[pgrouting-dev] Renaming TYPE structures?
Stephen Woodbridge
woodbri at swoodbridge.com
Fri May 10 08:36:54 PDT 2013
Hi Daniel, et al,
I have added renaming the pgrouting types to the spreadsheet. But I'm
concerned about doing this for a few reasons. If we are going to change
the types, this needs to be done first to avoid having to touch all the
SQL code twice.
pros:
1. it gives a more consistent naming through the project
cons:
1. this change is more invasive because it propagates into the C code
2. it may break the ability of legacy functions from working with old
existing code unless it is possible to define a CAST that would map the
new type to the old type like:
create cast (pgr_pathResult as path_result)
without function as implicit;
I have not tried this but it seems like it might work.
Thoughts?
-Steve
More information about the pgrouting-dev
