[pgrouting-dev] Gsoc 2013
Mukul priya
mukul2047 at gmail.com
Fri May 3 04:25:25 PDT 2013
Hi steve ,
I have forked the pgrouting project and cloned it to my local machine. My
git username is "mukulpriya". i will get through the installation process
and post doubts in case i get stuck somewhere.
regards,
mukul
On Sat, Apr 27, 2013 at 7:32 PM, Mukul priya <mukul2047 at gmail.com> wrote:
> Thanks Steve . i will go through the steps that you have mentioned once i
> am free from all my academic commitments by the end of this month ( in 2-3
> days at max).
> -Mukul
> On Sat, Apr 27, 2013 at 6:59 PM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> Hi Mukul,
>> I think your proposal looks good. Daniel may have some additional
>> comment. At this point if you have time, you might want to start with
>> getting a github account, forking the pgrouting project, making sure you
>> can build the existing project and install it under pg 9.2.
>> Regarding the Astar algorithm, you might want to look at implementing
>> your own algorithm unless you want to try and work with the existing Boost
>> code as this might be easier in the long run. Either way some research now,
>> might help you with your planning later. This would allow you to work out
>> all the basics of working in our environment and give you a head start. In
>> the past the most successful and less stressed projects have been those
>> that took an interest early on as these details can be frustrating and time
>> consuming. This is totally at you option because the proposal has not been
>> accepted yet.
>> Thank you putting together an interesting proposal that would add value
>> to the project.
>> -Steve
>> On 4/27/2013 6:29 AM, Mukul priya wrote:
>>> Hi steve , i have edited my proposal based on our previous discussion (
>>> added some lines about Astar) .meanwhile do suggest if there is scope of
>>> some improvement .
>>> Thanks
>>> Mukul
>>> On Thu, Apr 25, 2013 at 11:22 PM, Mukul priya <mukul2047 at gmail.com
>>> <mailto:mukul2047 at gmail.com>> wrote:
>>> Thanks Steve will add a few lines to my proposal explaining the
>>> reason behind opting Astar.
>>> Mukul
>>> On Thu, Apr 25, 2013 at 8:55 PM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>>> wrote:
>>> On 4/25/2013 11:06 AM, Mukul priya wrote:
>>> How much of the network do you have to explore using each
>>> algorithm?
>>> This will be reduced significantly while using Astar as we
>>> will have a
>>> fair bit of idea about the direction towards which we should
>>> proceed.
>>> How does this impact the number of grids you have to load?
>>> Once we have an idea about the direction towards which we
>>> should proceed
>>> , only those grids will be loaded. This will result in
>>> loading of less
>>> number of grids.
>>> How does this impact your proposal?
>>> The basic motivation behind the proposal is to make shortest
>>> path
>>> computation faster. Number of database querry will be
>>> reduced as we will
>>> be fetching lesser number of grids. This will have a
>>> positive effect on
>>> computation time.
>>> Right, so in your proposal, you want to be clear that the
>>> benefit will be achieved using astar or another algorithm with a
>>> heuristic and not dijkstra. I understand that "shortest path" is
>>> a generic reference to all of these algorithms, but the only
>>> ones that will benefit from this approach will be ones with a
>>> heuristic that allow us to explore only a subset the overall
>>> bounding box of edges that we might otherwise use as input. So
>>> it is best to be clear on these points.
>>> -Steve
>>> On Thu, Apr 25, 2013 at 7:07 PM, Stephen Woodbridge
>>> <mailto:woodbri at swoodbridge.__**com
>>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>>> wrote:
>>> On 4/25/2013 12:26 AM, Mukul priya wrote:
>>> Thanks Steve ,I am familar with astar ,It uses a
>>> heuristic to guide
>>> itself to the destination, there was huge focus on
>>> it in our
>>> game theory
>>> course.
>>> Although do point out the advantages it has in real
>>> life road
>>> network
>>> and its importance to my proposal.
>>> each algorithm?
>>> load?
