[pgrouting-dev] git dependency in (at least) pgRouting 2.0
Daniel Kastl
daniel at georepublic.de
Fri May 10 19:53:27 PDT 2013
On Sat, May 11, 2013 at 11:38 AM, Stephen Mather
<mather.stephen at gmail.com>wrote:
> I definitely got errors, but I'm wondering if I got the warning, and the
> errors right after for other unrelated reasons. I'll see if I can roll
> back to a state where I can replicate, but it will be Tuesday or Wednesday
> of next week before I can do that.
If you have a chance to post the errors, that would be nice.
I just uninstalled Git for testing, because I have no other environment
here without Git installed ;-)
Then I downloaded
https://github.com/pgRouting/pgrouting/archive/sew-devel-2_0.zip
And to compile I run:
cd pgrouting-sew-devel-2_0/
cmake -H. -Bbuild -DWITH_DD=ON
cd build && make && cd ..
... without errors.
Maybe something else is missing.
But again thanks for pointing out that you can also download the source
from Github as ZIP file. ;-)
Daniel
> Best,
> Steve
> On Fri, May 10, 2013 at 10:35 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>> On Sat, May 11, 2013 at 11:22 AM, Stephen Mather <
>> mather.stephen at gmail.com> wrote:
>>> Cool. Thanks Daniel. I figure I'm the first person to try to install
>>> it without git... :). It was a fresh install though.
>>> Best,
>>> Steve
>> Hi Steve,
>> When you meant "Git is a dependency", did you refer to the cmake output
>> like this?
>> -- The C compiler identification is GNU 4.7.2
>> -- The CXX compiler identification is GNU 4.7.2
>> -- Could NOT find Git (missing: GIT_EXECUTABLE)
>> This indicates, that Git isn't installed, but it doesn't prevent you from
>> compiling.
>> So it's not really a dependency, but if Git is there and the source is a
>> Git repository, then (as for now) it will place the version hash in the
>> documentation for example (in case you build the documentation)
>> Or do you get errors when trying to compile?
>> Daniel
>>> On Fri, May 10, 2013 at 9:47 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>>>> On Sat, May 11, 2013 at 12:59 AM, Stephen Mather <
>>>>> Here's a dependency not listed-- git itself is a dependency... . I
>>>>> know this is a silly thing to point out, but it is possible on github to
>>>>> download a zip of the file without installing git. Should git be added as
>>>>> a dependency?
>>>> I added a Cmake module to get some Git parameters, if available.
>>>> It should check if it's not a Git repository, though I didn't think
>>>> about it could fail if Git is not installed at all.
>>>> Thanks for the comment, because I didn't think about it at all.
>>>> I thought the Git module would be smart enough, but of course this
>>>> shouldn't become a build dependency.
>>>> Will take a look.
>>>> Daniel
>>>>> Best,
>>>>> Steve
>>>>> _______________________________________________
>>>>> pgrouting-dev mailing list
>>>>> pgrouting-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>>> Georepublic UG & Georepublic Japan
>>>> eMail: daniel.kastl at georepublic.de
>>>> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130511/3c5f4900/attachment.html>
More information about the pgrouting-dev
