[pgrouting-dev] Version, version, who has the version
Daniel Kastl
daniel at georepublic.de
Tue May 28 20:40:14 PDT 2013
On Wed, May 29, 2013 at 12:18 PM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> On 5/28/2013 10:14 PM, Daniel Kastl wrote:
>> What about just one "pgr_version()" function?
>> I don't get the use case where we need two of them ;-)
>> I think "pgr_version()" should then return the "full" version.
> I'm fine with have to two functions.
> pgr_full_version() - this would be the full string with everything
> pgr_version() - this should match version of extension like:
> 2.0.0-dev in pgrouting--2.0.0-dev.sql
> The full version string is what we want for bug reporting.
> The version is what you might want to use in an application to construct
> if clauses based on features available in this or that version of the
> software.
What about
pgr_version() -> should match version of extension
pgr_version("full") -> full string with everything (could be also "debug")
I know this is not really important discussion, but we did so well in
decreasing the number of functions and then we're having multiple ones for
just getting the version information ;-)
Also I had to add two pages to the function reference somehow.
I still like the idea to return a record, because someone could pick what
is important if used for an application, like:
SELECT * FROM pgr_version();
version | tag | build | hash | branch
2.0.0-dev | v2.0dev | 271 | g6eeef9b | sew-devel-2_0
So one could get the version with SELECT version FROM pgr_version() in case
they really use it for some application for example;
Well, I think I can do the modification as well.
Daniel
> This seems simple and convenient to provide and is a straight forward
> explanation of what they are for.
> -Steve
> ______________________________**_________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130529/8601ce56/attachment-0001.html>
More information about the pgrouting-dev
