[pgrouting-dev] OSX build error
Stephen Woodbridge
woodbri at swoodbridge.com
Tue May 28 14:17:16 PDT 2013
On 5/28/2013 4:38 PM, Alec Gosse wrote:
> Sorry, that did not fix the issue:
> /usr/local/src/pgrouting_main/src/kdijkstra/src/k_targets_boost_wrapper.cpp:341:31: error: variable length array of non-POD element type
> 'std::vector<int>'
> std::vector<int> path_vect[nb_targets];
What happens if you change this from:
to:
std::vector<int> path_vect(nb_targets);
I just guessing here, so someone with C++ experience please jump in!
-Steve
> This link:
> http://stackoverflow.com/questions/9550712/variable-length-array-of-non-pod-element-type-string-aka-basic-stringchar
> suggests that the code relies on a g++ extension of the language standard?
> Alec
> On May 28, 2013, at 4:15 PM, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>> I made these changes and they compile and work in linux, so I just pushed them. do another pull and try again.
>> Let me know how that goes,
>> -Steve
>> On 5/28/2013 4:11 PM, Stephen Woodbridge wrote:
>>> Actually, it looks like there are two occurances that need to be changed.
>>> -Steve
>>> On 5/28/2013 4:07 PM, Stephen Woodbridge wrote:
>>>> On 5/28/2013 3:51 PM, Alec Gosse wrote:
>>>>> Hello,
>>>>> I just pulled the latest in the sew_devel_2-0 branch and got the
>>>>> following compiler error under Mac 10.8.
>>>>> /usr/local/src/pgrouting_main/src/kdijkstra/src/k_targets_boost_wrapper.cpp:341:26:
>>>>> 'vector<int>'
>>>>> I can confirm that this does not occur on my Ubuntu machine.
>>>> Hi Alec,
>>>> I'm not very good with C++, but as a guess, can you edit that line 341
>>>> and change it from:
>>>> to:
>>>> And let me know if that fixes your compile problem.
>>>> Thanks,
>>>> -Steve
>>>> _______________________________________________
>>>> pgrouting-dev mailing list
>>>> pgrouting-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev
