[pgrouting-dev] [postgis-devel] Issue installing postgis-2.0 in Pg 9.3
Daniel Kastl
daniel at georepublic.de
Tue Apr 15 18:34:31 PDT 2014
OK, it's just necessary to comment out one line in the Travis configuration.
Will do it.
Daniel
On Wed, Apr 16, 2014 at 10:13 AM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> Regina,
> Thank you for looking into this and relaying that information.
> Daniel,
> When you have a chance it sounds like we need travis updated to only
> support the matrix below.
> Thanks,
> -Steve
> On 4/15/2014 4:44 PM, Paragon Corporation wrote:
>> Steve,
>> PostGIS 2.0 is not supported for Pg 9.3. We had patched up 2.1 with the
>> htup_details.h to work with 9.3 (pgRouting is fine I think because we had
>> already patched it for 9.3 when I noticed the same issue a while ago)
>> You need to run PostGIS 2.1 or above with 9.3.
>> The fixes you've been seeing on the net are people patching up 2.0 to work
>> with 9.3 which is not a supported mix. See matrix for details --
>> http://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
>> Hope that helps,
>> Regina
>> -----Original Message-----
>> From: postgis-devel-bounces at lists.osgeo.org
>> [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Stephen
>> Woodbridge
>> Sent: Tuesday, April 15, 2014 3:33 PM
>> To: PostGIS Development Discussion
>> Subject: [postgis-devel] Issue installing postgis-2.0 in Pg 9.3
>> Hi devs,
>> I just noticed that the pgrouting travis instance is failing when we try
>> to
>> create a postgresql 9.3 and install postgis-2.0 into it with the follow
>> error:
>> ERROR: could not load library
>> "/usr/lib/postgresql/9.3/lib/postgis-2.0.so":
>> /usr/lib/postgresql/9.3/lib/postgis-2.0.so: undefined symbol: GETSTRUCT
>> This is running Ubuntu precise? and probably packages from the Ubuntu GIS
>> ppa from launchpad.
>> So two questions:
>> 1. Is this known/fixed/etc? Are we just out of date on travis?
>> 2. For pgRouting, will I need to add something like:
>> #if POSTGIS_PGSQL_VERSION >= 93
>> #include "access/htup_details.h"
>> #endif
>> To all my C functions that are called from plpgsql?
>> Thanks,
>> -Steve
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140416/9d6f5a1b/attachment-0001.html>
More information about the pgrouting-dev
