[pgrouting-dev] [postgis-devel] Issue installing postgis-2.0 in Pg 9.3
Stephen Woodbridge woodbri at swoodbridge.com
Tue Apr 15 18:13:56 PDT 2014
Regina,
Thank you for looking into this and relaying that information.
Daniel,
When you have a chance it sounds like we need travis updated to only
support the matrix below.
Thanks,
   -Steve
On 4/15/2014 4:44 PM, Paragon Corporation wrote:
> Steve,
> PostGIS 2.0  is not supported for Pg 9.3.  We had patched up 2.1 with the
> htup_details.h to work with 9.3 (pgRouting is fine I think because we had
> already patched it for 9.3 when I noticed the same issue a while ago)
> You need to run PostGIS 2.1 or above with 9.3.
> The fixes you've been seeing on the net are people patching up 2.0 to work
> with 9.3 which is not a supported mix. See matrix for details --
> http://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at lists.osgeo.org
> [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Stephen
> Woodbridge
> Sent: Tuesday, April 15, 2014 3:33 PM
> To: PostGIS Development Discussion
> Subject: [postgis-devel] Issue installing postgis-2.0 in Pg 9.3
> Hi devs,
> I just noticed that the pgrouting travis instance is failing when we try to
> create a postgresql 9.3 and install postgis-2.0 into it with the follow
> error:
> ERROR: could not load library
> "/usr/lib/postgresql/9.3/lib/postgis-2.0.so":
> /usr/lib/postgresql/9.3/lib/postgis-2.0.so: undefined symbol: GETSTRUCT
> This is running Ubuntu precise? and probably packages from the Ubuntu GIS
> ppa from launchpad.
> So two questions:
> 1. Is this known/fixed/etc? Are we just out of date on travis?
> 2. For pgRouting, will I need to add something like:
> #if POSTGIS_PGSQL_VERSION >= 93
> #include "access/htup_details.h"
> #endif
> To all my C functions that are called from plpgsql?
> Thanks,
>     -Steve
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
