[pgrouting-dev] OSX build error
Alec Gosse alec at thegosses.com
Tue May 28 13:38:36 PDT 2013
Sorry, that did not fix the issue:
/usr/local/src/pgrouting_main/src/kdijkstra/src/k_targets_boost_wrapper.cpp:341:31: error: variable length array of non-POD element type
      'std::vector<int>'
    std::vector<int> path_vect[nb_targets];
This link:
http://stackoverflow.com/questions/9550712/variable-length-array-of-non-pod-element-type-string-aka-basic-stringchar
suggests that the code relies on a g++ extension of the language standard?
Alec
On May 28, 2013, at 4:15 PM, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> I made these changes and they compile and work in linux, so I just pushed them. do another pull and try again.
> Let me know how that goes,
>  -Steve
> On 5/28/2013 4:11 PM, Stephen Woodbridge wrote:
>> Actually, it looks like there are two occurances that need to be changed.
>> -Steve
>> On 5/28/2013 4:07 PM, Stephen Woodbridge wrote:
>>> On 5/28/2013 3:51 PM, Alec Gosse wrote:
>>>> Hello,
>>>> I just pulled the latest in the sew_devel_2-0 branch and got the
>>>> following compiler error under Mac 10.8.
>>>> /usr/local/src/pgrouting_main/src/kdijkstra/src/k_targets_boost_wrapper.cpp:341:26:
>>>>       'vector<int>'
>>>> I can confirm that this does not occur on my Ubuntu machine.
>>> Hi Alec,
>>> I'm not very good with C++, but as a guess, can you edit that line 341
>>> and change it from:
>>> to:
>>> And let me know if that fixes your compile problem.
>>> Thanks,
>>>   -Steve
>>> pgrouting-dev mailing list
>>> pgrouting-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
