[pgrouting-dev] git dependency in (at least) pgRouting 2.0
Stephen Woodbridge
woodbri at swoodbridge.com
Fri May 10 20:25:18 PDT 2013
On 5/10/2013 10:35 PM, Daniel Kastl wrote:
> On Sat, May 11, 2013 at 11:22 AM, Stephen Mather
> <mather.stephen at gmail.com <mailto:mather.stephen at gmail.com>> wrote:
> Cool. Thanks Daniel. I figure I'm the first person to try to
> install it without git... :). It was a fresh install though.
> Best,
> Steve
> Hi Steve,
> When you meant "Git is a dependency", did you refer to the cmake output
> like this?
> -- The C compiler identification is GNU 4.7.2
> -- The CXX compiler identification is GNU 4.7.2
> -- Could NOT find Git (missing: GIT_EXECUTABLE)
We should make this message clearer something like:
-- Could NOT find GIT -- ok to continue without it.
-Steve W
> This indicates, that Git isn't installed, but it doesn't prevent you
> from compiling.
> So it's not really a dependency, but if Git is there and the source is a
> Git repository, then (as for now) it will place the version hash in the
> documentation for example (in case you build the documentation)
> Or do you get errors when trying to compile?
> Daniel
> On Fri, May 10, 2013 at 9:47 PM, Daniel Kastl <daniel at georepublic.de
> <mailto:daniel at georepublic.de>> wrote:
> On Sat, May 11, 2013 at 12:59 AM, Stephen Mather
> Here's a dependency not listed-- git itself is a
> dependency... . I know this is a silly thing to point out,
> but it is possible on github to download a zip of the file
> without installing git. Should git be added as a dependency?
> I added a Cmake module to get some Git parameters, if available.
> It should check if it's not a Git repository, though I didn't
> think about it could fail if Git is not installed at all.
> Thanks for the comment, because I didn't think about it at all.
> I thought the Git module would be smart enough, but of course
> this shouldn't become a build dependency.
> Will take a look.
> Daniel
> Best,
> Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> <mailto:pgrouting-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
More information about the pgrouting-dev
