[pgrouting-dev] windows 9.3 w64 bdstar-any.test failure
Paragon Corporation lr at pcorp.us
Wed Apr 16 00:30:01 PDT 2014
Fixed another issue with jenkins with my path changes so it wasn't testing
the latest source.
However after the fixing, the windows 9.3 w64 build fails one test (9.3 w32
and 9.2s both w32/w64 are fine)
I presume this is a new test since I don't see it in 2.0 release logs.
Failing test is this one:
   'doc/test/bdstar-any.test' => 'FAILED: 1,5c1
< 0|4|3|0
< 1|3|5|1
< 2|6|11|1
< 3|11|12|0
< 4|10|-1|0
> ERROR:  Error computing path: Path Not Found',
Does it only fail on windows 9.3 64bit? Or is this seen on other platforms.
I presume I should be worried about it.
Thanks,
Regina
--full log --
Processing test: sampledata
    test run time: 0.750001
Processing test: alphashape-any
    test run time: 0.439451
Processing test: apspJohnson-any
    test run time: 0.435356
Processing test: apspWarshall-any
    test run time: 0.428825
Processing test: astar-any
    test run time: 0.430389
Processing test: bdstar-any
    test run time: 0.43254
Processing test: bdDijkstra-any
    test run time: 0.426679
Processing test: dijkstra-any
    test run time: 0.431251
Processing test: drivingDistance-any
    test run time: 0.427962
Processing test: pointsAsPolygon-any
    test run time: 0.445802
Processing test: kdijkstra-any
    test run time: 0.444671
Processing test: tsp-any
    test run time: 0.64054
Processing test: trsp-any
    test run time: 0.445026
Processing test: utilities-any
    test run time: 0.429804
Processing test: createTopology-any
    test run time: 3.390548
Processing test: createVertTab-any
    test run time: 2.312395
Processing test: analyzeGraph-any
    test run time: 3.406166
Processing test: analyzeOneway-any
    test run time: 0.531148
Processing test: nodeNetwork-any
    test run time: 1.749912
Processing test: apsp_johnson-any-00
    test run time: 0.42163
Processing test: apsp_warshall-any-00
    test run time: 0.433606
Processing test: spas-any-00
    test run time: 0.426944
Processing test: spas-any-01
    test run time: 0.428268
Processing test: bd_astar-any-01
    test run time: 0.490152
Processing test: bd_astar-any-02
    test run time: 0.494138
Processing test: bd_astar-any-03
    test run time: 0.4844
Processing test: bd_astar-any-04
    test run time: 0.484195
Processing test: bd_astar-any-05
    test run time: 0.487583
Processing test: bd_astar-any-06
    test run time: 0.481013
Processing test: bd_dijkstra-any-01
    test run time: 0.483489
Processing test: bd_dijkstra-any-02
    test run time: 0.48134
Processing test: bd_dijkstra-any-03
    test run time: 0.487245
Processing test: bd_dijkstra-any-04
    test run time: 0.477802
Processing test: bd_dijkstra-any-05
    test run time: 0.475179
Processing test: bd_dijkstra-any-06
    test run time: 0.48037
Processing test: versionless-any-01
    test run time: 0.515625
Processing test: common-any-01
    test run time: 0.718665
Processing test: common-any-02
    test run time: 0.843667
Processing test: common-any-03
    test run time: 0.765543
Processing test: common-any-04
    test run time: 1.500003
Processing test: common-any-05
    test run time: 0.796777
Processing test: createTopology-any-01
    test run time: 8.703063
Processing test: createVerticesTable-any-01
    test run time: 5.48428
Processing test: gettablename-any-01
    test run time: 1.828011
Processing test: pgrouting_conversion_tools-any-01
    test run time: 0.476386
Processing test: pgrouting_dmatrix_tools-any-01
    test run time: 0.507785
Processing test: spd-any-00
    test run time: 0.424661
Processing test: spd-any-01
    test run time: 0.431578
Processing test: spd-any-02
    test run time: 0.42765
Processing test: spd-any-03
    test run time: 0.428257
Processing test: spd-any-04
    test run time: 0.43095
Processing test: drivingdistance-any-00
    test run time: 0.453126
Processing test: kdijkstra-any-01
    test run time: 0.437412
Processing test: kdijkstra-any-02
    test run time: 0.435334
Processing test: kdijkstra-any-03
    test run time: 0.439515
Processing test: vidstodmatrix-any-01
    test run time: 0.433029
Processing test: vidstodmatrix-any-02
    test run time: 0.426178
Processing test: ksp-any-01
    test run time: 0.4382
Processing test: ksp-any-02
    test run time: 0.435956
Processing test: trsp-any-00
    test run time: 0.430287
Processing test: trsp-any-01
    test run time: 0.429003
Processing test: trsp-any-02
    test run time: 0.430788
Processing test: trsp-any-03
    test run time: 0.428426
Processing test: trsp_vias-any-04
    test run time: 0.440013
Processing test: trsp-issue244
    test run time: 0.434824
Processing test: tsp-any-00
    test run time: 0.562236
Processing test: tsp-any-01
    test run time: 0.515544
Processing test: tsp-any-03
    test run time: 1.046802
Processing test: tsp-any-04
    test run time: 0.49991
Processing test: tsp-any-05
    test run time: 0.531171
$stats = {
           'doc/test/test.conf' => [
                                       'comment' => 'documentation SQL tests
for any versions.',
                                       'doc/test/alphashape-any.test' =>
'Passed',
                                       'doc/test/analyzeGraph-any.test' =>
'Passed',
                                       'doc/test/analyzeOneway-any.test' =>
'Passed',
                                       'doc/test/apspJohnson-any.test' =>
'Passed',
                                       'doc/test/apspWarshall-any.test' =>
'Passed',
                                       'doc/test/astar-any.test' =>
'Passed',
                                       'doc/test/bdDijkstra-any.test' =>
'Passed',
'FAILED: 1,5c1
< 0|4|3|0
< 1|3|5|1
< 2|6|11|1
< 3|11|12|0
< 4|10|-1|0
                                       'doc/test/createTopology-any.test' =>
'Passed',