>>> -Steve
>>> On Thu, Apr 25, 2013 at 7:43 AM, Stephen Woodbridge
>>> <mailto:woodbri at swoodbridge.>_**___com
>>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>>
>>> wrote:
>>> Hi Mukul,
>>> This is a good write up. It largely mirrors
>>> out discussion. One
>>> thing that needs to change in this is that
>>> dijkstra should be
>>> replaced with astar.
>>> Are you familiar with how these are different?
>>> http://theory.stanford.edu/~__**
>>> ____amitp/GameProgramming/____**__AStarComparison.html<http://theory.stanford.edu/~______amitp/GameProgramming/______AStarComparison.html>
>>> <http://theory.stanford.edu/%**
>>> 7E____amitp/GameProgramming/__**__AStarComparison.html<http://theory.stanford.edu/%7E____amitp/GameProgramming/____AStarComparison.html>
>>> <http://theory.stanford.edu/%_**
>>> _7E__amitp/GameProgramming/___**_AStarComparison.html
>>> <http://theory.stanford.edu/%**7E__amitp/GameProgramming/__*
>>> *AStarComparison.html<http://theory.stanford.edu/%7E__amitp/GameProgramming/__AStarComparison.html>
>>> ___7Eamitp/GameProgramming/___**_AStarComparison.html
>>> <http://theory.stanford.edu/%_**_7Eamitp/GameProgramming/__*
>>> *AStarComparison.html>
>>> <http://theory.stanford.edu/%**7Eamitp/GameProgramming/**
>>> AStarComparison.html<http://theory.stanford.edu/%7Eamitp/GameProgramming/AStarComparison.html>
>>> Do you see why? and specifically why it matter
>>> for this
>>> project?
>>> -Steve
>>> On 4/24/2013 9:10 PM, Mukul priya wrote:
>>> ***Name*:Mukul Priya
>>> *Country:*India
>>> *School and degree*: International
>>> Institute Of Information
>>> Technology-Hyderabad ,
>>> B.Tech +
>>> Masters in
>>> computer
>>> Science And
>>> Engineering
>>> *Email*:mukul2047 at gmail.com
>>> <mailto:mukul2047 at gmail.com>> <mailto:mukul2047 at gmail.com
>>> <mailto:mukul2047 at gmail.com>>>
>>> <mailto:mukul2047 at gmail.com>>>**>
>>> *Phone*:+91 9885991061
>>> *OSGeo project(s*):pgRouting
>>> *Title:* A partitioned approach to on
>>> demand increment
>>> graph
>>> assembly
>>> for pgRouting.
>>> *Describe your idea*
>>> *1. Introduction*
>>> pgRouting has been working
>>> towards providing
>>> routing
>>> functionality on a PostGis/PostgreSql Geo
>>> spatial
>>> database. It already has support for
>>> shortest path
>>> algorithm
>>> like
>>> astar ,dijkstra , tdsp and trsp .But for a
>>> very
>>> large network, routing becomes time
>>> consuming. Network
>>> partitioning
>>> is one such way which can prove to
>>> be helpful in improving the overall
>>> time efficiency
>>> of routing
>>> querries. The main idea here is to first
>>> partition
>>> the whole network using a Quad tree
>>> approach and
>>> when the
>>> shortest
>>> path is computed these partitions are
>>> loaded on demand. hence , there is an
>>> on demand
>>> incremental
>>> graph
>>> generation.
>>> The project aims at designing and
>>> implementing a
>>> Shortest Path
>>> algorithm on an on demand incremental
>>> Graph using a network partitioning
>>> approach.
>>> *2. Background*
>>> Considering the present status
>>> where pgRouting has
>>> support for
>>> shortest path algorithm like astar etc.
>>> Looking at their implementation details
>>> we can
>>> observe that
>>> the graph
>>> is configured dynamically for all
>>> of them before computation.My proposal
>>> will also be
>>> on the
>>> same track
>>> and for very large networks
>>> where the distance between source and
>>> destination
>>> can be
>>> very large ,
>>> the response time will be
>>> significantly lesser and memory wise
>>> too it will be
>>> lot more
>>> efficient. Presently they don't use any
>>> partitioning
>>> approach so it will prove to be a good
>>> addition to their
>>> support for
>>> shortest past algorithms.
