[pgrouting-dev] pgRouting 2.0 using OSX homebrew
Alec Gosse alec at thegosses.com
Wed May 8 09:23:43 PDT 2013
Hello,
Based on Sanak's changes, I think I've gotten it sorted out. The two primary problems were first, that some of the libraries weren't using the library type variable and were getting the compile flags mixed up between dynamiclibs and osx bundles. The second was that code like this:
property_map<graph_t, edge_weight_t>::type weightmap = get(edge_weight, graph);
needed to be commented out in boost-related files. I don't know what this does, but I've been commenting it based on Sanak's changes, and it at least compiles.
How do I go about contributing these edits once I get it all working?
Best,
Alec
On May 8, 2013, at 11:55 AM, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Hi sanak,
> I looked at your changes below, and they do not seem to be based on my branch "sew-devel-2_0". The quick tell is that my source starts at "src/" and not "core/" as your changes reflect.
> For linux I compile, install and test using:
> tools/doit
> (cd build; sudo make install)
> tools/testrunner.pl
> In the C/C++ code you should be able to use:
> #ifdef __APPLE__
> #else
> #endif
> and in cmake you can use:
> if(APPLE)
> else(APPLE)
> endif(APPLE)
> Can you also post what the results of:
> echo | g++ -dM -E -
> when run on OSX.
> No hurray, when you can get to it, this weekend is fine.
> Thanks,
>  -Steve
> On 5/7/2013 6:05 PM, sanak wrote:
>> Hi Alec, Stephen,
>> About 1 month ago, I tried Mac ports build in my private
>> branch("macports") which is based on "sew-revel-2_0",
>> and confirmed that it can build with Mac OSX 10.8(Mountain Lion).
>> https://github.com/sanak/pgrouting4w/commit/7291a7b6be3bd37c9e507048bfe3ba0fcf0c5c6e
>> Now, I am busy for other task, but, I will check and test it in this
>> weekend.
>> 2013/5/8 Stephen Woodbridge <woodbri at swoodbridge.com
>> <mailto:woodbri at swoodbridge.com>>
>>    On 5/7/2013 10:27 AM, Alec Gosse wrote:
>>        Hello all,
>>        I am working on a bicycle routing project and converting from Open
>>        Trip Planner to pgRouting on both OSX and 64bit Ubuntu with
>>        PostgreSQL 9.1+. For me, the sew-revel-2_0 branch will build under
>>        ubuntu 12.10, but not on OSX 10.8 using dependencies installed
>>        through Homebrew.
>>        Homebrew is certainly the best way I've found to install open-source
>>        tools on a mac, so I would like to help get pgRouting 2.0
>>        installable
>>        that way. Homebrew tends to use quite current packages such as boost
>>        1.53, however, but I see in tool/NOTES.txt that pgRouting requires
>>        boost 1.46.1? Since things build on Ubuntu using boost 1.49, I'm
>>        wondering if this still applies?
>>    Well the required version is whatever you can get to work. I know
>>    there are some problems with 1.47, but those might be specific to
>>    that version.
>>        In either case, what's the best way for me to help get things
>>        running
>>        under OSX? Should I post errors I can't resolve to the list, and or
>>        is someone already working on this?
>>    Yes, We can try to help if we know what errors you are seeing. I'm
>>    not sure anyone here has OSX so you might need to take some
>>    initiative to figure things out. If you look at the CMakeLists.txt
>>    files that are sprinkled throughout the project tree, you will see
>>    that some of them have blocks like:
>>    if(APPLE)
>>    endif(APPLE)
>>    maybe we don't have these setup correctly or maybe some are missing
>>    that need to be added. It would be great if you can help with this.
>>    Thanks,
>>       -Steve
>>        Best, Conrad (Alec) Gosse, MUEP Doctoral Candidate: Civil &
>>        Environmental Engineering University of Virginia Charlottesville, VA
>>        On May 7, 2013, at 1:40 AM, Daniel Kastl <daniel at georepublic.de
>>        <mailto:daniel at georepublic.de>>
>>        wrote:
>>            Hi Razequl,
>>            The currently used branch is named "sew-devel-2_0" (we're
>>            planning
>>            to rename it to "develop" some time). You find all the necessary
>>            steps to compile explained on the Github readme:
>>            https://github.com/pgrouting/__pgrouting/tree/sew-devel-2_0
>>            <https://github.com/pgrouting/pgrouting/tree/sew-devel-2_0>
>>            If you want to compile with support for "Driving Distance", then
>>            you need to have CGAL libraries as dependency. GAUL
>>            dependency is
>>            gone.
>>            Daniel
>>            On Tue, May 7, 2013 at 2:35 PM, Razequl Islam
>>            <ziboncsedu at gmail.com <mailto:ziboncsedu at gmail.com>> wrote:
>>            Hi Steve, I also want to have a look
>>            at the possible problem. I am trying to set up the
>>            environment on
>>            my machine. I have the previous version. What do I need to do to
>>            get 2.0 working? Should I set up the environment from the
>>            scratch
>>            or should an update will do. Please let me know how I should
>>            proceed. I can also do the debugging once I have the
>>            environment in
>>            place.
>>            Thanks. - Razequl
>>            On Mon, May 6, 2013 at 11:32 PM, Stephen Woodbridge
>>            <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>
>>            wrote: Hi Razequl,
>>            I have been trying to integrate your bidirectional shortest path
>>            code. I have merged the code into my pgrouting branch
>>            "sew-devel-2_0", but it is crashing the back-end with a segv.
>>            If you have time and want to look into this that would be
>>            great as
>>            I would like to get this code working in 2.0.
>>            I'm not sure if I found a bug in your code or I broke something
>>            when I merged it, or for that matter that I even merged the
>>            correct
>>            code :) because you sent email indicating that you fixed
>>            stuff. I
>>            merged the code from master at
>>            https://github.com/zibon/__pgrouting
>>            <https://github.com/zibon/pgrouting>
>>            I also ran into an issue that when I merged you code into
>>            the code
>>            library, that the trsp broke, then take you code out and it
>>            works
>>            again. I assume that there is some kind of function name or
>>            global
>>            initialization issue. This does not seem to be an issue for trsp
>>            now that the bi-dir code is in a separate library.
>>            This might give you a chance to get your development/test/debug
>>            environment setup and to familiarize yourself with the new
>>            source
>>            code layout.
>>            Let me know if you have time and I'll help point the way. If you
>>            are tied up with class work, etc that clearly takes priority.
>>            Thanks, -Steve
>>            _________________________________________________ pgrouting-dev
>>            mailing list pgrouting-dev at lists.osgeo.org
>>            <mailto:pgrouting-dev at lists.osgeo.org>
>>            http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
>>            <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>            -- Georepublic UG & Georepublic Japan eMail:
>>            daniel.kastl at georepublic.de
>>            <mailto:daniel.kastl at georepublic.de> Web: http://georepublic.de
>>        mailing
>>    pgrouting-dev mailing list
>>    pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
More information about the pgrouting-dev mailing list
