see if we can break
this up into a collection of callable modules the tackle the various
configuration tasks and the make tasks.
-Steve
On 3/23/2013 4:37 PM, Stephen Woodbridge wrote:
> Hi Daniel,
> I did a little more work on this. I added a cmake/FindSphinx.cmake file
> and as I mentioned before add -DWITH_DOC=ON target.
> Also we have the README.md should this get renamed to rst and get build
> built as part of the doc.
> So my plan for the"doc" directory it to have one file there that would
> be our index.rst -> index.html and this file would have a project
> overview and an index to other docs like:
> project - A more detailed project overview including PSC, source,
> download links, listserv links, ...
> users-guide - Detailed doc on each major function and helper functions
> tutorial - List of tutorials and links (might be in subdirs)
> gallery - Standardized description and link to apps using pgr
> presentations - List of presentations and links (might be in subdirs)
> developers - Developer standards, howtos
> FAQ - FAQ document
> ... - other stuff as appropriate
> Where each of these would be a subdirectory and would contain pages and
> or additional subdirs as needed.
> But it still has some problems:
> woodbri at maps:~/work/pgrouting$ cmake -H. -Bmybuild -DWITH_TSP=ON
> -DWITH_DD=ON -DWITH_DOC=ON
> -- The C compiler identification is GNU 4.4.5
> -- The CXX compiler identification is GNU 4.4.5
> -- Check for working C compiler: /usr/bin/cc
> -- Check for working C compiler: /usr/bin/cc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Check for working CXX compiler: /usr/bin/c++
> -- Check for working CXX compiler: /usr/bin/c++ -- works
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- POSTGRESQL_EXECUTABLE is /usr/lib/postgresql/8.4/bin/postgres
> -- POSTGRESQL_PG_CONFIG is /usr/bin/pg_config
> -- Found PostgreSQL: /usr/include/postgresql/8.4/server, /usr/lib
> -- Boost version: 1.42.0
> Boost headers were found here: /usr/include
> POSTGRESQL_VERSION_STRING is PostgreSQL 8.4.16
> POSTGRESQL_VERSION is 8.4.16
> Install directory for libraries is set to /usr/lib/postgresql/8.4/lib
> Install directory for SQL files is set to /usr/share/pgrouting
> -- Found Sphinx: /usr/bin/sphinx-build
> Installation directory for libraries is set to
> /usr/lib/postgresql/8.4/lib and for SQL files is set to
> -- Found GAUL: /usr/local/lib/libgaul.so, /usr/local/lib/libgaul_util.so
> Installation directory for libraries is set to /usr/lib/postgresql/8.4/lib
> -- Found CGAL: /usr/include, /usr/lib/libCGAL.so,
> /usr/lib/libboost_thread.so, /usr/lib/libgmp.so
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/woodbri/work/pgrouting/mybuild
> woodbri at maps:~/work/pgrouting$ cd mybuild/
> woodbri at maps:~/work/pgrouting/mybuild$ make
> Scanning dependencies of target trsp
> [ 6%] Building C object core/trsp/src/CMakeFiles/trsp.dir/trsp.c.o
> [ 12%] Building CXX object
> core/trsp/src/CMakeFiles/trsp.dir/trsp_core.cpp.o
> [ 18%] Building CXX object
> core/trsp/src/CMakeFiles/trsp.dir/GraphDefinition.cpp.o
> [ 18%] Built target trsp
> Scanning dependencies of target astar
> [ 25%] Building C object core/astar/src/CMakeFiles/astar.dir/astar.c.o
> [ 31%] Building CXX object
> core/astar/src/CMakeFiles/astar.dir/astar_boost_wrapper.cpp.o
> [ 31%] Built target astar
> Scanning dependencies of target dijkstra
> [ 37%] Building C object
> core/dijkstra/src/CMakeFiles/dijkstra.dir/dijkstra.c.o
> [ 43%] Building CXX object
> core/dijkstra/src/CMakeFiles/dijkstra.dir/boost_wrapper.cpp.o
> [ 43%] Built target dijkstra
> Scanning dependencies of target shooting_star
> [ 50%] Building C object
> core/shooting_star/src/CMakeFiles/shooting_star.dir/shooting_star.c.o
> [ 56%] Building CXX object
> core/shooting_star/src/CMakeFiles/shooting_star.dir/shooting_star_boost_wrapper.cpp.o
> [ 56%] Built target shooting_star
> Scanning dependencies of target routing
> Linking CXX shared library lib/librouting.so
> [ 56%] Built target routing
> Scanning dependencies of target my_project_docs
> [ 62%] Building HTML documentation with Sphinx
> Making output directory...
> /home/woodbri/work/pgrouting/doc/README.rst:109: WARNING: image file not
> readable: build/trsp-test-image.png
> /home/woodbri/work/pgrouting/doc/index.rst:11: (WARNING/2) toctree
> references unknown document u'...'
> WARNING: static directory
> '/home/woodbri/work/pgrouting/mybuild/doc/_build/_static' does not exist
> [ 62%] Built target my_project_docs
> Scanning dependencies of target routing_tsp
> [ 68%] Building C object core/tsp/src/CMakeFiles/routing_tsp.dir/tsp.c.o
> [ 75%] Building CXX object
> core/tsp/src/CMakeFiles/routing_tsp.dir/tsp_solver.cpp.o
> Linking CXX shared library ../../../lib/librouting_tsp.so
> [ 75%] Built target routing_tsp
> Scanning dependencies of target routing_dd
> [ 81%] Building C object
> core/driving_distance/src/CMakeFiles/routing_dd.dir/alpha.c.o
> [ 87%] Building CXX object
> core/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.cpp.o
> [ 93%] Building CXX object
> core/driving_distance/src/CMakeFiles/routing_dd.dir/boost_drivedist.cpp.o
> [100%] Building C object
> core/driving_distance/src/CMakeFiles/routing_dd.dir/drivedist.c.o
> Linking CXX shared library ../../../lib/librouting_dd.so
> [100%] Built target routing_dd
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev
