[pgrouting-dev] Renaming TYPE structures?
Alec Gosse alec at thegosses.com
Fri May 10 09:26:11 PDT 2013
Hello,
I think it makes sense to the naming consistent for this release since it will only get harder to change in the future.
On a hopefully related note, is there a reason that path_result does not include an explicit edge order? I'm using row_number() OVER (PARTITION BY routeid) to generate one, but my understanding is that this isn't guaranteed to preserve the correct ordering? I also assume that it's adding considerable overhead to the query.
Best,
Alec
On May 10, 2013, at 11:36 AM, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Hi Daniel, et al,
> I have added renaming the pgrouting types to the spreadsheet. But I'm concerned about doing this for a few reasons. If we are going to change the types, this needs to be done first to avoid having to touch all the SQL code twice.
> pros:
> 1. it gives a more consistent naming through the project
> cons:
> 1. this change is more invasive because it propagates into the C code
> 2. it may break the ability of legacy functions from working with old existing code unless it is possible to define a CAST that would map the new type to the old type like:
> create cast (pgr_pathResult as path_result)
>   without function as implicit;
> I have not tried this but it seems like it might work.
> Thoughts?
> -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
