[pgrouting-dev] pgRouting 2.0 using OSX homebrew
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Wed May  8 09:50:52 PDT 2013
On 5/8/2013 12:23 PM, Alec Gosse wrote:
> Hello,
> Based on Sanak's changes, I think I've gotten it sorted out. The two
> primary problems were first, that some of the libraries weren't using
> the library type variable and were getting the compile flags mixed up
> between dynamiclibs and osx bundles. The second was that code like
> this: property_map<graph_t, edge_weight_t>::type weightmap =
> get(edge_weight, graph); needed to be commented out in boost-related
> files. I don't know what this does, but I've been commenting it based
> on Sanak's changes, and it at least compiles.
> How do I go about contributing these edits once I get it all
> working?
Best way, is to fork the pgrouting respository, make your changes there
and issue a pull request so we can merge your changes.
If there are not too many changes, you could do something like:
git diff > mychanges-diff.txt
And open a ticket and attache the diff file to the ticket.
-Steve
> Best, Alec
> On May 8, 2013, at 11:55 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> Hi sanak,
>> I looked at your changes below, and they do not seem to be based on
>> my branch "sew-devel-2_0". The quick tell is that my source starts
>> at "src/" and not "core/" as your changes reflect.
>> For linux I compile, install and test using:
>> tools/doit (cd build; sudo make install) tools/testrunner.pl
>> In the C/C++ code you should be able to use:
>> #ifdef __APPLE__ ... #else ... #endif
>> and in cmake you can use:
>> if(APPLE) ... else(APPLE) ... endif(APPLE)
>> Can you also post what the results of:
>> echo | g++ -dM -E -
>> when run on OSX.
>> No hurray, when you can get to it, this weekend is fine.
>> Thanks, -Steve
>> On 5/7/2013 6:05 PM, sanak wrote:
>>> Hi Alec, Stephen,
>>> About 1 month ago, I tried Mac ports build in my private
>>> branch("macports") which is based on "sew-revel-2_0", and
>>> confirmed that it can build with Mac OSX 10.8(Mountain Lion).
>>> https://github.com/sanak/pgrouting4w/commit/7291a7b6be3bd37c9e507048bfe3ba0fcf0c5c6e
Now, I am busy for other task, but, I will check and test it in this
>>> weekend.
>>> 2013/5/8 Stephen Woodbridge <woodbri at swoodbridge.com
>>> <mailto:woodbri at swoodbridge.com>>
>>> On 5/7/2013 10:27 AM, Alec Gosse wrote:
>>> Hello all,
>>> I am working on a bicycle routing project and converting from
>>> Open Trip Planner to pgRouting on both OSX and 64bit Ubuntu with
>>> PostgreSQL 9.1+. For me, the sew-revel-2_0 branch will build
>>> under ubuntu 12.10, but not on OSX 10.8 using dependencies
>>> installed through Homebrew.
>>> Homebrew is certainly the best way I've found to install
>>> open-source tools on a mac, so I would like to help get pgRouting
>>> 2.0 installable that way. Homebrew tends to use quite current
>>> packages such as boost 1.53, however, but I see in tool/NOTES.txt
>>> that pgRouting requires boost 1.46.1? Since things build on
>>> Ubuntu using boost 1.49, I'm wondering if this still applies?
>>> Well the required version is whatever you can get to work. I
>>> know there are some problems with 1.47, but those might be
>>> specific to that version.
>>> In either case, what's the best way for me to help get things
>>> running under OSX? Should I post errors I can't resolve to the
>>> list, and or is someone already working on this?
>>> Yes, We can try to help if we know what errors you are seeing.
>>> I'm not sure anyone here has OSX so you might need to take some
>>> initiative to figure things out. If you look at the
>>> CMakeLists.txt files that are sprinkled throughout the project
>>> tree, you will see that some of them have blocks like:
>>> if(APPLE) ... endif(APPLE)
>>> maybe we don't have these setup correctly or maybe some are
>>> missing that need to be added. It would be great if you can help
>>> with this.
>>> Thanks, -Steve
>>> Best, Conrad (Alec) Gosse, MUEP Doctoral Candidate: Civil &
>>> Environmental Engineering University of Virginia Charlottesville,
>>> VA
>>> On May 7, 2013, at 1:40 AM, Daniel Kastl <daniel at georepublic.de
>>> <mailto:daniel at georepublic.de>> wrote:
>>> Hi Razequl,
>>> The currently used branch is named "sew-devel-2_0" (we're
>>> planning to rename it to "develop" some time). You find all the
>>> necessary steps to compile explained on the Github readme:
>>> https://github.com/pgrouting/__pgrouting/tree/sew-devel-2_0
>>> <https://github.com/pgrouting/pgrouting/tree/sew-devel-2_0>
>>> If you want to compile with support for "Driving Distance", then
>>> you need to have CGAL libraries as dependency. GAUL dependency
>>> is gone.
>>> Daniel
>>> On Tue, May 7, 2013 at 2:35 PM, Razequl Islam
>>> <ziboncsedu at gmail.com <mailto:ziboncsedu at gmail.com>> wrote: Hi
>>> Steve, I also want to have a look at the possible problem. I am
>>> trying to set up the environment on my machine. I have the
>>> previous version. What do I need to do to get 2.0 working? Should
>>> I set up the environment from the scratch or should an update
>>> will do. Please let me know how I should proceed. I can also do
>>> the debugging once I have the environment in place.
>>> Thanks. - Razequl
>>> On Mon, May 6, 2013 at 11:32 PM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>> Hi Razequl,
>>> I have been trying to integrate your bidirectional shortest path
>>> code. I have merged the code into my pgrouting branch
>>> "sew-devel-2_0", but it is crashing the back-end with a segv.
>>> If you have time and want to look into this that would be great
>>> as I would like to get this code working in 2.0.
>>> I'm not sure if I found a bug in your code or I broke something
>>> when I merged it, or for that matter that I even merged the
>>> correct code :) because you sent email indicating that you fixed
>>> stuff. I merged the code from master at
>>> https://github.com/zibon/__pgrouting
>>> <https://github.com/zibon/pgrouting>
>>> I also ran into an issue that when I merged you code into the
>>> code library, that the trsp broke, then take you code out and it
>>> works again. I assume that there is some kind of function name
>>> or global initialization issue. This does not seem to be an issue
>>> for trsp now that the bi-dir code is in a separate library.
>>> This might give you a chance to get your development/test/debug
>>> environment setup and to familiarize yourself with the new
>>> source code layout.
>>> Let me know if you have time and I'll help point the way. If you
>>> are tied up with class work, etc that clearly takes priority.
>>> Thanks, -Steve
>>> _________________________________________________ pgrouting-dev
>>> mailing list pgrouting-dev at lists.osgeo.org
>>> <mailto:pgrouting-dev at lists.osgeo.org>
>>> http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
>>> <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>> -- Georepublic UG & Georepublic Japan eMail:
>>> daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
>>> Web: http://georepublic.de
> _______________________________________________ pgrouting-dev mailing
More information about the pgrouting-dev