>>> *3. The idea*
>>> There are two major components of my
>>> idea .
>>> *Network Partitioning*
>>> For this part we can use a quad
>>> tree approach.
>>> Say , we
>>> start
>>> with a square and a condition like maximum
>>> number of nodes that can reside
>>> in a square .
>>> if the
>>> number of
>>> nodes in the square is greater than the max
>>> condition we further quarter it
>>> into four
>>> squares and
>>> allot the
>>> nodes appropriately to each of them.All
>>> these
>>> squares can be called grids and
>>> they all will
>>> be addressed
>>> uniquely using a grid cell number .Each
>>> node
>>> will be assigned a grid cell
>>> number based on
>>> the grid
>>> they are
>>> lying inside.
>>> We will have data
>>> structures to address
>>> edges as
>>> they can
>>> remain contained in either one grid cell
>>> or span across a number of grid
>>> cells.the
>>> idea is to
>>> first flag
>>> such edges and store the grid cell numbers
>>> of the grids that the edge
>>> crosses/intersects.
>>> *On demand graph generation and
>>> Routing.*
>>> The idea here is to first
>>> identify the
>>> grid cell
>>> initially and then fetch the edges that
>>> are associated with
>>> that grid. These are the edges
>>> that will get
>>> appended
>>> to the
>>> present graph and the graph will keep
>>> growing
>>> dynamically this way. we will
>>> have appropriate
>>> database
>>> tables
>>> addressing the above issue such that
>>> we are able to fetch the required
>>> edges
>>> quickly using a
>>> database querry.
>>> The implementation details for
>>> the above are :
>>> we will first partition the whole
>>> graph using
>>> the quad tree
>>> approach and each node/vertex will be
>>> assigned
>>> a grid cell number so we can have
>>> database
>>> table for the
>>> assigned nodes and edges like :
>>> CREATE TABLE vertex{
>>> id Node_id
>>> unique
>>> for each
>>> node.
>>> cell grid_cell_number;
>>> \\ the
>>> grid in
>>> which the
>>> node lies.
>>> geometry;
>>> CREATE TABLE edge {
>>> int id ;
>>> Int node_a;
>>> int node_b; \\ the
>>> connecting nodes
>>> // we can have other parameters
>>> like
>>> traversal cost
>>> and return
>>> cost.
>>> using the tables we can then
>>> fetch the
>>> edges form
>>> edge table
>>> using simple database querry once
>>> we are provided with the grid cell
>>> number very easily.
>>> In short the summary of the whole idea
>>> is :
>>> Step1: Fetch the start node , get the
>>> related Grid cell
>>> number.
>>> Step 2: Increment the graph by fetching
>>> all the items
>>> related to
>>> that grid.
>>> Step3 : Check for boundary nodes ( this
>>> is done while
>>> we are
>>> partitioning) or target node .
>>> Step 4: On hitting a boundary node
>>> check if the connected
>>> grid is
>>> loaded and
>>> continue if
>>> it is
>>> or we extend the graph
>>> with the new
>>> grid and
>>> continue
>>> with the routing;
>>> or On hitting the target Node
>>> stop;
>>> *4. Project plan*
>>> I will have about 12 weeks to
>>> implement the
>>> project. The
>>> tentative
>>> schedule is as follows:
>>> Before 17th June : Get familiar
>>> with the development
>>> environment
>>> of pgRouting and test some demos.
>>> week 1-2: Discuss and Define the
>>> various data
>>> structures
>>> and data
>>> table that will be required.Prepare the
>>> Overall
>>> implementation
>>> architecture.
>>> week 3-4- Discuss and Implement
>>> network
>>> partitioning
>>> using quad
>>> tree.
