[pgrouting-dev] Version, version, who has the version
Daniel Kastl
daniel at georepublic.de
Tue May 28 19:14:07 PDT 2013
On Tue, May 28, 2013 at 10:00 PM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> On 5/28/2013 12:45 AM, Daniel Kastl wrote:
>> On Tue, May 28, 2013 at 1:16 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>> wrote:
>> I have made a bunch of changes that are all version related.
>> 1. I have added three functions (not documented)
>> pgr_test=# select pgr_version();
>> pgr_version
>> 2.0.0-dev
>> (1 row)
>> pgr_test=# select pgr_full_version();
>> pgr_full_version
>> ------------------------------**__----------------
>> 2.0.0-dev v2.0dev-271-g6eeef9b sew-devel-2_0
>> (1 row)
>> pgr_test=# select pgr_build_version();
>> pgr_build_version
>> (1 row)
>> Here is what all this means:
>> VERSION TAG BUILD HASH BRANCH
>> 2. I have added a top-level file VERSION and tools/pre-commit hook
>> to keep it updated. Daniel you will have to copy tools/pre-commit to
>> .git/hooks/pre-commit
>> I'm not sure how much I like this. I have tried a post-commit hook
>> which updates the local file with the hash and build info after the
>> commit in the local copy but not the copy send to github and the
>> pre-commit hook updates the file with the has BEFORE the commit so
>> it always reflects and state before the commit, but that also means
>> the number in the file will match what is on the server.
>> BTW, It is not possible to set the hash of a current commit into a
>> file that is getting committed because the hash IS based on the
>> content of the files committed, so you get infinite recursion!
>> Hi Steve,
>> The Git hooks look like a good way to automate this.
>> I always thought to use CMake GIT module, but obviously this doesn't
>> work if the source is not a repository.
>> Looking at PostGIS they also include information about libraries
>> required to build and compile.
>> So I thought we could somehow also add information about the version of
>> CMake and Boost for example.
>> But I don't know exactly how to put this information in SQL files ...
>> probably the Sphinx CMake module does something like this, but I need to
>> study this first.
> OK, I do not think that we need to add the library information. In the
> postGIS case, there code and therefore their bugs, are highly related to
> their libraries and they also develop, support and release some of the
> libraries. The only library that we are dependent on at the moment is CGAL
> and I don't expect that we will have many bugs because of this dependency.
> So lets not do this.
> Regarding how the names get into the pgr_*version() functions the SQL just
> have cmake variable names and in CMakeLists.txt we have:
> configure_file("${CMAKE_**BINARY_DIR}/lib/pgrouting--${**
> PGROUTING_VERSION_STRING}.sql.**in <http://sql.in>"
> "${CMAKE_BINARY_DIR}/lib/**pgrouting--${PGROUTING_**
> VERSION_STRING}.sql")
> that does the subsitution. You can do the same thing with doc files if you
> have cmake pre-process them, do it how you are doing it now.
> I think the version function is't something that may not change in
>> future versions. So we could leave it like this and we can improve it
>> when we have a good idea.
>> Just one thing I never understood also with the PostGIS version function:
>> * What's the purpose of multiple functions?
>> * Why does the return type needs to be a single text string and can't
>> be split into multiple attributes instead?
> It is just easier to use the function that you gives you what you need
> rather than require the user to figure out how to parse the strings. We
> already know how to do that, but everyone might not.
Hi Steve,
What about just one "pgr_version()" function?
I don't get the use case where we need two of them ;-)
I think "pgr_version()" should then return the "full" version.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130529/6ea9d2d0/attachment.html>
More information about the pgrouting-dev
