[pgrouting-dev] pgRouting 2.0 Update - Build outside src tree
Daniel Kastl daniel at georepublic.de
Mon Mar 25 18:56:06 PDT 2013
> Your last pushed broke a few things:
> 1. make distclean - is now gone
I didn't change anything but "make distclean" is a custom extension added
by Kishore during GSoC and maybe it doesn't work in build directories.
> 2. something is missing related to sphinx (see below)
It's missing the theme named 'pyramid', which seems to be installed with
the Ubuntu package, so I assumed it would be included in general.
Changing this to "default" solves this. But good to know that not all
themes are available, so I will use the default one and customize it.
Daniel
> 3. MinGW cmake can not find any of dependencies. I'm trying to figure this
> out, but its seriously broke at the moment.
> -Steve
> Build error:
> woodbri at maps:~/work/pgrouting$ rm -rf build
> woodbri at maps:~/work/pgrouting$ mkdir build
> woodbri at maps:~/work/pgrouting$ cd build
> woodbri at maps:~/work/pgrouting/**build$ cmake -DWITH_TSP=ON -DWITH_DD=ON
> -DWITH_DOC=ON ..
> -- The C compiler identification is GNU 4.4.5
> -- The CXX compiler identification is GNU 4.4.5
> -- Check for working C compiler: /usr/bin/cc
> -- Check for working C compiler: /usr/bin/cc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Check for working CXX compiler: /usr/bin/c++
> -- Check for working CXX compiler: /usr/bin/c++ -- works
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- Found Git: /usr/bin/git
> -- POSTGRESQL_EXECUTABLE is /usr/lib/postgresql/8.4/bin/**postgres
> -- POSTGRESQL_PG_CONFIG is /usr/bin/pg_config
> -- Found PostgreSQL: /usr/include/postgresql/8.4/**server, /usr/lib
> -- Boost version: 1.42.0
> Boost headers were found here: /usr/include
> POSTGRESQL_VERSION_STRING is PostgreSQL 8.4.16
> POSTGRESQL_VERSION is 8.4.16
> Install directory for libraries is set to /usr/lib/postgresql/8.4/lib
> Install directory for SQL files is set to /usr/share/pgrouting
> -- Found Sphinx: /usr/bin/sphinx-build
> Installation directory for libraries is set to /usr/lib/postgresql/8.4/lib
> and for SQL files is set to /usr/share/pgrouting
> -- Found GAUL: /usr/local/lib/libgaul.so, /usr/local/lib/libgaul_util.so
> -- Found CGAL: /usr/include, /usr/lib/libCGAL.so,
> /usr/lib/libboost_thread.so, /usr/lib/libgmp.so
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/woodbri/work/pgrouting/**build
> woodbri at maps:~/work/pgrouting/**build$ make
> Scanning dependencies of target trsp
> [  6%] Building C object core/trsp/src/CMakeFiles/trsp.**dir/trsp.c.o
> [ 12%] Building CXX object core/trsp/src/CMakeFiles/trsp.**
> dir/trsp_core.cpp.o
> [ 18%] Building CXX object core/trsp/src/CMakeFiles/trsp.**
> dir/GraphDefinition.cpp.o
> [ 18%] Built target trsp
> Scanning dependencies of target astar
> [ 25%] Building C object core/astar/src/CMakeFiles/**astar.dir/astar.c.o
> [ 31%] Building CXX object core/astar/src/CMakeFiles/**
> astar.dir/astar_boost_wrapper.**cpp.o
> [ 31%] Built target astar
> Scanning dependencies of target dijkstra
> [ 37%] Building C object core/dijkstra/src/CMakeFiles/**
> dijkstra.dir/dijkstra.c.o
> [ 43%] Building CXX object core/dijkstra/src/CMakeFiles/**
> dijkstra.dir/boost_wrapper.**cpp.o
> [ 43%] Built target dijkstra
> Scanning dependencies of target shooting_star
> [ 50%] Building C object core/shooting_star/src/**
> CMakeFiles/shooting_star.dir/**shooting_star.c.o
> [ 56%] Building CXX object core/shooting_star/src/**
> CMakeFiles/shooting_star.dir/**shooting_star_boost_wrapper.**cpp.o
> [ 56%] Built target shooting_star
> Scanning dependencies of target routing
> Linking CXX shared library lib/librouting.so
> [ 56%] Built target routing
> Scanning dependencies of target pgRoutingDocumentationdoc
> [ 62%] Building HTML documentation with Sphinx
> Making output directory...