>>> week 5-8 -Start coding for on
>>> demand graph
>>> generation and
>>> routing
>>> using Dijkstra. In between Prepare mid-term
>>> report.
>>> week 9 - Integration with pgrouting
>>> week 10-12- Testing and Bug fixing.
>>> Draft Final
>>> report and
>>> documentation.
>>> 5. Future ideas / How can your idea be
>>> expanded? *
>>> It can be integrated with other
>>> shortest path
>>> algorithms
>>> like
>>> astar etc. which pgrouitng provides.For
>>> time dependent
>>> shortest path computation, it will
>>> greatly reduce the
>>> updating cost
>>> as we will be updating the cost of only
>>> those edges
>>> that are contained in the grid cells
>>> that are loaded.
>>> In route nearest neigbour querries
>>> can also be
>>> implemented using
>>> the partitioning approach.Overall we can
>>> expand this approach to various
>>> other algorithms.
>>> *Explain how your SoC task would benefit
>>> the OSGeo member
>>> project and
>>> more generally the OSGeo Foundation as a
>>> whole:*
>>> The proposed idea will significantly
>>> improve the
>>> performance of
>>> shortest path finding algorithms.This will
>>> have a
>>> positive effect on the user base of
>>> pgRouting. For
>>> various
>>> software
>>> paltforms or applications that are using
>>> this library ,
>>> the response time will significantly
>>> improve.
>>> Please provide details of general
>>> computing experience:
>>> I generally use ubuntu ( 12.04) for all my
>>> academic
>>> purposes and
>>> windows
>>> 7 for entertainment only. I am familiar
>>> with Fedora also.
>>> C++ is the language that i use most (
>>> programming
>>> purposes). For
>>> implementing various course projects i
>>> have used C++
>>> ,python
>>> ,Java and
>>> matlab.
>>> I have no experience with hardware. The
>>> only experience
>>> that i
>>> had with
>>> networking was during my computer network
>>> course.
>>> Please provide details of previous GIS
>>> experience:*
>>> I am a part of "Lab for Spatial
>>> Informatics" which is
>>> the only
>>> lab in
>>> India devoted to GIS applications and
>>> learning. I am
>>> familiar
>>> with and
>>> have used almost all the open source GIS
>>> platforms like
>>> Quantum ,
>>> OpenJump, ILwis,Grass. We have our own
>>> rendering
>>> platform that was
>>> developed by our lab.(LSI viewer)
>>> *Please provide details of any previous
>>> involvement
>>> with GIS
>>> programming
>>> and other software programming:*
>>> I am very much familiar with Gdal/OGR as
>>> i used it
>>> extensively
>>> while
>>> implementing an outsourced project of
>>> Honeywell
>>> Technology . I have played a lot with ESRI
>>> shape files.
>>> *Please tell us why you are interested in
>>> GIS and open
>>> source
>>> software:*
>>> I was very impressed with google earth
>>> when it was
>>> launched way
>>> back in
>>> 2004.GIS platforms like quantum and
>>> Openjump were
>>> introduced to
>>> me when
>>> i was in my second year and then i joined
>>> Lab for spatial
>>> informatics
>>> that is in our college based on my
>>> interest in this area.
>>> open source platforms provide an
>>> opportunity to learn .
>>> The best
>>> part is
>>> you can always create or develop something
>>> that you are
>>> interested in
>>> and there are people who will always be
>>> there to help
>>> you if you
>>> are stuck.
>>> working for
>>> OSGeo and the
>>> software project you have selected:*
>>> It will be huge learning experience since
>>> i have been
>>> using
>>> platforms
>>> like Qgis , Gdal ,PostGis etc which come
>>> under Osgeo
>>> I chose pgrouting because the algorithms
>>> that they have
>>> implemented are
>>> related to my masters topic and it will be
>>> great if i
>>> get an insight
>>> about how these were implemented on a much
>>> larger scale.
