[pgrouting-dev] pgRouting 2.0 using OSX homebrew
Alec Gosse
alec at thegosses.com
Tue May 7 07:27:22 PDT 2013
Hello all,
I am working on a bicycle routing project and converting from Open Trip Planner to pgRouting on both OSX and 64bit Ubuntu with PostgreSQL 9.1+. For me, the sew-revel-2_0 branch will build under ubuntu 12.10, but not on OSX 10.8 using dependencies installed through Homebrew.
Homebrew is certainly the best way I've found to install open-source tools on a mac, so I would like to help get pgRouting 2.0 installable that way. Homebrew tends to use quite current packages such as boost 1.53, however, but I see in tool/NOTES.txt that pgRouting requires boost 1.46.1? Since things build on Ubuntu using boost 1.49, I'm wondering if this still applies?
In either case, what's the best way for me to help get things running under OSX? Should I post errors I can't resolve to the list, and or is someone already working on this?
Best,
Conrad (Alec) Gosse, MUEP
Doctoral Candidate: Civil &
Environmental Engineering
University of Virginia
Charlottesville, VA
On May 7, 2013, at 1:40 AM, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Razequl,
> The currently used branch is named "sew-devel-2_0" (we're planning to rename it to "develop" some time).
> You find all the necessary steps to compile explained on the Github readme:
> https://github.com/pgrouting/pgrouting/tree/sew-devel-2_0
> If you want to compile with support for "Driving Distance", then you need to have CGAL libraries as dependency. GAUL dependency is gone.
> Daniel
> On Tue, May 7, 2013 at 2:35 PM, Razequl Islam <ziboncsedu at gmail.com> wrote:
> Hi Steve,
> I also want to have a look at the possible problem. I am trying to set up the environment on my machine. I have the previous version. What do I need to do to get 2.0 working? Should I set up the environment from the scratch or should an update will do. Please let me know how I should proceed. I can also do the debugging once I have the environment in place.
> Thanks.
> - Razequl
> On Mon, May 6, 2013 at 11:32 PM, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Hi Razequl,
> I have been trying to integrate your bidirectional shortest path code. I have merged the code into my pgrouting branch "sew-devel-2_0", but it is crashing the back-end with a segv.
> If you have time and want to look into this that would be great as I would like to get this code working in 2.0.
> I'm not sure if I found a bug in your code or I broke something when I merged it, or for that matter that I even merged the correct code :) because you sent email indicating that you fixed stuff. I merged the code from master at https://github.com/zibon/pgrouting
> I also ran into an issue that when I merged you code into the code library, that the trsp broke, then take you code out and it works again. I assume that there is some kind of function name or global initialization issue. This does not seem to be an issue for trsp now that the bi-dir code is in a separate library.
> This might give you a chance to get your development/test/debug environment setup and to familiarize yourself with the new source code layout.
> Let me know if you have time and I'll help point the way. If you are tied up with class work, etc that clearly takes priority.
> Thanks,
> -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
More information about the pgrouting-dev
