[pgrouting-dev] Bidirectional Integration bug
Razequl Islam
ziboncsedu at gmail.com
Mon May 6 22:52:27 PDT 2013
Hi Daniel,
Thanks for the information. I am going through the given link and trying to
set it up. I will let you know if I am finished or I encounter any problem.
Thanks for your help.
- Razequl
On Tue, May 7, 2013 at 11:40 AM, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Razequl,
> The currently used branch is named "sew-devel-2_0" (we're planning to
> rename it to "develop" some time).
> You find all the necessary steps to compile explained on the Github readme:
> https://github.com/pgrouting/pgrouting/tree/sew-devel-2_0
> If you want to compile with support for "Driving Distance", then you need
> to have CGAL libraries as dependency. GAUL dependency is gone.
> Daniel
> On Tue, May 7, 2013 at 2:35 PM, Razequl Islam <ziboncsedu at gmail.com>wrote:
>> Hi Steve,
>> I also want to have a look at the possible problem. I am trying to set up
>> the environment on my machine. I have the previous version. What do I need
>> to do to get 2.0 working? Should I set up the environment from the scratch
>> or should an update will do. Please let me know how I should proceed. I can
>> also do the debugging once I have the environment in place.
>> Thanks.
>> - Razequl
>> On Mon, May 6, 2013 at 11:32 PM, Stephen Woodbridge <
>> woodbri at swoodbridge.com> wrote:
>>> Hi Razequl,
>>> I have been trying to integrate your bidirectional shortest path code. I
>>> have merged the code into my pgrouting branch "sew-devel-2_0", but it is
>>> crashing the back-end with a segv.
>>> If you have time and want to look into this that would be great as I
>>> would like to get this code working in 2.0.
>>> I'm not sure if I found a bug in your code or I broke something when I
>>> merged it, or for that matter that I even merged the correct code :)
>>> because you sent email indicating that you fixed stuff. I merged the code
>>> from master at https://github.com/zibon/**pgrouting<https://github.com/zibon/pgrouting>
>>> I also ran into an issue that when I merged you code into the code
>>> library, that the trsp broke, then take you code out and it works again. I
>>> assume that there is some kind of function name or global initialization
>>> issue. This does not seem to be an issue for trsp now that the bi-dir code
>>> is in a separate library.
>>> This might give you a chance to get your development/test/debug
>>> environment setup and to familiarize yourself with the new source code
>>> layout.
>>> Let me know if you have time and I'll help point the way. If you are
>>> tied up with class work, etc that clearly takes priority.
>>> Thanks,
>>> -Steve
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130507/462eab67/attachment.html>
More information about the pgrouting-dev