>>> your specific
>>> coding
>>> project:*
>>> Implementing routing algorithms for real
>>> world networks is
>>> actually very
>>> challenging.its a challenge to come up
>>> with good
>>> approaches so
>>> that the
>>> computation cost and response time is both
>>> reduced.
>>> *Would your application contribute to your
>>> ongoing
>>> studies/degree? If
>>> so, how?*
>>> I am pursuing my Masters and my topic is
>>> closely
>>> related to my
>>> proposal
>>> . If the results are impressive , i might
>>> get a
>>> publication in
>>> this area.
>>> *Please explain how you intend to continue
>>> being an
>>> active member of
>>> your project and/or OSGeo AFTER the summer
>>> is over:*
>>> I was always interested in open source
>>> programming but
>>> never
>>> knew where
>>> to start . GSOC provides an opportunity
>>> for beginners
>>> like me
>>> to take a
>>> dive in the area open source programming.
>>> i have other
>>> ideas like
>>> implementing IRNN ( In route nearest
>>> neighbour
>>> querries) which
>>> can be
>>> implemented within pgRouting.I have other
>>> intentions like
>>> working for
>>> bigger projects like Quantum Gis or
>>> Grass.I will be
>>> contributing
>>> to the
>>> community forum and will always try to
>>> improve things.
>>> *Do you understand this is a serious
>>> commitment,
>>> equivalent to a
>>> full-time paid summer internship or summer
>>> job?*
>>> Yes, I understand that this is a serious
>>> commitment and
>>> will try
>>> to give
>>> my best and work in a professional manner.
>>> *Do you have any known time conflicts
>>> during the
>>> official coding
>>> period?
>>> (June 17 to Sept. 27)*
>>> No .
>>> On Thu, Apr 25, 2013 at 12:47 AM, Stephen
>>> Woodbridge
>>> <mailto:woodbri at swoodbridge>.
>>> <mailto:woodbri at swoodbridge>.>**______com
>>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>>>
>>> wrote:
>>> On 4/24/2013 2:34 PM, Mukul priya
>>> wrote:
>>> Hi Steve and Daniel ,
>>> I have posted my proposal on
>>> Melange Gsoc
>>> system. Do
>>> have a look
>>> at it.
>>> Waiting for feedback and
>>> suggestions.
>>> Can you post a link to your proposal?
>>> or the text
>>> of it
>>> here also. I
>>> can never find anything in Melange or
>>> I may not have
>>> visibility to
>>> it yet as I just applied as a mentor.
>>> Thanks,
>>> -Steve
>>> ______________________________**_________________________
>>> pgrouting-dev mailing list
>>> pgrouting-dev at lists.osgeo.org
>>> <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>>> <mailto:pgrouting-dev at lists.__**osgeo.org <http://osgeo.org>
>>> <mailto:pgrouting-dev at lists.>_**___osgeo.org <
>>> http://osgeo.org>
>>> <mailto:pgrouting-dev at lists.__**osgeo.org<http://osgeo.org>
>>> <mailto:pgrouting-dev at lists>.
>>> <mailto:pgrouting-dev at lists>.>**______osgeo.org
>>> <http://osgeo.org> <http://osgeo.org>
>>> http://osgeo.org>
>>> http://lists.osgeo.org/_______**_mailman/listinfo/pgrouting-
>>> **dev <http://lists.osgeo.org/________mailman/listinfo/pgrouting-dev> <
>>> http://lists.osgeo.org/______**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev>
>>> <http://lists.osgeo.org/______**
>>> <http://lists.osgeo.org/____**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev>
>>> **>__>
>>> <http://lists.osgeo.org/__**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
>>> **>__>__>
>>> **>__>
>>> <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>> **>__>__>__>
>>> http://osgeo.org>
>>> **>__>
>>> **>__>__>
>>> http://osgeo.org>
>>> **>__>
>>> **>__>__>
>>> **>__>
>>> **>__>
>>> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**
>>> osgeo.org <pgrouting-dev at lists.osgeo.org>>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130503/e965fc8b/attachment-0001.html>
More information about the pgrouting-dev