> Theme error:
> no theme named 'pyramid' found (missing theme.conf?)
> make[2]: *** [doc/CMakeFiles/**pgRoutingDocumentationdoc] Error 1
> make[1]: *** [doc/CMakeFiles/**pgRoutingDocumentationdoc.dir/**all] Error
> 2
> make: *** [all] Error 2
>>       mkdir mybuild; cd mybuild; cmake .. && make
>>     This is how qgis cmake build works, for example.
>> I will try this out and if it's possible to make this default.
>>     Also, does this still require cmake 2.8.10 ?
>> Yes, it would be nice if there wouldn't be a requirement for such a
>> recent version of CMake,
>> I even had to compile for Ubuntu.
>> Daniel
>>     --strk;
>>      > You can build it "in" a sub-dir in the source tree or put the
>> source
>>      > tree elsewhere.
>>      > Thank you for the suggestion.
>>      > -Steve
>>      > On 3/13/2013 10:02 AM, Sandro Santilli wrote:
>>      > >On Wed, Mar 13, 2013 at 08:24:52AM -0400, Stephen Woodbridge
>> wrote:
>>      > >>Hi strk,
>>      > >>On 3/13/2013 3:14 AM, Sandro Santilli wrote:
>>      > >>>Hi Stephen,
>>      > >>>is the branch supposed to be buildable on linux ?
>>      > >>More or less, I have been changing between linux and windows to
>>     keep
>>      > >>the cmake changes working on both side. It needs me to push some
>>      > >>stuff back for linux which will happen later today.
>>      > >>BUT - at this point it is only "buildable", it does not install
>> and
>>      > >>has not been tested. I also have a lot of changes to make to it
>> for
>>      > >>postgis 2.x compatibility.
>>      > >It's not buildable here, with cmake 2.8.7:
>>      > >  -- Configuring done
>>      > >  CMake Error at CMakeLists.txt:139 (ADD_LIBRARY):
>>      > >   Cannot find source file:
>>      > >     $<TARGET_OBJECTS:astar>
>>      > >   Tried extensions .c .C .c++ .cc .cpp .cxx .m .M .mm .h .hh
>>     .h++ .hm .hpp
>>      > >   .hxx .in .txx
>>      > >And the same message repeated for:
>>      > >   $<TARGET_OBJECTS:dijkstra>
>>      > >   $<TARGET_OBJECTS:shooting_**star>
>>      > >   $<TARGET_OBJECTS:trsp>
>>      > >Then:
>>      > >  CMake Error in core/astar/src/CMakeLists.txt:
>>      > >     OBJECT
>>     .h++ .hm .hpp
>>      > >   .hxx .in .txx
>>      > >and the same message repeated for:
>>      > >  CMake Error in core/dijkstra/src/CMakeLists.**txt:
>>      > >  CMake Error in core/shooting_star/src/**CMakeLists.txt:
>>      > >  CMake Error in core/trsp/src/CMakeLists.txt:
>>      > >And finally:
>>     /usr/src/pgrouting/pgrouting/b
>>      > >With cmake exit code being 1 and `make` returning:
>>      > >  make: *** No targets specified and no makefile found.  Stop.
>>      > >This is invoking cmake from outside the source dir, ie:
>>      > >  mkdir b; cd b; cmake -DWITH_TSP=ON -DWITH_DD=ON ..
>>      > >With current seq-devel-2_0 (commit
>>     825b40e049e4b21787c27f00aae49b**0382279842)
>>      > >--strk;
>>      > >_____________________________**__________________
>>      > >pgrouting-dev mailing list
>>      > >pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**
>> osgeo.org <pgrouting-dev at lists.osgeo.org>>
>>      > >http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>      > ______________________________**_________________
>>     http://www.cartodb.com - Map, analyze and build applications with
>>     your data
>>                                             ~~ http://strk.keybit.net
>>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl@**georepublic.de<daniel.kastl at georepublic.de>
>> Web: http://georepublic.de <http://georepublic.de/>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130326/9cd7e738/attachment-0001.html>
More information about the pgrouting-dev mailing list