                                       'doc/test/createVertTab-any.test' =>
'Passed',
                                       'doc/test/dijkstra-any.test' =>
'Passed',
                                       'doc/test/drivingDistance-any.test'
=> 'Passed',
                                       'doc/test/kdijkstra-any.test' =>
'Passed',
                                       'doc/test/nodeNetwork-any.test' =>
'Passed',
                                       'doc/test/pointsAsPolygon-any.test'
=> 'Passed',
                                       'doc/test/sampledata.test' =>
'Passed',
                                       'doc/test/trsp-any.test' => 'Passed',
                                       'doc/test/tsp-any.test' => 'Passed',
                                       'doc/test/utilities-any.test' =>
'Passed'
           'src/apsp_johnson/test/test.conf' => [
                                                    'comment' => 'APSP
Johnson test for any versions.',
'src/apsp_johnson/test/apsp_johnson-any-00.test' => 'Passed'
           'src/apsp_warshall/test/test.conf' => [
                                                     'comment' => 'APSP
Warshall test for any versions.',
'src/apsp_warshall/test/apsp_warshall-any-00.test' => 'Passed'
           'src/astar/test/test.conf' => [
                                             'comment' => 'astar test for
any versions.',
'src/astar/test/spas-any-00.test' => 'Passed',
'src/astar/test/spas-any-01.test' => 'Passed'
           'src/bd_astar/test/test.conf' => [
                                                'comment' => 'Bi-directional
AStar test for any versions.',
'src/bd_astar/test/bd_astar-any-01.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-02.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-03.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-04.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-05.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-06.test' => 'Passed'
           'src/bd_dijkstra/test/test.conf' => [
                                                   'comment' =>
'Bi-directional Dijkstra test for any versions.',
'src/bd_dijkstra/test/bd_dijkstra-any-01.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-02.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-03.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-04.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-05.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-06.test' => 'Passed'
           'src/common/test/test.conf' => [
                                              'comment' =>
'pgr_createTopology, pgr_analyzegraph, and pgr_analyzeOneway tests for any
versions.',
'src/common/test/common-any-01.test' => 'Passed',
'src/common/test/common-any-02.test' => 'Passed',
'src/common/test/common-any-03.test' => 'Passed',
'src/common/test/common-any-04.test' => 'Passed',
'src/common/test/common-any-05.test' => 'Passed',
'src/common/test/createTopology-any-01.test' => 'Passed',
'src/common/test/createVerticesTable-any-01.test' => 'Passed',
'src/common/test/gettablename-any-01.test' => 'Passed',
'src/common/test/pgrouting_conversion_tools-any-01.test' => 'Passed',
'src/common/test/pgrouting_dmatrix_tools-any-01.test' => 'Passed',
'src/common/test/versionless-any-01.test' => 'Passed'
           'src/dijkstra/test/test.conf' => [
                                                'comment' => 'Dijkstra test
for any versions.',
'src/dijkstra/test/spd-any-00.test' => 'Passed',
'src/dijkstra/test/spd-any-01.test' => 'Passed',
'src/dijkstra/test/spd-any-02.test' => 'Passed',
'src/dijkstra/test/spd-any-03.test' => 'Passed',
'src/dijkstra/test/spd-any-04.test' => 'Passed'
           'src/driving_distance/test/test.conf' => [
                                                        'comment' =>
'Driving Distance test for any versions.',
'src/driving_distance/test/drivingdistance-any-00.test' => 'Passed'
           'src/kdijkstra/test/test.conf' => [
                                                 'comment' => 'KDijkstra
'src/kdijkstra/test/kdijkstra-any-01.test' => 'Passed',
'src/kdijkstra/test/kdijkstra-any-02.test' => 'Passed',
'src/kdijkstra/test/kdijkstra-any-03.test' => 'Passed',
'src/kdijkstra/test/vidstodmatrix-any-01.test' => 'Passed',
'src/kdijkstra/test/vidstodmatrix-any-02.test' => 'Passed'
           'src/ksp/test/test.conf' => [
                                           'comment' => 'KSP test for any
versions.',
                                           'src/ksp/test/ksp-any-01.test' =>
'Passed',
                                           'src/ksp/test/ksp-any-02.test' =>
'Passed'
           'src/trsp/test/test.conf' => [
                                            'comment' => 'TRSP test for any
versions.',
                                            'src/trsp/test/trsp-any-00.test'
=> 'Passed',
                                            'src/trsp/test/trsp-any-01.test'
=> 'Passed',
                                            'src/trsp/test/trsp-any-02.test'
=> 'Passed',
                                            'src/trsp/test/trsp-any-03.test'
=> 'Passed',
'src/trsp/test/trsp-issue244.test' => 'Passed',
'src/trsp/test/trsp_vias-any-04.test' => 'Passed'
           'src/tsp/test/test.conf' => [
                                           'comment' => 'TSP test for any
versions.',
                                           'src/tsp/test/tsp-any-00.test' =>
'Passed',
                                           'src/tsp/test/tsp-any-01.test' =>
'Passed',
                                           'src/tsp/test/tsp-any-03.test' =>
'Passed',
                                           'src/tsp/test/tsp-any-04.test' =>
'Passed',
                                           'src/tsp/test/tsp-any-05.test' =>
'Passed'
           'z_crash' => 0,
           'z_fail' => 1,
           'z_pass' => 69
More information about the pgrouting-dev mailing list
