[pgrouting-dev] Build
Stephen Mather stephen at smathermather.com
Sun Nov 24 19:14:40 PST 2013
OK, I created an issue, https://github.com/pgRouting/pgrouting/issues/218 .
This is something I'm actually capable of, so maybe I'll get some time to
do some testing when things calm down for me.
Best,
Steve
On Sun, Nov 24, 2013 at 9:55 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 11/24/2013 9:48 PM, Stephen Mather wrote:
>> Is it wrong to set a minimum known version?  You could even specify it
>> as such.  It would give people an opportunity to decide if their package
>> managed versions stand a change before building from source.
> There is nothing "wrong" with that but it is just one more thing that
> someone has to do and document. With the exception of cmake the needs to be
> at least 2.8, and postgresql 8.4+ we put very little version requirements
> on the dependencies. This is in part because we mostly use very basic and
> simple features of those packages.
> We are working on improving our game. Rev 2.0 was a big step in that
> directions and it help from you and the community we hope to get better in
> future releases.
> Feel free to open a ticket and we will make an effort to collect more
> information for the next release.
> Thanks,
>   -Steve W.
>  Best,
>> Steve
>> On Sun, Nov 24, 2013 at 9:37 AM, Daniel Kastl <daniel at georepublic.de
>> <mailto:daniel at georepublic.de>> wrote:
>>     Just some additional comment:
>>     I wanted to fill in the minimum required versions, but just didn't
>>     try ancient versions of Boost and CGAL, or uncommon combinations.
>>     In general pgRouting seems to work with recent version of Boost and
>>     CGAL, or with versions that are available in package mangers of
>>     popular Linux distributions.
>>     So I don't know what to write instead of "[TBD]". Maybe we should
>>     just list the dependencies and remove the minimum required version
>>     part, where we don't know about it.
>>     Daniel
>>     On Sun, Nov 24, 2013 at 3:01 PM, Stephen Woodbridge
>>     <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>         On 11/23/2013 10:21 PM, Stephen Mather wrote:
>>             Do we know yet what the minimum versions are for building
>>             listed here?:
>>             http://docs.pgrouting.org/2.0/__en/doc/src/installation/
>> build.__html#build
>>             <http://docs.pgrouting.org/2.0/en/doc/src/installation/
>> build.html#build>
>>             e.g. what can I get away with for Boost... .
>>         I was running Boost 1.34 on a Lenny system without a problem
>>         until some other dependency caused builds to fail.
>>         I have built with 1.42 on squeeze and 1.49 on wheezy.
>>         In general, most versions will work. I think there was one maybe
>>         two versions that were broken because of some that boost did
>>         like moving includes around but I have since then ifdef's the
>>         boost versions if there is an issue that I know about.
>>         Too many to test them all! If you find one that does not work,
>>         file a bug and I'll fix it or document it as a problem.
>>         Thanks,
>>            -Steve
>>         _________________________________________________
>>         pgrouting-dev mailing list
>>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.
>> osgeo.org>
>>         http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
>>         <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>     Georepublic UG & Georepublic Japan
>>     eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl@
>> georepublic.de>
>>     Web: http://georepublic.de <http://georepublic.de/>
>>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20131124/3b2c72a1/attachment.html>
More information about the pgrouting-dev mailing list
